    Estudio Nómada v6
    19 Posts 8 Posters 1.2k Views 8 Watching
    • artysmediaA Offline
      artysmedia
      A new building that i'm constructing on Google SketchUp:
      http://farm3.static.flickr.com/2709/4415881231_f21655ee17_o.jpg
      Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
      Blog: Artysmedia
        artysmedia
        Estudio Nómada 002 v6
        Sección derecha - Right Section
        http://farm3.static.flickr.com/2699/4415881313_aca062d214_o.jpg
        Blog: Artysmedia
          artysmedia
          Two more steps on the air:
          http://farm5.static.flickr.com/4020/4415881385_e91e1a4e8d_o.jpg
          http://farm5.static.flickr.com/4008/4416074969_5b648cb985_o.jpg
          Blog: Artysmedia
            artysmedia
            And here we have the railing
            http://farm5.static.flickr.com/4047/4416075099_762477837c_o.jpg
            Blog: Artysmedia
            • 2 Offline
              21D
              Great design and modeling... but that to be expected now from you mate... always amazed on the level of modeling you've got 👍 😄
              "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
              Le Corbusier
                artysmedia
                but but but, it is only a simple model 😆
                Blog: Artysmedia
                  KXI System
                  Then what would you call you Hole series? Normal? 😆
                  I would like to see you model a complex model!
                  Getting the perfect sig is hard...
                  Google it!
                    artysmedia
                    I think i have made some of them! 😄
                    Addind some details...
                    http://farm5.static.flickr.com/4039/4421442511_d512c69a5e_o.jpg
                    After that, i will change the angle of the camera, add some more details and start to color-texture
                    Blog: Artysmedia
                      artysmedia
                      Hello all!
                      A little update today... I have changed the camera position and started to put colored-materials.
                      http://farm3.static.flickr.com/2769/4422208944_f5f8aedb27_o.jpg
                      See you next week!
                      Blog: Artysmedia
                        artysmedia
                        Finishig to put the materials in the model...
                        http://farm5.static.flickr.com/4024/4438683564_d9b793b90c_o.jpg
                        Blog: Artysmedia
                          artysmedia
                          There is the final image. On monday i will put the original image of the magazine so you can compare... 😉
                          http://farm5.static.flickr.com/4059/4445303954_f70b0c68a7_o.jpg
                          Blog: Artysmedia
                            artysmedia
                            Original image
                            http://farm3.static.flickr.com/2692/4446730157_f75c6fd539_b.jpg
                            Blog: Artysmedia
                            • olisheaO Offline
                              olishea
                              wow artys, very close indeed!!
                              I would suggest more vartiation in teh timbers (could do this in photoshop quite easily) and add some age. the cobbles especially could benefit from this, also the streaks to the timber facade.....great work though. those cobbles must have been a nightmare!! whats with the blur?
                              oli
                                sketchup_fan
                                I love it!!!
                                  jopsa2
                                  wow artys, an interesting exercise! did you use photo match at all, for the modelling?
                                  also about the cobbled road, did you place the stones manually? it looks very tiring, I would have thrown a displacement map on it! wouldnt have looked as good obviously 😛
                                  • massimoM Offline
                                    massimo Moderator
                                    Roberto, would you try with this texture I've made? Perhaps you can change the color and add some straining and a bit of dirt in photoshop. Nice work so far.😄
                                      artysmedia
                                      I have used 11 different textures for the timbers. The facade is not a plane. Each wooden plank was modeled independently.
                                      Yeah the cobbles aren't great! 😢
                                      Yeah!
                                      It is a simple gaussian with a mask.
                                      I have never used photo match, sorry
                                      Yes. in the end I was tempted to put a displacement map
                                      Thanks for the txeture, but i think it is too little. All of the wooden planks are larger than you texture but maybe i will make a try later
                                      Thanks to all!
                                      Blog: Artysmedia
                                        ScottPara
                                        Artys,
                                        Nice work indeed. I like how you even went ahead and made it into a magazine cover to match the original.
                                        You did miss a groove in the right side of the structure near the door. One thing that I notice is that your windows are not recessed as much as the original structure. The wall on the far left of the image has a gap too large from the original image. I am not sure if there was supposed to be cables on that side to match the side with the cobblestones but I can not see the cables. A little weathering to the structure would help too. Like olishea said this could easily be done in post with photoshop.
                                        All in all really nice work and a good example that projecting textures on to a box will never come close to good modeling.
                                        Scott
                                        Love the fact that some HATE my avatar.....
                                          artysmedia
                                          Thanks for the critiques. I will see if i can find time to fix some errors. 😄
                                          I'm not so sure about that, Scott 😕
                                          Blog: Artysmedia
