    Drawing round objects
    4 Posts 3 Posters 463 Views 3 Watching
      merc
      I hope I can explain this.
      I can not seem to be able to draw a circle--pull it to make a cylinder--then reduce the diameter-pull it some more and increase the diameter.
      The final object should look like a pedestal,with a bowl on top.
      How do you do that?
      thanks
      Merc
        Use the PushPull +Ctrl key to split then Scale about center by +Ctrl and Offset top face to keep it flast as tanle top etc...
          merc
          Thanks TIG
          good instruction too.
          I followed each step and drew that.
          thanks
          How do I make the bowl round, without straight edges?
          http://i124.photobucket.com/albums/p25/merc68/Sketchup/drawingradii.jpg
          Merc
          • Jean LemireJ Offline
            Jean Lemire
            Hi folks.
            And a few ideas on how to do it a bit faster.
            Bowl on pedestal.skp
