    Help modeling a whirlpool
    6 Posts 3 Posters 286 Views 3 Watching
      KarinaGM
      Hi. Me again not knowing how to model something...
      I need to render a turbulence/whirlpool and I'm not sure how to model it.
      I tried making a double spiral, but maybe because of the imprecise form (or just because it is not the way) the results were not good.
      As I have difficulties trying to express myself in english, I attach an image of what I've modeled so far.
      this is a quick render
      here is where I want to place the whirlpool
      and here is the model in SU. A tapered double spiral
      Thanks for all the helpful topics and for any help you can give me 😄
      **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
      -Benjamín Franklin.**
        KarinaGM
        Oh, sorry. Is not a double but a single (very fat) tapered spiral.
          KarinaGM
          No ideas?
          I'll try making a smaller spiral touching the blades and see if it looks better. Also I'll make the bump map smaller in the render.
          Anyway It doesn't have to be accurate, just give the idea of movement.
          • N Offline
            notareal
            I seen whirlpool/vortex made with blender fluid simulation.
            http://www.youtube.com/watch?v=j2dNHQtcmSM
            Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
              KarinaGM
              Oh thanks.
              Here at work I have blocked the access to youtube, so I'll check it at home
              Though the most complicated I've done in blender is a penguin 😆
                A smaller tapering cylinder along a 3D spiraling helix staring at the impeller's blade ends should work better with transparency and a good bump-map ?
