    Clear the Ruby Console with Win32 API?
    15 Posts 9 Posters 15.3k Views 9 Watching
    • tbdT
      tbd
      last time when I checked it didn't help much because the whole text will be back on the print/puts
      http://plugins.ro
      • Chris FullmerC
        Have you looked at Jim's plugin that doe this? I don't know about the prints/puts thing though. His plugin only works in 32bit, so it never quite worked for me. 😞
          awh crud! why on earth?!?
            So this means SU caches ALL the text? it doesn't append to the existing text, to completely rewrites it?? No wonder that thing is slow!
              looking at this again:
              After using WinDowse to clear the text:
              • if I click the command line textbox in the Ruby Console to bring up any old commands - then all the old stuff comes back
              • if I don't do that - and use a script that uses a puts statement - or type in a new command or blank line into the Ruby Console command line - then the old history doesn't come back any more.
                jessejames
                The Ruby console "As Is" needs to die a torturous and horrible death, and in its place, a new multi-line console "shining prince" (not IO! πŸ˜‰ ) would herald in the new era of scripting bliss!
                Always sleep with a loaded gun under your pillow!
                  After you have cleared the console why not have your code do an empty puts to help you ?
                    well - I have not written the code yet. I've only used WinDowse to poke about.
                    But yes - that would be a solution - if I now could work out how to do this from Ruby.
                      I have PM'd you clearConsole.rb that works OK - I didn't publish it here as I'm unsure where it came from - no accreditation in the header ?
                        Excellent TIG. πŸ‘
                        Now - if only we found the author so we could get this posted publicly...
                          Jim
                          morisdov compiled a small windows exe to clear the console. It is called using the system command. I use it, and like to have it around because I can also double-click it from my file manager and clear the console.
                          Error 404 (Not Found)!!1
                          (morisdov.googlepages.com)
                          (I was sure this was posted at morsidov's site, but it does not seem to be available now.)
                          • Al HartA
                            Al Hart
                            Here is a routine which should work.
                            If you have problems, let me know.
                            (Sometimes code I extract from larger projects only works because of other plugins I have loaded already)
                            • Place Win32API.so in the Plugins folder (I grabbed a copy from the ruby install and placed it there)
                            • place clear_ruby_console.rb in your Plugins folder.
                            • "Clear Ruby Console" should appear at the bottom of the Window drop-down menu after you start SketchUp
                            # you need Win32API.so in the Plugins folder for this to work.
                            # I grabbed a copy from the ruby install and placed it there
                            require 'Win32API'
                            def clear_ruby_console
                            	# Find a window called Ruby Console
                            	# (Note; if there is more than one, then this may not work)
                            	fw = Win32API.new("user32.dll", "FindWindow", ['P', 'P'], 'N')
                            	pw=fw.call(0, "Ruby Console")
                            	if (!pw)
                            		puts "Ruby Console not found"
                            		return
                            	end#if
                            	# get the text output window in the Ruby Console
                            	fw_ex = Win32API.new("user32.dll", "FindWindowEx", ['N', 'N', 'P', 'P'], 'N')
                            	h_text = fw_ex.call(pw, 0, "Edit", 0) # Text Input for Ruby Console
                            	if (!h_text)
                            		puts "Ruby Console text window not found"
                            		return
                            	end#if
                            	# get the output window
                            	h_output = fw_ex.call(pw, h_text, "Edit", 0) # Output for Ruby Console
                            	if (!h_output)
                            		puts "Ruby Console output window not found"
                            		return
                            	end#if
                            	# Clear the text in the ruby output
                            	# by sending it an empty string
                            	sm = Win32API.new("user32.dll", "SendMessage", ['N', 'N', 'N', 'P'], 'N')
                            	wm_settext = 0x000c # windows constant to set text
                            	sm.call(h_output, wm_settext, 0, "")
                            	#You can change this to whatever message you want to display
                            	#after the console is cleared.
                            	puts "--- Ruby Console Cleared ---"
                            end#def
                            # Add to Windows menu
                            if ( !$clear_console_loaded)
                               UI.menu("Window").add_item("Create Ruby Console") {clear_ruby_console}
                               $clear_console_loaded = true
                            Al Hart
                            IRender nXt from Render Plus
                            • F
                              filsaz
                              [attachment=0:2o2wyuvn]<!-- ia0 -->clear_ruby_console.rb<!-- ia0 -->[/attachment:2o2wyuvn]
                              > require 'Win32API'
                              > 	if (!pw)
                              > 		return
                              > 	end#if
                              > 	if (!h_text)
                              > 		return
                              > 	end#if
                              > 	if (!h_output)
                              > 		return
                              > 	end#if
                              > end#def
                              > end
                              Thanks, it works! And I learned something new (win32api calls) with this example of yours. Thanks!
                              Yet, be careful there... I am sure you know about this but, in ruby only "false" and "nil" evaluate to "false", "C language" NULL does not, so you need to test against 0(zero) instead of using the "not operator" on the return values, which are numbers and therefore using "not" always yield to false in ruby.
                                MartinRinehart
                                Clears input and output windows. Toggle output off and on to clear just output.
                                404 Not Found
                                (forums.sketchucation.com)
