    Stretching with an offset + stretching on all sides
    37 Posts 7 Posters 2.1k Views 7 Watching
      MartinRinehart
      @agamemnus said:
      I was afraid of this. I know about everything you just mentioned but I was hoping I had missed some little-known shortcut. I guess not.
      Some of these problems have simple Ruby Console solutions. I'm not sure I understand what you were doing, tho. Would a picture be possible?
        agamemnus
        Take a look at my ship WIP:
        http://forums.sketchucation.com/viewtopic.php?f=81&t=26699
        What would you do if you wanted to scale the hull to a certain width/height/length? The inner skin of the hull needs to be scaled exactly as much (in terms of absolute size--ie, +10 meters in length) to maintain the shell size, but the regular Sketchup scaling tools can't do that.
          agememnus
          I haven't read the whole thread but you say you can't Scale to a set size...
          You can use the Scale tool and enter a dimension with a text suffix identifier - e.g. 10m, it will scale in the selected axis/axes to make it 10m, rather than plain 10 which would make it 10 times bigger...
            MartinRinehart
            Go with TIG's stuff.
            • Jean LemireJ Offline
              Jean Lemire
              Hi folks.
              In addition, you can control how far the Scale Tool will go by using any geometry to snap the scaling action.
              In your case, you could, for example, add a guide or a line or whatever at the specified offset distance that you want and then use this guide or line or whatever to controll the scaling action.
              Of course, you may need to do this on all 3 axes one by one. You could use the symmetric scaling capability of SU to do only 3 scaling actions instead of 6.
              Just ideas.
              • X Offline
                xrok1
                you could of course simply use fredoscale. his scaling and stretching tools have all the functions you seek and a few more.
                http://forums.sketchucation.com/viewtopic.php?f=323&t=17948&st=0&sk=t&sd=a&hilit=fredoscale
                  agamemnus
                  @tig said:
                  agememnus
                  I wanted to add a certain height/width/length, instead of setting it to a particular size that I knew in advance.
                  xrok1, I'll keep looking at fredoscale but I find I have to constantly remove it because it disables grouping, rotating and flipping for some objects.
                    You must usually have some idea of the dimension you require 'in advance' ?
                    If so, then enter it in the NNNunits format; if not then you must want it to match up to something already in the model - so use Jean L's ideas of snapping the scaling to some existing geometry [with inferences etc] or perhaps to some guide-geometry that you could have drawn beforehand to suit... if it's neither of the above then how are you to make it any meaningful 'size' ?... then can only scale it dragging a handle 'by eye' ??
                      agamemnus
                      Well, usually but not always.
                      I'll try to rephrase... this tool would work like so: whatever the size is, add X meters to it. Even if I knew the original size, I would have to add! Just adding one mesh is not so bad, but if I have several meshes that I want to resize by some amount it gets more tedious.
                        Use the Tapemeasure tool to make a guide-point offset along the axis from the things to be 'enlarged' by the required amount - say 500mm - copy it to several things that you want to Scale.
                        Make other guide-points at other offsets as needed...
                        Scale each of the things using these guide-markers to snap to.
                        Every 'thing' has been scaled by that fixed amount.
                        In this example you could have selected all of the top faces [hold Ctrl to add to selection] and simply 'Move' them up in the Z by 500mm [constrain in axis by holding Shift]... BUT on more complex shapes Scaling will give different results...
                          agamemnus
                          Oh, of course! Thanks.
                          Would be interesting, though, if you could just do something like +5m in the Scale tool and it would do the same thing.
                          BTW, while we're on the subject, I am having trouble inserting a value when I "scale on all sides" (CTRL+scale): typing a number doesn't work.. what's going on there?
                            You are falling it the Scaling Pythagoras Trap !
                            When you scale from the center on a diagonal and type in a scale value it scales the XYZ sides to match, but when you type in a dimension it sets the size of the diagonal, not the XYZ sides size.
                            So for example if you have a 1m cube and use Scale+Ctrl and type in 500mm the cube scales about its center so that the diagonal is now 500mm long - if you wanted the sides to be 500mm long you should have typed 0.5...
                            You need to do a bit of pre-planning and work out the ratio first NewSize/OldSize = scale_factor - here 500mm/1000mm=0.5.
                            Entering a dimension is pretty impractical in this type of scaling unless you do want the diagonal to become a set length...
                            Alternatively use the uniform Scale + Ctrl with a side handle and the modifier 'Shift' key and type 500mm to make all edges 500mm, scaling from the center ???
                              For this reason I do not even use the diagonal scaling (well, unless I want to do some quick and dirty operation). The side grips are much more easy to work with - just use the mod keys to scale uniformly and such.
                                agamemnus
                                Yes yes, I usually use a scaling factor when I do this, so it's not a problem...My problem is that I CAN'T type a number when I press and hold CTRL (or CTRL+SHIFT)!
                                  Don't then. Start the operation with these mod keys - then release them, type your value and hit Enter without ever touching them again. SU is smart enough to remember what you are up to!
                                    I can type it in - perhaps I release ctrl/shift as I do it and then re-press ?
                                    I'm on PC what's yours ?
                                    • X Offline
                                      xrok1
                                      do your second click (or release mouse button, depending which way you work) to end the scaling, then type your values and SU will adjust accordingly even though you ended the operation. its like drawing a line; then entering length, doesn't matter that its already done SU will resize it. 😉
                                        Now is that a question Rocky or a statement?
                                        Please, note that my English is really bad and it's 22:30 here already (and I did not sleep last night)
                                        • X Offline
                                          xrok1
                                          its a fact, jack. 😉 try it
                                            Then it seems to be the same as what I wrote above.
