    Colours to illustrate range
    13 Posts 4 Posters 1.6k Views 4 Watching
      @tig said:
      Five case/when statements with three nested case/whens seems the way ?
      That's the method I know I can do.
      @tig said:
      Unless you have a clever matrix manipulation way ?
      This is what I'm wondering is can be done.
      It's out of curiosity. Wondering if there's something to learn.
        Jim
        Maybe Color.blend would help shorten up the code to 4 states?
        blue = Sketchup;;Color.new('blue')
        bluegreen = Sketchup;;Color.new(0, 255, 255)
        green = Sketchup;;Color.new('green')
        redgreen = Sketchup;;Color.new(255, 255, 0)
        red = Sketchup;;Color.new('red')
        # assuming v is (0..100)
        case v
        c = v / 100.0
        when (0..25)
          color = blue.blend(bluegreen, c)
        when (25..50)
          color = bluegreen.blend(green, c)
        when (50..75)
          color = green.blend(redgreen, c)
        when (75..100)
          color = redgreen.blend(red, c)
          ` def test_clr(value = 45, max = 100, min = 0)
          clr = []
          clr << Sketchup::Color.new(255,0,0)
          clr << Sketchup::Color.new(255,255,0)
          clr << Sketchup::Color.new(0,255,0)
          clr << Sketchup::Color.new(0,255,255)
          clr << Sketchup::Color.new(0,0,255)
          n = value / ( (max - min) / 5.0 )
          index = n.to_i
          ratio = n - index
          c1 = clr[index-1].blend(clr[index], ratio)
          def`
            hm... fails when given the max value... πŸ˜•
              This works - with out of range recovery.
              	clr = []
              	clr << Sketchup;;Color.new(255,0,0)
              	clr << Sketchup;;Color.new(255,255,0)
              	clr << Sketchup;;Color.new(0,255,0)
              	clr << Sketchup;;Color.new(0,255,255)
              	clr << Sketchup;;Color.new(0,0,255)
              	value = [min, value].max
              	value = [max, value].min
              	index = n.to_i
              	ratio = n - index
              But a simple switch might still be neater... πŸ˜•
                And bugged when min is not 0. ... ok - I'm no making for an elegant solution. KISS calling?
                  Ok - This one is the final deal. Easily extendible with other colour ranged by changing the array.
                  def value_to_color(value = 0, max = 100, min = 0)
                  	# Colours to translate to. First is max, last is bottom.
                  	# NOTE; last must appear twice!
                  	clr = []
                  	# Cap value to range.
                  	# Calculate what colours to blend between and the blending ratio.
                  	n = (value-min) / ( (max-min) / (clr.length-1.0) )
                  	index = n.to_i
                  	ratio = n - index
                  	#puts [n, index, ratio] # DEBUG
                  	return clr[index-1].blend(clr[index], ratio)
                  Sketchup.active_model.selection[0].material = value_to_color(30, 60, 20)
                    weeeell, this is the really final deal! really!
                    def self.value_to_color(value = 0, max = 100, min = 0)
                    	clr = []
                    	index1 = n.to_i
                    	index2 = [index1+1, clr.length-1].min
                    	ratio = n - index1
                    	#puts [value, n, index, ratio].inspect # DEBUG
                    	return clr[index2].blend(clr[index1], ratio)
                    I had confused how the blend weighting worked. Fixed. +some cleaning up.
                    • Chris FullmerC
                      Very cool Thom, thanks for posting this. Its something that has crossed my mind recently. I'll be sure to look through your code,
                      • Chris FullmerC
                        I've got this snippet in a top secret little project I'm working (ok, well its top secret but I've shared it with quite a few other people, so its not that top secret). Anyhow, the code works great Thom, but I only just recently realized it does not cover the entire range of colors. To get it to come full swing back to red, one woul need to add the lines:
                        clr << Sketchup::Color.new(255,0,255) clr << Sketchup::Color.new(255,0,0)
                        to the end of the other similar lines so that it adds the magenta color to the array and finally back to red. Then you have a true full spectrum represented in this lovely gradient.
                        Thanks again Thom!
                          πŸ˜„
