    Revit Architecture 2010
    extensions
    15 Posts 7 Posters 2.8k Views 7 Watching
    • KrisidiousK
      Krisidious
      so windows and doors are no good... and walls shouldn't even be to size... just lines?
      By: Kristoff Rand
        You're best of just creating the volume in SU. Keep it very simple.
        Thick walls and detailed windows etc will just confuse Revit.
        • KrisidiousK
          Krisidious
          well how depressing... glad I found this out before I got too deep in it. thank goodness for trials...
          By: Kristoff Rand
            Revit sees a surface as a surface - it does know that one surface is part of a "wall", "roof", "window" etc.
              I've successfully imported a skp of planes as a massing element, then converted the various planes to walls, floors, roofs, curtain walls etc, BUT twiddly bits like doors and windows don't come over well.
              You can model a complex skp form and import it - e.g. a reception desk -it is not easily editable later inside Revit... 😞
                ScottPara
                You can import sketchup models into revit as I have done it many times. BUT the process is long and confusing if you do not follow certain steps.
                First you need to use color by layer in Sketchup, naming your layers something you will be able to identify again in Revit is crucial.
                Keep in mind your RGB color values need to not be to close to one another otherwise revit will group them together for some odd reason. Not sure if this is a bug or not but have never been able to crack this part.
                Next you need to explode your model as revit will screw stuff up in groups/components.
                Now you import your model into Revit.
                Open "setting/objects".
                Select the "imported objects" tab.
                Change all your line colors to black (important).
                Now take note of the layer names, renaming them if necessary.
                Close window.
                Open the "settings/materials" section.
                Delete everything called "render material".
                Create all new layers for each color/texture. Make sure the layer names are descriptive so you can find them later.
                In the graphics tab set "use render appearance for shading".
                Select the "render appearance" tab
                Under "general material properties" select the RGB button.
                Now match the RGB codes of the original Sketchup models colors/textures for all materials. once you are done click ok. This is when you need the original (not the color by layer one) Sketchup model open while doing this in Revit.
                Now go to "settings/object styles" and select "imported objects".
                In the section "materials" makes sure there are materials for every imported layer. these should be named correctly and correspond to the layers to easily keep track of things.
                Select the material for the first layer then click on the "...", the material editing box opens up.
                Select the material that has the same name as the layer you created earlier. click "ok". Do this for all imported layers. close the "object styles" section when finished.
                Save the model as a family under the appropriate families in revit.
                Open a new revit project and import your newly created family and render it to make sure you have completed all the steps properly. if not you have some backtracking to do. If you do have issues go back and correct them in the family but you will need to open a NEW project as revit stores the old materials and things will not automatically update (another one I found out the hard way).
                Some hints: glass can be a B***ch to get to look right and I suggest you use a revit material for all transparencies. I have spent countless hours trying to get sketchup transparencies to work correctly with very limited success.
                Good luck. As you can see this is not an easy process. I wish Autodesk would make the importation of sketchup models more seamless but for the time being this is what works.
                Hope this helps.
                Scott
                Love the fact that some HATE my avatar.....
                  ScottPara
                  The colors will be transferred "by layer" but no textures will carry over.
                  Scott
                    JGA
                    Scott,
                    Thanks for the information, I didn't know that any colour information could be transferred across.
                    Regards,
                    JGA
                    Regards,
                    JGA
                    • FletchF
                      Fletch
                      just don't bother trying if you have any curved surface at all. 😆 (there's no smoothing that I've ever found.)
                      More than one person in our office spent more than 6hrs at a time trying to make simple flatscreen TVs, or Windows that would flex parametrically... could have been done in 5 mins in SU. 🤣
                      I'm impressed, Scott, 👍 as after 6+ hrs trying to get a simple sink to import/render in Revit, I gave up every trying to import and render anything from SU inside of Revit ever again! 😒
                      Fletch
                        ScottPara
                        Fletch,
                        Yes, smoothing can be a B*@tch but I think I have a way in my notes somewhere but I have not looked at them in quite some time. I will go through them this weekend and see what I have.
                        Importing SU models successfully into Revit can be done. It takes a fair bit of patience and time but it works. I have done hundreds of models in the past using SU 7 pro and Revit 2010. Once you get the basic down your off and running. The thing that always drove me nuts was the colors. If the values are too close to eachother Revit merges the geometry together. I have not found a way around this other than spreading color values out further. It can just be a pain in the backside on a model that has large amounts of colors/textures.
                        If anyone needs help let me know and I can walk you through it or add some more notes together.
                        Scott
                          JGA
                          Thanks again for the tips.
                          Is the avatar image a dormobile for hobbits??!
                          Regards,
                          JGA
                          • mitcorbM
                            mitcorb
                            Oh well--you gotta love it.
                              ScottPara
                              No just a damn funny pic I found this morning and liked it.
                              Scott
