    [Plugin] Center of Gravity
    183 Posts 41 Posters 317.6k Views 41 Watching
      driven
      it is in the db method,
      I just ran composite on to groups and got this
      Error; #<NoMethodError; undefined method `db' for CofGravity;Class>
      /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/CofGravity.rb;604;in `composite'
      /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/CofGravity.rb;817
        chrisjk
        TIG,
        Sorry for the earlier abbreviated message - I got called away from the computer.
        I get the following when trying CofG (Version 1.4 here).
        QUOTE
        Error: #<NoMethodError: undefined method db' for CofGravity:Class> /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/CofGravity.rb:156:in do_calculation'
        /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/CofGravity.rb:816
        UNQUOTE
          chrisjk
          Possibly something to do with the version of Ruby? Macs running Snow Leopard come with a pre-packaged version 1.8.7 of Ruby.
            The error is with the db def method... BUT it ha been and is still working fine on PCs and it's been used in similar ways in many other tools... so why the problem here ?
            To avoid having to add deBabelizer(string, lingvo_file_path) to every string in the output that needs translating I make a shortcut method def db for each tool
            that alls deBabelizer and has the lingvo_file_path hardcoded into it, and works simply as db(string).
            It's easy and effective in all my recent tools, so why the problem here ???
            It's clear now that it wasn't the missed out 'require' or other possible clashes that were causing this... BUT why it's not working is a mystery... 😢 😳 ❓ 🎉
            Surely you can call a def inside another def though ??? even with 1.8.7 on Macs ???
              DSG2k
              I had checked for any evidence of Vista stupidity given past experience with having to look at the Virtual Store. But I've tried v. 1.4 and it works great!
              Thank you so much for your incredible plugins. I'm using them for sci-fi mesh analysis and they are invaluable.
                Seems to work fine on PC but on Mac it falls over... I WILL find a solution... 😒
                  driven
                  I'll try it on an sterile Mac i.e. just on it's own, see what happens, give me five minutes
                    driven
                    Same error when v1.4 + debabelizer are the only rubies installed
                      TIG,
                      It's not all Macs that have problems, though. It works just fine on mine. Could it be another plugin or something?
                        As I suspected 😞 😢
                        I'll sleep on it... and see how I can devise a work around in my sleep...
                        PC works fine - come on Mac's what's up with you !!! ❓
                        Is it a particular version of Mac OS and the Ruby version that they have ??? 😕
                          driven
                          well, mine are
                          both running SU 7.1
                          both running OSX 10.5.8
                          both running Ruby version 1.8.6
                          MacBookPro is a fresh SU instal with just v1.4 bits
                          iMac is littered with rubies but very few clashes are left roaming free, it is also running rubygems, but that doesn't seem to effect any thing else in SU
                          both give same error
                            Must be something wrong with my Mac, then.
                              driven
                              yeh, you sure it's not a PC....
                                Very funny. 😒 I have both and I know the difference.
                                Here's proof that it works on my Mac.
                                http://farm5.static.flickr.com/4011/4418553314_f02f513736.jpg
                                • wind-borneW Offline
                                  wind-borne
                                  works ok on my Mac but TIG Tools folder replaced existing one so extrusion toolbar icons disappeared. I see missing icons on Dave's screenshot also.
                                  "To read between the lines was easier than to follow the text."OSX 10.11.6
                                  %(#BF80BF)[SU 8 pro
                                    chrisjk
                                    Most mysterious. I have tried with no other plugins or tools in the respective folders and using CofG version 1.4 I still get:-
                                    /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/CofGravity.rb;156;in `do_calculation'
                                    /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/CofGravity.rb;816
                                    /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/CofGravity.rb;156;in `call'
                                      "Merge" the folders so that the other existing files are kept - just overwrite any files for that specific tool...
                                        Thanks for noticing that Wind-Borne and thank you TIG for the fix.
                                          pedromarmol
                                          I have translated the plugin to Spanish language, bottom i put de link for download. I see that other Mac's users have the plugin working fine, to me no works, i use Sketchup 7.1 in Mac OSX Snow Leopard 10.6.2 and the last version of the plugin CofG_1.4, i have tried run sketchup with CofG in the plugins folder only, and don't works, SU read the plugin, i see the plugin (in spanish) in plugins Menu but don't works.
                                          When i run the plugin this message appears in Ruby Console:
                                          Error: #<NoMethodError: undefined method db' for CofGravity:Class> /Users/Oxer/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/CofGravity.rb:156:in do_calculation'
                                          /Users/Oxer/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/CofGravity.rb:816
                                          /Users/Oxer/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/CofGravity.rb:156:in `call'
                                          EDIT: Script Removed. SketchUcation forum policy does not permit people to post scripts they did not write. Please obtain permission from the author first, thanks!
                                            Pedro
                                            We have been PMing about this - the Mac db glitch is known and driven and I are trying to track it down.
                                            Please PM me the CofG ES lingvo file and I'll publish it with acknowledgment of your input - hopefully with a fix for this Mac/Ruby glitch...
                                            • 3 / 10
