    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    [Plugin] Center of Gravity
    183 Posts 41 Posters 297.6k Views 41 Watching
      No problem i can make the Xray mode by hands ๐Ÿ˜‰
      Another thing
      Seems "Composite mode" don't works for me ๐Ÿ˜ฎ
      object goup 1(without CoF), object goup 2(without CoF),
      group 3 = Group1 + Group 2
      Find Cof for group3 ok โ˜€
      object goup 1(with CoF), object goup 2(with CoF)
      Composite group 3 not Ok ๐Ÿ˜ž
      What I miss?
        with different densities
        haaaaaaaa โ˜€
        THX! ๐Ÿ˜Ž
          chrisjk
          I can't seem to get it to do anything on a Mac..
            Please explain a little more...
            What can't you get to work ?
            Open the Window > Ruby Console.
            Select a group or component instance that has a volume - we are trying to find it's C of G !
            Run the tool and answer the dialog's questions...
            What happens / doesn't happen ?
            What are the messages if any in the Ruby Console...
            There is nothing different between a PC and a Mac for this tool [except 'PEBCAK' ๐Ÿ˜‰ ]
              driven
              Error: #<NoMethodError: undefined method db' for CofGravity:Class> /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/CofGravity.rb:153:in calculate'
              /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/CofGravity.rb:813
                I just installed it on my MacBook and tried running it. It worked fine for me. Thank you TIG.
                  Have you got deBabelizer.rb in the Plugins Folder ?
                  This file is for translation and is used by many of my tools and it ships with each of them - although it's always the same file...
                  It should come with the zip and is installed into the same folder as CofGravity.rb ?
                  The error is because 'db' which is the local def of deBableizer in the class is failing to get defined...
                  ๐Ÿ˜•
                    driven
                    @tig said:
                    Have you got deBabelizer.rb in the Plugins Folder ? :?
                    Hi Tig,
                    I only installed it to send you a report from another Mac, and am sure I used all of the correct instal procedures.
                    your other tools are still working (EEby.., Manifold, Vol..2) , after the CofG_1.2 instal (including deBalelizer.rb)
                    after the first (_1.2) Error, I replaced both files with the _1.1 files and had the same error.
                    I then tested all in the same drawing
                    EEby Rail--worked
                    Volume2 --worked
                    Manifold --worked
                    CofG --same error report (-1.2 re-installed from zip)
                      driven
                      A mystery... ๐Ÿ˜• ๐Ÿ˜’
                      def CofGravity;;calculate ### LINE 129 ==start of class/def that is reporting the error...
                      def db(string)
                        dir=File.dirname(__FILE__)+"/TIGtools"
                        toolname="CofGravity"
                        locale=Sketchup.get_locale.upcase
                        path=dir+"/"+toolname+locale+".lingvo"
                        if not File.exist?(path)
                          return string
                        else
                          deBabelizer(string,path)
                      end#db
                      if (Sketchup.version.split(".")[0].to_i<5)
                           UI.messagebox(db("C of G; Sorry, this is Version >= 6 Tool !"))
                           return nil
                      end#if
                      model=Sketchup.active_model
                      entities=model.active_entities
                      if Sketchup.version[0,1].to_i > 6
                        model.start_operation((db("C of G")),true)### LINE 153 GIVES ERROR !!!
                      Can you look at the script's contents and see if it looks like this ?
                      Works fine on a PC for me - can't see where a Mac might trip up ?
                      โ“ โ“ โ“
                        Jim
                        Need to require 'dBabelizer' before you use it.
                          Jim
                          That's it ! Thanks.
                          Other tools requiring it were masking the fact I missed it out of the initial 'require'... ๐Ÿ˜’
                          Update on it's way !!!
                            driven
                            that appears exactly the same,
                            the only thing that seems at odds is the syntax colouring for calculate shows it as a variable??
                            I don't know enough to know why, or where to look next
                            this is odd...
                            I'll send this even if the missing "require" is at fault, because I don't understand why one and not the other would be a variable....
                              Here's v1.3...
                              http://forums.sketchucation.com/viewtopic.php?p=229404#p229404
                              The initial 'require' of deBabelizer was accidentally missed out, but its absence was masked by some other tools loading it anyway so most times it worked anyway...
                              Now it is explicitly called for in the tool... ๐Ÿ˜’
                              Sorry for the confusion...
                                driven
                                Same error code, same syntax colouring for line 813
                                seems to have something to do with it...
                                  driven
                                  Have you got the recent v1.3, with the require 'deBabelizer.rb' added ?
                                  This should fix it ?
                                    If calculate is a reserved term in Mac Ruby versus PC I'm surprised...
                                    You can edit the file and change every ' calculate' to say ' do_calculation' and see if that helps - if so let me know asap ๐Ÿ˜• ๐Ÿ˜• ๐Ÿ˜•
                                      driven
                                      Yes it's v1.3
                                      changed to tig_calculate (lines 131, 815)
                                      Error; #<NoMethodError; undefined method `db' for CofGravity;Class>
                                      /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/CofGravity.rb;155;in `calculate'
                                      /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/CofGravity.rb;815
                                      but the colour changed
                                        @driven said:
                                        Yes it's v1.3
                                        You mustn't have changed them all as it's still calling 'calculate' ?
                                        I've redone the original and v1.4 with full 'do_calculation' will be there asap...
                                          Here's v1.4 http://forums.sketchucation.com/viewtopic.php?p=229401#p229401 with 'calculate' replaced with 'do_calculation' to see if that fixes it - if not I have exhausted all ideas so far !!!
                                            driven
                                            Ok, v1.4
                                            /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/CofGravity.rb;156;in `do_calculation'
                                            /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/CofGravity.rb;816
                                            sorry
                                            • 10 / 10
