    Calling Whaat and Fredo!! new MAC issues (SOLVED)
    94 Posts 19 Posters 28.2k Views 19 Watching
    • EdsonE
      Edson
      in fairness i must say that jeff's suggestion has worked for me. i moved all the plugins i had at the user level to the regular plugins folder and removed the extra plugins folder. so far all the plugins are working, even podium which originally installs itself at the user level and booltools.
      http://www.mahfuz.arq.br
      • T
        tfdesign
        I've bookmarked this thread, and I'm going to try shifting everything around after I've finished this church visualisation project. But, it all looks very promising, so thanks to everyone for putting all this time in- especially Jeff! πŸ˜„
        • W
          Whaat
          @chrisjk said:
          Jeff,
          I have tried installing Profile Builder as you suggest but to no avail - it is not to be seen. The manual makes explicit mention of this "The plugin may NOT work if installed to the following directory: Macintosh HD/Library/Application Support/Google Sketchup 6/SketchUp/Plugins" and although I am using SU7.1 (5803) rather than the version 6 mentioned by WHAAT,it makes no difference. The other plugins you mention will work in either place albeit missing some toolbars/icons or actual tools as in the case of Fredo's BZ tools.
          The key word above is 'may'. The plugin will work if put in the standard HD plugin location (as long as there is no User/plugin folder). At the time I wrote the manual, the best workaround I could think of for this problem was to require all users to install Profile Builder to the Users subfolder.
          Since then, I have found the solution to this problem which was been discussed at length here. The problem is related to the Sketchup.find_support_file("Plugins") method which will not return the HD subfolder if there exists a Users plugins subfolder (I never determined if it was related to the OS version or not...)
          The solution I have found is to not use this method unless you also specify the desired subfolder. For example, if you say Sketchup.find_support_file("Plugins\/ProfileBuilder"), it will return the ProfileBuilder subfolder regardless of where it is installed (as long as it's in one of the $: locations)
          I intend to update ProfileBuilder, SDS, and BoolTools with this fix but I have been dragging my heels a bit (sorry for this...)
          So, to summarize, all my plugins should work if you install them in the standard HD plugins subfolder. However, if you run into a conflict with Podium, put the plugin in the Users plugins subfolder.
            Would be interesting to hear what Sketchup.find_support_file("Plugins") returns on Edison's 10.5 system. As on my 10.4 system it still returned the HD path after installing Podium.
            • EdsonE
              Edson
              /Library/Application Support/Google SketchUp 7/SketchUp/Plugins
              note: i have now all my plugins at the hd level.
                Ah. Then we need someone else with 10.5/10.6 and User plugins folder to test this.
                • cmeedC
                  cmeed
                  Can I say a huge Thank you to all those people who have helped this problem go away. I have no user level plugins folder now and everything seems to work. THANK YOU!
                    Jim
                    Holy carp, so Sketchup.find_support_file is not portable?
                    Does that mean I need to look at all the locations stored in $LOAD_PATH to be sure?
                    It does explain some blank toolbar image problems I have on the Mac.
                      If you use that to get the path of your own plugin - use File.dirname(__FILE__) instead. Or possilby File.dirname( File.realpath(__FILE__) ).
                      To find other plugins: yes I think you do.
                        Jim
                        Yes, but File.dirname(__FILE__) does not return a valid path when used in an encrypted file.
                        What is File.realpath?
                          @jim said:
                          Yes, but File.dirname(FILE) does not return a valid path when used in an encrypted file.
                          Really? Never used encrypted files. What do you get in return then?
                          Sorry, I mixed up with PHP. 😳 I meant File.expand_path http://ruby-doc.org/core/classes/File.html#M002540
                          Reason you might want to use that is explained here: http://forums.sketchucation.com/viewtopic.php?f=180&t=26040&st=0&sk=t&sd=a#p224558
                            Jim
                            The File:
                            print "*** file1.rb being loaded..."
                            print __FILE__
                            print File.dirname(__FILE__)
                            print File.dirname(File.expand_path(__FILE__))
                            print "*** Done."
                            Output when not scrambled:
                            c;/Program Files/Google/Google Sketchup 7/Plugins/file1.rb
                            *** Done.
                            Output when scrambled: No idea why the podium path is in there?
                            (eval)
                            c;/Program Files/Google/Google Sketchup 7/Plugins/SU_Podium_V2/plug_in/extensions
                            *** Done.
                              eh? Now that's odd!
                                driven
                                sorry if I'm interupting
                                May not be related, I'm new to ruby scripting, but in trying to figure out why I sometimes have blank tool buttons, I have noticed a couple of things.
                                if I load a sphere_tool.rb from WebConsole I don't get the icon, but the ruby works
                                if I use a full 'load' call from WC to Ruby Console using a "Plugins" I get the large icon or "plugins" I get the small icon,
                                the other thing is they just add into the existing unless I restart in between.
                                In other cases, depending on the path in the .rb I'm calling, the blank button may or may not work from WC or ConsoleEditor. even if it works load though ruby Console or place in plugins folder. I'll keep tabs on the path in future, to see if it's a type of path causing the issue.
                                Spare non functional buttons (like I get with TIG's EE toolbar) only appear (on re-start) if left open and horizontal on close, but they go away when moved vertical down a left side
                                I don't know why or how I'm just poking around to try and learn something...
                                For what I've been playing around with this seems to be the most reliable path...
                                @str = Sketchup.get_resource_path("")
                                are there problems with me using that if I want to share what I make?
                                observations...
                                • tbdT
                                  tbd
                                  even if I am not anymore involved in Podium 2 development, I will take a look tomorrow when I get back on my Windows machine.
                                  http://plugins.ro
                                  • T
                                    tfdesign
                                    Thank you TBD. That's very decent of you. πŸ˜„
                                    • tbdT
                                      tbd
                                      regarding v2 "odd" behaviour when running scrambled scripts - as .rbs are executed dynamically the FILE returns "." (current directory) which is changed by Podium v2 (renderer.rb) via Dir.chdir.
                                      that's why File.expand_path(FILE) returns .../SU_Podium_V2/plug_in/extensions path
                                      you can try this code:
                                      Dir.chdir "c;/"
                                      puts "*** file1.rb being loaded..."
                                      puts __FILE__
                                      puts File.dirname(__FILE__)
                                      puts File.dirname(File.expand_path(__FILE__))
                                      puts "*** Done."
                                      and you will get back:
                                      (eval)
                                      c;/
                                      *** Done.
                                      http://plugins.ro
                                        dylan
                                        I missed this thread.
                                        Fantastic piece of info about moving rubies and deleting the User level plugins folder on the Mac.
                                        That extra folder has been a pain with rubies in the past.
                                        http://dmdarchitecture.co.uk/
                                          rbrown3rd
                                          Hello everyone. I am a relatively new Sketchup user using a MAC with OSX 10.58 and Sketchup 7.1.6859. I openly admit to be totally lost as to how to install the Bezier Curve plugin. Reading all of this thread has me totally lost. I am running some tools I added for generating CNC files for a foam cutting machine. I am pretty sure I installed those a long time ago as .rb files. Would someone please tell me the easiest way to get a spline tool installed? I need to create some airfoil designs. Thank you very much.
                                          • EdsonE
                                            Edson
                                            do as it was suggested:
                                            1. move everything you have in the plugins folder at the user level to the plugins folder to be found at the system level.
                                            2. delete the plugins folder at the user level
                                            3. from now on install all plugins at the HD level.
                                              User level map
                                              levelHd  map
                                            • 5 / 5
