    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    Color to Image texture?
    7 Posts 5 Posters 1.2k Views 5 Watching
      Jim
      I don't suppose there exists a plugin to take an in-model (solid) color material, make an external image file of the same color, then use that image and replace the in-model color with the texture material?
      • X Offline
        xrok1
        you can right click a colored (painted) face and select make unique texture, it will ask what size image you want ie. 1024x768. i'm not sure where SU saves the corresponding image file though. anyone know?
        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
        • X Offline
          xrok1
          ah, here we go right click on it here, then save where ever you want. of course you have to right click the face and select make unique texture first.
            You can easily get the material's color's RGB.
            You then need to write a png file with those values.
            Import it in as a texture for that material...
            There are image writing modules for Ruby with stuff like GD2 ?
            ๐Ÿ˜•
            • Chris FullmerC Offline
              It is available as built in tool of SketchUp. But it is not expoed in the API. So I don't think a plugin exists. But you can do it natively. Just right click on a single face with a color material applied to it. And choose "Make Unique Texture". That turns it into an image material. Then you can open it in photoshop.
              • X Offline
                xrok1
                ๐Ÿ˜ณ sorry if this was a coding question.
                  ๐Ÿ˜•
                  PNG files are not trivial to deal with. If anyone are knows of a lightweight lib to use with SU Ruby then I'd be very interested.
                  I just wrote my own BMP reader for a plugin I'm working on. A BMP writer would be easy - but the downside is the filesize... ๐Ÿ˜•
