    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.3m Views 329 Watching
      21D
      @chris fullmer said:
      ... a old version of component spray installed. Any chance you have component spray installed recently?
      actualy yes, i recently installed it, because i really needed for a project, but i did not know there where another version of component spray...
      ::edit::
      after reading your post i went and removed CS to see if this was my problem, and yup that was it 😳
      but is there another version of CS that does not conflict with BEND??
      "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
      Le Corbusier
      • Chris FullmerC
        Yup, the newest version is located here:
        404 Not Found
        (forums.sketchucation.com)
        It has a few improvements, and fixes the this bug. Specifically what it was doing was interfering with Progressbar. So any script that used progressbar is broken if you have the bad version of Component Spray installed.
        But get the new version and it should all be working smoothly. Well, as smoothly as shape bender can work, its a bit buggy 😄
          suzid6050
          Hi just wondering if you can help me, I have installed the shape bender several times and still getting the same problem where it wont let me select the line. I have made my box a group, click on the shape bender and then it wont let me continue. I have tryed redrawing the red line, I have reset my axis but still having no luck. Please help
          • Chris FullmerC
            Yeah, please set up a file with the the component, curved line and straight line so it is ready to bend, then upload it here. I'll check it out and see if I can get it to work. Then we'll see where to go from there,
              suzid6050
              here is the component I am trying to curve but having no success with, hope you can help, Thanks.
              sketch up 2.skp
              • Chris FullmerC
                Hmm, it worked for me just fine. Select the component, start the tool. The cursor changes a little bit. Hover over the straight line until it turns blue, then click on it. Then click on the curve and it should start processing. It takes about 30 seconds to process on my computer is all.
                So. How far into that process can you get? Does the cursor change when you try to activate the tool?
                  suzid6050
                  no it doesnt change it just says please select the line on the red axis and wont let me select the line.
                  • Chris FullmerC
                    Would you please open the ruby console in Window > Ruby Console.
                    Then run shape bender. See if that window shows any errors. Please copy the entire text and past it back here. Hopefully it will be giving you some odd error that I can see and fix.
                      suzid6050
                      Error: #<TypeError: cannot convert nil into String>
                      C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:158:in create_cursor' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:158:in make_cursors'
                      C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:128:in activate' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:995:in select_tool'
                      C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:995:in call' Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor'
                      C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in onSetCursor' Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor'
                      C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in onSetCursor' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:173:in onMouseMove'
                      C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in onSetCursor'
                      C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:173:in onMouseMove' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165 Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor'
                      C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in onSetCursor' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165 Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor'
                      C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in onSetCursor' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:230:in onLButtonUp'
                      C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:230:in onLButtonUp' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165 Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor'
                        It looks like you have misplaced files ?
                        C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:158:in `create_cursor'
                        line_cursor_path = Sketchup.find_support_file("line_pointer.png", "Plugins/clf_shape_bender")
                        curve_cursor_path = Sketchup.find_support_file("curve_pointer.png", "Plugins/clf_shape_bender")
                        default_cursor_path = Sketchup.find_support_file("default_pointer.png", "Plugins/clf_shape_bender")
                        @line_pointer = UI.create_cursor(line_cursor_path, 15, 2)### line 158 ### line_cursor_path if nil !!!
                        Do you have these images and other files in a folder called clf_shape_bender in the Plugins folder ???Capture.PNG
                        • DVERGERD
                          DVERGER
                          No success me too.
                          I have this : 1%.End @ ? (1 of 5) Searching for objects to explode.
                            Can those of you having these problems please check that all of the files are in the right folders first...
                            Then try again and report back... 😕
                              arjunmax09
                              @dverger said:
                              No success me too.
                              ditto situtation like dverger.... happens with me too..... i've checked all my files but the problem still persists... the plugin keeps on searching but nothing happens....
                              when you fail at something....you haven't really failed...you've found one way the thing will not work out
                              • DVERGERD
                                DVERGER
                                Yes, I found!
                                I have the progressbar in french (fr_progressbar.rb) so I copy this one in progressbar.rb and that's run.
                                http://www.crai.archi.fr/RubylibraryDepot/Ruby/FR_fil_page.htm
                                  It's the name of the file it's trying to load fr_ progressbar.rb !
                                  Still doesn't fix the other some files in the wrong folder possible problems...
                                    arjunmax09
                                    but i have the progressbar ruby script in English only ... my shape bender isn't workin' yet... 😞
                                    • DVERGERD
                                      DVERGER
                                      Mon dossier Shape Bender (dans le dossier Plugins)
                                        suzid6050
                                        all my files are in the correct place, no the plugin tab has disappeared from the top of sketchup. Still having no joy
                                          I have fixed your file and PM'd it to you.
                                          Do you also have progressbar.rb in the right place [Plugins] ?
                                          Basically I found your group a bit messy [exploded-nested/re-oriented/etc] and cleaned it up then it worked OK...
                                          • Chris FullmerC
                                            Thanks TIG for stepping in and helping here. I'll throw in my observations here as well.
                                            Shape bender is really slow at breaking down internal components. So if your component you are bending has internal components or groups, it will go LOTS faster if you explode them all first. It can be slow you might think it was broken.
                                            And if you are having problems, please open the ruby console and then run the script and copy and paste all errors into this thread and then we can troubleshoot.
                                            If you have component spray (a different plugin) installed, please make sure it the most recent version. Previous versions had conflicts with progressbar, which in turn broke every script that uses progresbar, including shapebender. You might try removing component spray temporarily to see if that helps.
                                            If you can not select the straight line, you might need to right click on the model axis and choose "Reset Axis", and then try the script again.
                                            Keep reporting back here with specific errors, and exactly where the script breaks down, and we (I mean me and anyone like TIG who is kind enough to help me!) should be able to troublshoot most anything,
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 63
                                            • 64
                                            • 17 / 64
