    Estudio Nómada v6
    19 Posts 8 Posters 1.6k Views 8 Watching
    • artysmediaA Offline
      artysmedia
      Finishig to put the materials in the model...
      http://farm5.static.flickr.com/4024/4438683564_d9b793b90c_o.jpg
      Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
      Blog: Artysmedia
        artysmedia
        There is the final image. On monday i will put the original image of the magazine so you can compare... 😉
        http://farm5.static.flickr.com/4059/4445303954_f70b0c68a7_o.jpg
        Blog: Artysmedia
          artysmedia
          Original image
          http://farm3.static.flickr.com/2692/4446730157_f75c6fd539_b.jpg
          Blog: Artysmedia
          • olisheaO Offline
            olishea
            wow artys, very close indeed!!
            I would suggest more vartiation in teh timbers (could do this in photoshop quite easily) and add some age. the cobbles especially could benefit from this, also the streaks to the timber facade.....great work though. those cobbles must have been a nightmare!! whats with the blur?
            oli
              sketchup_fan
              I love it!!!
                jopsa2
                wow artys, an interesting exercise! did you use photo match at all, for the modelling?
                also about the cobbled road, did you place the stones manually? it looks very tiring, I would have thrown a displacement map on it! wouldnt have looked as good obviously 😛
                • massimoM Offline
                  massimo Moderator
                  Roberto, would you try with this texture I've made? Perhaps you can change the color and add some straining and a bit of dirt in photoshop. Nice work so far.😄
                    artysmedia
                    I have used 11 different textures for the timbers. The facade is not a plane. Each wooden plank was modeled independently.
                    Yeah the cobbles aren't great! 😢
                    Yeah!
                    It is a simple gaussian with a mask.
                    I have never used photo match, sorry
                    Yes. in the end I was tempted to put a displacement map
                    Thanks for the txeture, but i think it is too little. All of the wooden planks are larger than you texture but maybe i will make a try later
                    Thanks to all!
                    Blog: Artysmedia
                      ScottPara
                      Artys,
                      Nice work indeed. I like how you even went ahead and made it into a magazine cover to match the original.
                      You did miss a groove in the right side of the structure near the door. One thing that I notice is that your windows are not recessed as much as the original structure. The wall on the far left of the image has a gap too large from the original image. I am not sure if there was supposed to be cables on that side to match the side with the cobblestones but I can not see the cables. A little weathering to the structure would help too. Like olishea said this could easily be done in post with photoshop.
                      All in all really nice work and a good example that projecting textures on to a box will never come close to good modeling.
                      Scott
                      Love the fact that some HATE my avatar.....
                        artysmedia
                        Thanks for the critiques. I will see if i can find time to fix some errors. 😄
                        I'm not so sure about that, Scott 😕
                        Blog: Artysmedia
