    Street Project in London
    23 Posts 20 Posters 4.9k Views 20 Watching
      ScottPara
      That looks great. Very detailed. Nice work!
      Scott
      Love the fact that some HATE my avatar.....
      • artysmediaA Offline
        artysmedia
        A lot of work here. ๐Ÿ˜ฎ
        How many polygons are on SketchUp without the trees and cars? ๐Ÿ’š
        Is there a difference between the VRay for C4D and 3D Max as a result of the render?
        ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
        Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
        Blog: Artysmedia
        • ely862meE Offline
          ely862me
          ๐Ÿ˜ฒ
          Elisei (sketchupper)
          Come and See EliseiDesign
          • massimoM Offline
            massimo Moderator
            Great images and great work indeed! I especially like the balance of colors you obtained in renders. ๐Ÿ‘
              D-space
              Awesome work! ๐Ÿ‘
              Care to share more info on the SU to C4D to vray workflow.? ๐Ÿ˜‰
              http://blibestmentalt.no/54981
              • olisheaO Offline
                olishea
                best visuals ive seen in a long time! great work, great colour ๐Ÿ‘
                oli
                  Speaker
                  Excellent model! Love it ๐Ÿ˜„
                  http://www.youtube.com/user/latvietis1234
                  • dermotcollD Offline
                    dermotcoll
                    Simply fantastic - loved the second one - just drew me in completely.
                    When you burn your arse - you gotta sit on the blisters!!
                      spdesign
                      Awesome Work!
                      I'd also be interested in some tips from your workflow. It seems there isnt much discussion on Sketchup to c4d and vray for c4d on these forums compared to other software. Any help would be appreciated!
                        tonyc
                        excellent, very detail work
                        • daleD Offline
                          dale
                          Can you give us a little insight into how your dealing with model size? I'm sure your using groups and components, but are you relying on layers when you add the high poly vegitation, or are you working in completely separate files? What did you find as the biggest challenge, and how did you deal with it? Also wouldn't mind knowing you computer specs.
                          This amazing results from a large model. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                            choppir
                            wohww! Thanks for the replies guys!
                            Ok,
                            Artysmedia: Not sure, i have to look when my machine stopped rendering, but it is alot. I had to use proxies for all planting as this scene crashes instantly without it.... Rendered on a 8core machine,8 gig ram which was nessesary!
                            Not sure what you mean by your 2nd question?
                            D-space & spdesign: I chose the workflow of SU to C4D above max because it is so easy.
                            I learned max and I was quite frustrated when I saw the different workflow between the 2....Max is waaaayy to complicated. So here you can also see what is the best way to export your model to Cinema 4D: http://www.vrayforc4d.com/forum/showthread.php?t=5426&highlight=export+sketchup+model
                            Dale: I modelled all the different buildings on their own separate file, then the street with all the bits & pieces on ones file, then on the big file, I've imported all the models together....
                            I definitely used components.
                            What is very very important is to work on different layers, because it makes the exporting part easy and also good to work with.... I always layer my stuff in the correct layers so that my workflow is ultimately faster. Neglecting layering it, makes it hardly unbearable. I did ask somebody once to help me model, but because he did not really use layers I had to re-model everything.
                            I also group objects alot. That makes the texturing bit very easy.
                            So i don't have any plants in Sketch-up, but i use proxies in Cinema 4D.
                            hope this helps!
                            Feel free to ask, I'll be happy to help.
                            Cheers
                            choppir ๐Ÿ˜„
                            • FrederikF Offline
                              Frederik
                              Awesome...! Awesome...!
                              http://www.kerkythea.net/users/Frederik/Anim-Icons/praise.gif
                              Cheers
                              Kim Frederik
                                jopsa2
                                this is amazing!! shows the huge potential in sketchup, how many edges did you end up with?
                                also I notice in the clays that you modelled the lines on the street, I imagine it's so you only had one asphalt texture? very clever!
                                  choppir
                                  Hi Jopsa2: I just looked and without the plants it comes to 3995564 poligons......yeah so almost 4 million.
                                  The lines was modelled separately and yes the tarmac is one big texture i painted in Photoshop.
                                  Hope this helps.
                                  Choppir
                                    steelers05
                                    these are great. Its nice to see someone using SU along with another program other than max. good work
                                      tomislavm
                                      Looks great, thank You!
                                        kevsterman
                                        ๐Ÿ˜ฎ Absolutely amazing! If it wasn't for the clay models I would swear it they were photos. Amazing work!
                                        What was the reason for modelling this street? Is it an existing street or is it all made up?
                                        "Avoid keeping more than 3 items on your desk that you can't fit into your mouth."
                                          choppir
                                          Thanks kevsterman ๐Ÿ˜„
                                          It is existing, but the whole street will be refurbished ๐Ÿ˜„
                                          Here are some existing pictures. You will see they have already started building the School in the background of the 1st pic....
                                          Laters!
                                          choppir
                                            kostas_designer
                                            Really professional stuff ๐Ÿ‘
                                            Excellent work, mate!
