    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Connect a face to face (bridge face plugin)
    14 Posts 5 Posters 6.4k Views 5 Watching
      jamma-pcb
      Hi all
      If any of you have tried wings3d there is an option (if limited option) to connect 2 faces to form a bridge.
      My problem is I am trying to connect a ArC face to a rectangular face. forming a automated bridge between them would be welcomed.
      Does anyone know of such a plugin?
      • TIGT Online
        Can you add a skp or graphic of exactly what you mean ?
          jamma-pcb
          File attached
          Those 2 faces joined together. Some kind of automated face to face bridge.
            jamma-pcb
            The right word would be morphed and joined together
            • TIGT Online
              You need my ExtrusionTools - in this forum.
              It includes ExtrudeEdgresByFaces
                jamma-pcb
                Perfect. Thanks
                  jamma-pcb
                  any urls to this plugin's zip file. thanks
                  • TIGT Online
                    Use the Forum's Search tool for TIG and Extrusion Tools ???
                    • EarthMoverE Offline
                      EarthMover
                      At the top of the plugins section of the forum there is a "stickied" thread (Plugin Forum Sticky Links) that allows you to search for plugins by Author. Look for TIG. Another one to consider would be Blend by Kirill. It will do exactly what you need as well.
                      Content Creator at Skapeup
                      • fredo6F Offline
                        @jamma-pcb said:
                        Hi all
                        The plugin is not yet available, but here is the intent:
                          jamma-pcb
                          please hurry it up
                          Great plugin looks good.
                          Has anyone got any instructions on TIGS plugin... just cant get it to work...
                            jamma-pcb
                            Hi fredo
                            I've tried all the other plugins in 7.1 and they are all glitchy and the results are far from clean.
                            Yours though is clean. It's exactly what I'm after.
                            Any date for release or a alpha version to try out... will report any bugs and glitches.
                              jamma-pcb
                              Are there any dot to dot plugins.
                              Highlight 2 object faces with exact same points then a plugin just to line connect and draw them all in and fill.
                              Something more along those lines would be more realiable.
                              Anyone?
                              • TIGT Online
                                Look here...
                                http://forums.sketchucation.com/viewtopic.php?p=226249#p226249
                                Run the tool - select the two faces and a rail [curve] as prompted...
                                The path must be a 'curve' - even if it's straight lines - use 'weld' to make these into a 'curve'.
                                Arcs, Circles and Beziers are made as curves but combinations of these or just simple 'lines' are not curves - so these need 'weld'ing...
                                ๐Ÿ˜•
