    Colours to illustrate range
    13 Posts 4 Posters 1.6k Views 4 Watching
      Jim
      Maybe Color.blend would help shorten up the code to 4 states?
      blue = Sketchup;;Color.new('blue')
      bluegreen = Sketchup;;Color.new(0, 255, 255)
      green = Sketchup;;Color.new('green')
      redgreen = Sketchup;;Color.new(255, 255, 0)
      red = Sketchup;;Color.new('red')
      # assuming v is (0..100)
      case v
      c = v / 100.0
      when (0..25)
        color = blue.blend(bluegreen, c)
      when (25..50)
        color = bluegreen.blend(green, c)
      when (50..75)
        color = green.blend(redgreen, c)
      when (75..100)
        color = redgreen.blend(red, c)
        ` def test_clr(value = 45, max = 100, min = 0)
        clr = []
        clr << Sketchup::Color.new(255,0,0)
        clr << Sketchup::Color.new(255,255,0)
        clr << Sketchup::Color.new(0,255,0)
        clr << Sketchup::Color.new(0,255,255)
        clr << Sketchup::Color.new(0,0,255)
        n = value / ( (max - min) / 5.0 )
        index = n.to_i
        ratio = n - index
        c1 = clr[index-1].blend(clr[index], ratio)
        def`
          hm... fails when given the max value... πŸ˜•
            This works - with out of range recovery.
            	clr = []
            	clr << Sketchup;;Color.new(255,0,0)
            	clr << Sketchup;;Color.new(255,255,0)
            	clr << Sketchup;;Color.new(0,255,0)
            	clr << Sketchup;;Color.new(0,255,255)
            	clr << Sketchup;;Color.new(0,0,255)
            	value = [min, value].max
            	value = [max, value].min
            	index = n.to_i
            	ratio = n - index
            But a simple switch might still be neater... πŸ˜•
              And bugged when min is not 0. ... ok - I'm no making for an elegant solution. KISS calling?
                Ok - This one is the final deal. Easily extendible with other colour ranged by changing the array.
                def value_to_color(value = 0, max = 100, min = 0)
                	# Colours to translate to. First is max, last is bottom.
                	# NOTE; last must appear twice!
                	clr = []
                	# Cap value to range.
                	# Calculate what colours to blend between and the blending ratio.
                	n = (value-min) / ( (max-min) / (clr.length-1.0) )
                	index = n.to_i
                	ratio = n - index
                	#puts [n, index, ratio] # DEBUG
                	return clr[index-1].blend(clr[index], ratio)
                Sketchup.active_model.selection[0].material = value_to_color(30, 60, 20)
                  weeeell, this is the really final deal! really!
                  def self.value_to_color(value = 0, max = 100, min = 0)
                  	clr = []
                  	index1 = n.to_i
                  	index2 = [index1+1, clr.length-1].min
                  	ratio = n - index1
                  	#puts [value, n, index, ratio].inspect # DEBUG
                  	return clr[index2].blend(clr[index1], ratio)
                  I had confused how the blend weighting worked. Fixed. +some cleaning up.
                  • Chris FullmerC
                    Very cool Thom, thanks for posting this. Its something that has crossed my mind recently. I'll be sure to look through your code,
                    • Chris FullmerC
                      I've got this snippet in a top secret little project I'm working (ok, well its top secret but I've shared it with quite a few other people, so its not that top secret). Anyhow, the code works great Thom, but I only just recently realized it does not cover the entire range of colors. To get it to come full swing back to red, one woul need to add the lines:
                      clr << Sketchup::Color.new(255,0,255) clr << Sketchup::Color.new(255,0,0)
                      to the end of the other similar lines so that it adds the magenta color to the array and finally back to red. Then you have a true full spectrum represented in this lovely gradient.
                      Thanks again Thom!
                        πŸ˜„
