    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
      decorarq
      Thanks a lot Chris you are very kind to share
      Rodolfo Prieto
      Mexico City
      • 2 Offline
        21D
        hi chriss, i have been using this incredible plugin for quite a while now, but i recently have been running into a small problem,
        i am not able to bend anymore, i can start the plugin, select the straigt line, and than select the bend line, but after that the progressbar at the bottom that states how far along it's going, just hangs at 5% and dosn't bend, so i don't even get to see the preview of the bend to even start it, would you know why this is??
        SU version: 7.1 (latest)
        i also have your LOFT plugin and this one works fine till now, so i think it's a problem with BEND itself
        thnx for the amazing plugins mate
        "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
        Le Corbusier
          archi-sketch
          THANK YOU VERY MUCH!!
          • Chris FullmerC Offline
            Hey Rachid, I'm not sure what the problem is. It sounds like a similar bug others have experienced when they had a old version of component spray installed. Any chance you have component spray installed recently?
            • 2 Offline
              21D
              @chris fullmer said:
              ... a old version of component spray installed. Any chance you have component spray installed recently?
              actualy yes, i recently installed it, because i really needed for a project, but i did not know there where another version of component spray...
              ::edit::
              after reading your post i went and removed CS to see if this was my problem, and yup that was it 😳
              but is there another version of CS that does not conflict with BEND??
              Le Corbusier
                Yup, the newest version is located here:
                http://forums.sketchucation.com/viewtopic.php?f=323&t=11746
                It has a few improvements, and fixes the this bug. Specifically what it was doing was interfering with Progressbar. So any script that used progressbar is broken if you have the bad version of Component Spray installed.
                But get the new version and it should all be working smoothly. Well, as smoothly as shape bender can work, its a bit buggy 😄
                  suzid6050
                  Hi just wondering if you can help me, I have installed the shape bender several times and still getting the same problem where it wont let me select the line. I have made my box a group, click on the shape bender and then it wont let me continue. I have tryed redrawing the red line, I have reset my axis but still having no luck. Please help
                    Yeah, please set up a file with the the component, curved line and straight line so it is ready to bend, then upload it here. I'll check it out and see if I can get it to work. Then we'll see where to go from there,
                      suzid6050
                      here is the component I am trying to curve but having no success with, hope you can help, Thanks.
                      sketch up 2.skp
                        Hmm, it worked for me just fine. Select the component, start the tool. The cursor changes a little bit. Hover over the straight line until it turns blue, then click on it. Then click on the curve and it should start processing. It takes about 30 seconds to process on my computer is all.
                        So. How far into that process can you get? Does the cursor change when you try to activate the tool?
                          suzid6050
                          no it doesnt change it just says please select the line on the red axis and wont let me select the line.
                            Would you please open the ruby console in Window > Ruby Console.
                            Then run shape bender. See if that window shows any errors. Please copy the entire text and past it back here. Hopefully it will be giving you some odd error that I can see and fix.
                              suzid6050
                              Error: #<TypeError: cannot convert nil into String>
                              C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:158:in create_cursor' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:158:in make_cursors'
                              C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:128:in activate' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:995:in select_tool'
                              C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:995:in call' Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor'
                              C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in onSetCursor' Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor'
                              C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in onSetCursor' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:173:in onMouseMove'
                              C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in onSetCursor'
                              C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:173:in onMouseMove' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165 Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor'
                              C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in onSetCursor' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165 Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor'
                              C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in onSetCursor' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:230:in onLButtonUp'
                              C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:230:in onLButtonUp' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165 Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor'
                                It looks like you have misplaced files ?
                                C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:158:in `create_cursor'
                                line_cursor_path = Sketchup.find_support_file("line_pointer.png", "Plugins/clf_shape_bender")
                                curve_cursor_path = Sketchup.find_support_file("curve_pointer.png", "Plugins/clf_shape_bender")
                                default_cursor_path = Sketchup.find_support_file("default_pointer.png", "Plugins/clf_shape_bender")
                                @line_pointer = UI.create_cursor(line_cursor_path, 15, 2)### line 158 ### line_cursor_path if nil !!!
                                Do you have these images and other files in a folder called clf_shape_bender in the Plugins folder ???Capture.PNG
                                • DVERGERD Offline
                                  DVERGER
                                  No success me too.
                                  I have this : 1%.End @ ? (1 of 5) Searching for objects to explode.
                                    Can those of you having these problems please check that all of the files are in the right folders first...
                                    Then try again and report back... 😕
                                      arjunmax09
                                      @dverger said:
                                      No success me too.
                                      ditto situtation like dverger.... happens with me too..... i've checked all my files but the problem still persists... the plugin keeps on searching but nothing happens....
                                      when you fail at something....you haven't really failed...you've found one way the thing will not work out
                                      • DVERGERD Offline
                                        DVERGER
                                        Yes, I found!
                                        I have the progressbar in french (fr_progressbar.rb) so I copy this one in progressbar.rb and that's run.
                                        http://www.crai.archi.fr/RubylibraryDepot/Ruby/FR_fil_page.htm
                                          It's the name of the file it's trying to load fr_ progressbar.rb !
                                          Still doesn't fix the other some files in the wrong folder possible problems...
                                            arjunmax09
                                            but i have the progressbar ruby script in English only ... my shape bender isn't workin' yet... 😞
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 63
                                            • 64
                                            • 12 / 64
