Colours to illustrate range
Given a value within a given range range - say 0-100:
how would you return a colour between these colour ranges?
255, 000, 000 255, 255, 000 000, 255, 000 000, 255, 255 000, 000, 255Top (red) would be 100
Bottom (blue) would be 0I know I could get a result if I split the range into five segments and did a number of if-else statements. but is there a more efficient/cleaner method?
Five case/when statements with three nested case/whens seems the way ?
Unless you have a clever matrix manipulation way ? -
Maybe Color.blend would help shorten up the code to 4 states?
blue = Sketchup;;Color.new('blue') bluegreen = Sketchup;;Color.new(0, 255, 255) green = Sketchup;;Color.new('green') redgreen = Sketchup;;Color.new(255, 255, 0) red = Sketchup;;Color.new('red') # assuming v is (0..100) case v c = v / 100.0 when (0..25) color = blue.blend(bluegreen, c) when (25..50) color = bluegreen.blend(green, c) when (50..75) color = green.blend(redgreen, c) when (75..100) color = redgreen.blend(red, c) end -
` def test_clr(value = 45, max = 100, min = 0)
clr = []
clr << Sketchup::Color.new(255,0,0)
clr << Sketchup::Color.new(255,255,0)
clr << Sketchup::Color.new(0,255,0)
clr << Sketchup::Color.new(0,255,255)
clr << Sketchup::Color.new(0,0,255)n = value / ( (max - min) / 5.0 )
index = n.to_i
ratio = n - indexc1 = clr[index-1].blend(clr[index], ratio)
def` -
hm... fails when given the max value...
This works - with out of range recovery.
def test_clr(value = 45, max = 100, min = 0) clr = [] clr << Sketchup;;Color.new(255,0,0) clr << Sketchup;;Color.new(255,255,0) clr << Sketchup;;Color.new(0,255,0) clr << Sketchup;;Color.new(0,255,255) clr << Sketchup;;Color.new(0,0,255) clr << Sketchup;;Color.new(0,0,255) value = [min, value].max value = [max, value].min n = value / ( (max - min) / 5.0 ) index = n.to_i ratio = n - index c1 = clr[index-1].blend(clr[index], ratio) endBut a simple switch might still be neater...
And bugged when min is not 0. ... ok - I'm no making for an elegant solution. KISS calling?
Ok - This one is the final deal. Easily extendible with other colour ranged by changing the array.
def value_to_color(value = 0, max = 100, min = 0) # Colours to translate to. First is max, last is bottom. # NOTE; last must appear twice! clr = [] clr << Sketchup;;Color.new(255,0,0) clr << Sketchup;;Color.new(255,255,0) clr << Sketchup;;Color.new(0,255,0) clr << Sketchup;;Color.new(0,255,255) clr << Sketchup;;Color.new(0,0,255) clr << Sketchup;;Color.new(0,0,255) # Cap value to range. value = [min, value].max value = [max, value].min # Calculate what colours to blend between and the blending ratio. n = (value-min) / ( (max-min) / (clr.length-1.0) ) index = n.to_i ratio = n - index #puts [n, index, ratio] # DEBUG return clr[index-1].blend(clr[index], ratio) endSketchup.active_model.selection[0].material = value_to_color(30, 60, 20) -
weeeell, this is the really final deal! really!
def self.value_to_color(value = 0, max = 100, min = 0) # Colours to translate to. First is max, last is bottom. clr = [] clr << Sketchup;;Color.new(255,0,0) clr << Sketchup;;Color.new(255,255,0) clr << Sketchup;;Color.new(0,255,0) clr << Sketchup;;Color.new(0,255,255) clr << Sketchup;;Color.new(0,0,255) # Cap value to range. value = [min, value].max value = [max, value].min # Calculate what colours to blend between and the blending ratio. n = (value-min) / ( (max-min) / (clr.length-1.0) ) index1 = n.to_i index2 = [index1+1, clr.length-1].min ratio = n - index1 #puts [value, n, index, ratio].inspect # DEBUG return clr[index2].blend(clr[index1], ratio) endI had confused how the blend weighting worked. Fixed. +some cleaning up.
Very cool Thom, thanks for posting this. Its something that has crossed my mind recently. I'll be sure to look through your code,
I've got this snippet in a top secret little project I'm working (ok, well its top secret but I've shared it with quite a few other people, so its not that top secret). Anyhow, the code works great Thom, but I only just recently realized it does not cover the entire range of colors. To get it to come full swing back to red, one woul need to add the lines:
clr << Sketchup::Color.new(255,0,255) clr << Sketchup::Color.new(255,0,0)to the end of the other similar lines so that it adds the magenta color to the array and finally back to red. Then you have a true full spectrum represented in this lovely gradient.
Thanks again Thom!
