    [Plugin] V-Ray Tools
    238 Posts 80 Posters 290.1k Views 80 Watching
      AcesHigh
      @thomthom said:
      Sorry. What I mean is that we can only allow what SU allows us to control from Ruby. The API is the methods we can use to communicate with SU's model. Making textures unique is missing. 😞
      damn SU developers!
      does that mean you cant even execute the Make Texture Unique command already implemented into GE? Maybe simulate a right click over the face and a left click over the command?? 😄
        hmm... not sure.
        maybe if you assigned a hotkey to it I could trigger that hotkey.
          AcesHigh
          @thomthom said:
          hmm... not sure.
          cant the plugin itself assign a hotkey?
            nope!
            • W Offline
              wahoowetzel
              Hey ThomThom,
              I'm trying to use the vray toys-specifically the camera sync function, and I'm not having any luck getting the tools to show up anywhere in sketchup. I've dropped the folder into my plugins folder like I've done with my other plugins, but no luck. I'm running Sketchup 7.1.6087 (the latest, I think) and vRay 01.05.30, in case that matters.
              Any idea what the problem could be? I think I have it saved in the right place, I restarted sketchup several times and I've restarted my comp just in case.
                Do you have one VRayToys folder and a vray_toys.rb file right under your plugins folder?
                When loaded you should have an V-Ray Toys menu under Tools. And a V-Ray Tools toolbar.
                • W Offline
                  wahoowetzel
                  here's my current fie location setup.
                  Does this look correct? I've checked under tools and plugins and I don't see it in SKUP.
                    No, you should not have that vray_toys-1_1_1 folder there.
                    The VRayToys folder and a vray_toys.rb should be placed directly under SU's plugins folder.
                    • W Offline
                      wahoowetzel
                      shoot, you're totally right. blanked out I guess.
                      Thanks again, and it seems like you're the go to guy for VfSU, I hope the beta testing is going well. It's rolling out in February right? Looking forward to it and thanks again!
                        Not sure exactly when it goes gold. But they're working hard to get it out soon. Crunch time I think.
                          cadmunkey
                          Hi ThomThom, does this camera plugin work with the new Vray for SU release? I cant seem to get the zoom factor to output correctly anymore.
                          Have you had chance to use it yet in the new Vray at all?
                            With the new VfSU you do not need to adjust the Zoom factor. Set it to one.
                            There is no features in this plugin for the new VfSU.
                              cadmunkey
                              Thanks man!
                                Updated to make Load on Demand compatible with the new VfSU release.
                                When using VfSU 1.48.66 or newer - you can now enable or disable VfSU from Preferences -> Extensions in SketchUp.
                                But that will enable VfSU for all SU sessions. If you want to enable VfSU in just one session then use V-Ray Toys->Start V-Ray.
                                • N Offline
                                  nattawout
                                  thank you very much
                                  • N Offline
                                    nomeradona
                                    thanks thom, for the new release of vray i have to overwrite the old file right?
                                      you're talking about V-Ray Toys or V-Ray for Sketchup?
                                      • troyhomeT Offline
                                        troyhome
                                        I'm running 1.48.83 vfsu on my mac and vray toys doesn't work. Under Tools, there is a check by Load Vray on demand, but vfsu still loads. ?? any ideas? thanks! I used the great plug to prevent the extra time it takes SU to load. I miss that now.
                                        IOviz.com
                                        SU Pro 2024 PC
                                        • sadyoS Offline
                                          sadyo
                                          I'm running 1.48.89 vfsu, and it still working fine for me, I also experienced the same problem when first using this tool.
                                          You just have to click out the VRay Toolbar first, then restart the SketchUp
                                            hm.... maybe it's not finding the location of VfSU on OSX properly... any error messages in the Ruby Console?
                                            • 11
                                            • 12
                                            • 3 / 12
