    [Plugin] Center of Gravity
    183 Posts 41 Posters 328.3k Views 41 Watching
      Have you got a file called deBabelizer.rb in the Plugins folder.
      If not then please put a copy of it in there***.
      You must extract all of the files and sub-folders in a zip file keeping their sub-folders etc.
      A good unzip application will do that for you.
      Moving files manually leads to problems as they end up in the wrong place.
      Unzipping directly into Plugins can cause problems as files seemingly overwritten are not !***
      With Vista you are probably best firstly extracting everything into a folder on your Desktop [e.g. 'CofG_1.1'] and then use copy/paste on all of that folder's contents [unchanged], en mass into the Plugins folder...
      ***You are on Vista so I suspect you have some access-right problems with your Plugins folder ๐Ÿ˜’ โ“
      The dreaded 'compatibility files' issue - it looks like you put the file into the folder but Vista 'protects you' by putting it into a parallel 'compatibility folder' so you don't actually get to find it, load it etc as it's not really there...
      So I recommend you change the access-rights to the folder [properties] so you can write to it without problems...
      The deBabelizer.rb file issued with all tools is the same file - you only need one copy in Plugins for any tool that uses it to load and to use it...
      ๐Ÿค“
        Hm. This is a very interesting piece of plugin, TIG; thanks!
        It immediately brings teaching into my mind - as how you can (for instance) explain the different vectors arising in a Gothic structure for instance. It would be (also) interesting to see how these centers of gravity can interact with each other after a structure is assembled.
          Why not put the Xray mode at the end of the process?
          Because we can't see the CofG when this one is inside a volume ๐Ÿ˜‰
          Pilou
            Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=229401#p229401
            with FR lingvo file by Pilou...
              Pilou
              You can't set Xray mode on your own ?
              Many want just the top SP for lifting, and the weight - so CofG is secondary...
              If you want it then you can Xray it...
              Sorry if I sound cranky... long week and tomorrow's Monday [aaargh!] ๐Ÿ˜‰
              *Vous ne pouvez pas dรฉfinir le mode Xray sur vos propres?
              Beaucoup veulent juste le SP haut pour le levage, et le poids - donc CofG est secondaire ...
              Si vous le souhaitez vous pouvez le Xray ...
              Dรฉsolรฉ si j'ai l'air grognon ... longue semaine et demain lundi [aaargh!];)*
                It came from a PM request for a tool to find the perfect lifting point for a delicate piece of restoration stonework...
                I added the composite tool to combine the CoG's and SP's of assembles of multiple or varying density units...
                Any more ideas welcome... ๐Ÿ˜•
                  'Composite C of G' is for use only on existing C of G elements - it's used to get a combined C of G for them.
                  If you have an assembly of parts that all have the same density then you can just make one group of all of them and find the C of G of that one group.
                  BUT if you have an assembly of parts of different densities you'll need to find the individual C of G's of each of them: then you select these C of G elements [only these, nothing else] and use the Composite C of G tool on them.
                  You only need to use the Composite C of G tool on the C of G's of parts with different densities that could unexpectedly relocate the assembly's C of G - 'off center' for example... Otherwise group and get the one C of G...
                    No problem i can make the Xray mode by hands ๐Ÿ˜‰
                    Another thing
                    Seems "Composite mode" don't works for me ๐Ÿ˜ฎ
                    object goup 1(without CoF), object goup 2(without CoF),
                    group 3 = Group1 + Group 2
                    Find Cof for group3 ok โ˜€
                    object goup 1(with CoF), object goup 2(with CoF)
                    Composite group 3 not Ok ๐Ÿ˜ž
                    What I miss?
                      haaaaaaaa โ˜€
                      THX! ๐Ÿ˜Ž
                        chrisjk
                        I can't seem to get it to do anything on a Mac..
                          Please explain a little more...
                          What can't you get to work ?
                          Open the Window > Ruby Console.
                          Select a group or component instance that has a volume - we are trying to find it's C of G !
                          Run the tool and answer the dialog's questions...
                          What happens / doesn't happen ?
                          What are the messages if any in the Ruby Console...
                          There is nothing different between a PC and a Mac for this tool [except 'PEBCAK' ๐Ÿ˜‰ ]
                            driven
                            Error: #<NoMethodError: undefined method db' for CofGravity:Class> /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/CofGravity.rb:153:in calculate'
                            /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/CofGravity.rb:813
                              I just installed it on my MacBook and tried running it. It worked fine for me. Thank you TIG.
                                Have you got deBabelizer.rb in the Plugins Folder ?
                                This file is for translation and is used by many of my tools and it ships with each of them - although it's always the same file...
                                It should come with the zip and is installed into the same folder as CofGravity.rb ?
                                The error is because 'db' which is the local def of deBableizer in the class is failing to get defined...
                                ๐Ÿ˜•
                                  driven
                                  @tig said:
                                  Have you got deBabelizer.rb in the Plugins Folder ? :?
                                  Hi Tig,
                                  I only installed it to send you a report from another Mac, and am sure I used all of the correct instal procedures.
                                  your other tools are still working (EEby.., Manifold, Vol..2) , after the CofG_1.2 instal (including deBalelizer.rb)
                                  after the first (_1.2) Error, I replaced both files with the _1.1 files and had the same error.
                                  I then tested all in the same drawing
                                  EEby Rail--worked
                                  Volume2 --worked
                                  Manifold --worked
                                  CofG --same error report (-1.2 re-installed from zip)
                                    driven
                                    A mystery... ๐Ÿ˜• ๐Ÿ˜’
                                    def CofGravity;;calculate ### LINE 129 ==start of class/def that is reporting the error...
                                    def db(string)
                                      dir=File.dirname(__FILE__)+"/TIGtools"
                                      toolname="CofGravity"
                                      locale=Sketchup.get_locale.upcase
                                      path=dir+"/"+toolname+locale+".lingvo"
                                      if not File.exist?(path)
                                        return string
                                      else
                                        deBabelizer(string,path)
                                    end#db
                                    if (Sketchup.version.split(".")[0].to_i<5)
                                         UI.messagebox(db("C of G; Sorry, this is Version >= 6 Tool !"))
                                         return nil
                                    end#if
                                    model=Sketchup.active_model
                                    entities=model.active_entities
                                    if Sketchup.version[0,1].to_i > 6
                                      model.start_operation((db("C of G")),true)### LINE 153 GIVES ERROR !!!
                                    Can you look at the script's contents and see if it looks like this ?
                                    Works fine on a PC for me - can't see where a Mac might trip up ?
                                    โ“ โ“ โ“
                                      Jim
                                      Need to require 'dBabelizer' before you use it.
                                        Jim
                                        That's it ! Thanks.
                                        Other tools requiring it were masking the fact I missed it out of the initial 'require'... ๐Ÿ˜’
                                        Update on it's way !!!
                                          driven
                                          that appears exactly the same,
                                          the only thing that seems at odds is the syntax colouring for calculate shows it as a variable??
                                          I don't know enough to know why, or where to look next
                                          this is odd...
                                          I'll send this even if the missing "require" is at fault, because I don't understand why one and not the other would be a variable....
                                            Here's v1.3...
                                            http://forums.sketchucation.com/viewtopic.php?p=229404#p229404
                                            The initial 'require' of deBabelizer was accidentally missed out, but its absence was masked by some other tools loading it anyway so most times it worked anyway...
                                            Now it is explicitly called for in the tool... ๐Ÿ˜’
                                            Sorry for the confusion...
                                            • 2 / 10
