    Canopy
    10 Posts 4 Posters 727 Views 4 Watching
    • F Offline
      fhenaux
      Hi, Would anybody be able to give me any pointers on how to draw a canopy?
      I have attached an skp file of the canopy top I'm trying to draw, I can draw the out line ok but I can't seem to be able to create a flowing material face (if that makes sense!). I've tryed using the contours tool but this creates un-even surfaces.
      It also needs to be hollow!!!!
      Hope all that makes sense!!!
      Fred
      Canopy top
      • Rich O BrienR Online
        Tig's Extrude Tool Set should do the trick
        http://forums.sketchucation.com/viewtopic.php?f=323&t=25362&hilit=+plugin
        or you can just use the Extrude by Rails Plugin on its own
        http://forums.sketchucation.com/viewtopic.php?f=323&t=23662&hilit=plugin
        • massimoM Offline
          massimo Moderator
          Hi Fred, if you need something like the picture below, it's 2 min of work with SoapSkin&Bubble plugin.
          Canopy.skp
            dedmin
            Extrude Edges by Rails. Reduce the segments of the curves - the file is gonna be huge!
            Canopy-2.skp
            • F Offline
              fhenaux
              [attachment=0:3fsissi5]<!-- ia0 -->Clipboard-1.jpg<!-- ia0 -->[/attachment:3fsissi5]
              [attachment=1:3fsissi5]<!-- ia1 -->Canopy-2.skp<!-- ia1 -->[/attachment:3fsissi5]
              Hi, Thanks for the tips, where can I down load the extrude by rails plugin please?
              fred
                Read the first reply 😳
                • F Offline
                  fhenaux
                  Thank you, much appreciated for everyones help.
                  Thanks again
                  Fred
                  • F Offline
                    fhenaux
                    [attachment=0:3o6ouh6g]<!-- ia0 -->Clipboard-1.jpg<!-- ia0 -->[/attachment:3o6ouh6g]
                    [attachment=1:3o6ouh6g]<!-- ia1 -->Canopy-2.skp<!-- ia1 -->[/attachment:3o6ouh6g]
                    Hi, Thank you for the advice, could you please tell me how I can reduce the No. of segments of curves with out having to re-draw the canopy?
                    Fred
                      Double click your grouped geometry to edit it
                      select each curve one at a time and right click and select entity info
                      under segments you'll see 100 ,change that to 20 for example. Repeat fir each curve
                      • F Offline
                        fhenaux
                        Many thanks.
                        Fred
