    [Plugin] V-Ray Tools
    238 Posts 80 Posters 301.7k Views 80 Watching
    • W
      wahoowetzel
      here's my current fie location setup.
      Does this look correct? I've checked under tools and plugins and I don't see it in SKUP.
        No, you should not have that vray_toys-1_1_1 folder there.
        The VRayToys folder and a vray_toys.rb should be placed directly under SU's plugins folder.
        • W
          wahoowetzel
          shoot, you're totally right. blanked out I guess.
          Thanks again, and it seems like you're the go to guy for VfSU, I hope the beta testing is going well. It's rolling out in February right? Looking forward to it and thanks again!
            Not sure exactly when it goes gold. But they're working hard to get it out soon. Crunch time I think.
            • C
              cadmunkey
              Hi ThomThom, does this camera plugin work with the new Vray for SU release? I cant seem to get the zoom factor to output correctly anymore.
              Have you had chance to use it yet in the new Vray at all?
                With the new VfSU you do not need to adjust the Zoom factor. Set it to one.
                There is no features in this plugin for the new VfSU.
                • C
                  cadmunkey
                  Thanks man!
                    Updated to make Load on Demand compatible with the new VfSU release.
                    When using VfSU 1.48.66 or newer - you can now enable or disable VfSU from Preferences -> Extensions in SketchUp.
                    But that will enable VfSU for all SU sessions. If you want to enable VfSU in just one session then use V-Ray Toys->Start V-Ray.
                    • N
                      nattawout
                      thank you very much
                      • N
                        nomeradona
                        thanks thom, for the new release of vray i have to overwrite the old file right?
                          you're talking about V-Ray Toys or V-Ray for Sketchup?
                          • troyhomeT
                            troyhome
                            I'm running 1.48.83 vfsu on my mac and vray toys doesn't work. Under Tools, there is a check by Load Vray on demand, but vfsu still loads. ?? any ideas? thanks! I used the great plug to prevent the extra time it takes SU to load. I miss that now.
                            IOviz.com
                            SU Pro 2024 PC
                            • sadyoS
                              sadyo
                              I'm running 1.48.89 vfsu, and it still working fine for me, I also experienced the same problem when first using this tool.
                              You just have to click out the VRay Toolbar first, then restart the SketchUp
                                hm.... maybe it's not finding the location of VfSU on OSX properly... any error messages in the Ruby Console?
                                • troyhomeT
                                  troyhome
                                  I'll try that- thanks!
                                  update:
                                  I opened SU, clicked on the Vray Toolbar and quick SU. I reopened SU and no change 😞
                                  What did i miss?
                                  update:
                                  I thought it was solved, but the toolbar was just hiding...i thought it still took a long time to load SU...
                                  IOviz.com
                                  SU Pro 2024 PC
                                  • troyhomeT
                                    troyhome
                                    ThomThom, no errors reported...
                                    IOviz.com
                                    SU Pro 2024 PC
                                      You have the console open before you click Load V-Ray ?
                                      • troyhomeT
                                        troyhome
                                        No, i just opened the Ruby Consol after SU started and didn't see anything.
                                        There is permanently a check beside Load Vray, if that gives you any hints... I try to uncheck it and nothing happens.
                                        IOviz.com
                                        SU Pro 2024 PC
                                        • troyhomeT
                                          troyhome
                                          There is permanently a check beside Load Vray on Demand, if that gives you any hints... I try to uncheck it and nothing happens.
                                          IOviz.com
                                          SU Pro 2024 PC
                                          • troyhomeT
                                            troyhome
                                            okay- i am an idiot- i had forgotten to go into preferences and uncheck Vray in the extensions... well you know the rest. DUHHH... how many of these moments am i going to have this month??
                                            IOviz.com
                                            SU Pro 2024 PC
                                            • 11
                                            • 12
                                            • 4 / 12
