    Bonzai 2.0 released
    extensions
    215 Posts 28 Posters 55.1k Views 28 Watching
      @xrok1 said:
      love the fact that you can detach the flyout toolbars.
      i really think that this:[attachment=0:1dckt4eq]<!-- ia0 -->Capture2.JPG<!-- ia0 -->[/attachment:1dckt4eq]
      should be the default though, for a while i could'nt figure why i had to rearange my tools to my liking everytime i started. πŸ‘Š
      Ah hah! πŸ‘
      • ken28875K Offline
        ken28875
        This is the setting for bonzai3d. Does anyone knows if there is a similar option for sketchup? Each time I add a new plugin, everything gets messed up and I have to rearrange all my icons when I start sketchup.
        Thanks.
        _KN
        Follow Your Dreams.
        • X Offline
          xrok1
          Thanks.
          _KN
          sorry, this is the age old question. i'm afaid you, and everyone else is SOL when it comes to this issue! πŸ‘Ώ
          maybe there will be a couple users left by version 8 who can enjoy fixed toolbars! πŸ˜’ MAYBE...
            bonzai3d support
            Rocky,
            I was not able to get the view into SketchUp -- but you may know something about SketchUp that I don't...
            Regarding bonzai3d preferences, the palette locations AND the tool options are stored in the System General: Preference file (or Previous Session settings). Personally, I don't like the Previous Session option, as it can cause tools to behave differently every time you launch bonzai3d (if you are changing tool options and then quitting). Personally, I like to launch with Default Prefs, change anything and everything I can think of, Save a Preference File, quit, and relaunch once more -- and then exactly the preferences (and only the preferences) that I want will be saved.
            Does this help?
            Explore * Design * Deliver
            http://www.bonzai3d.com
            Version 2.5 Now Available!
            • jeff hammondJ Offline
              not quite everyone ο£Ώ
              πŸ˜„
              • X Offline
                xrok1
                πŸ˜„
                do tell!
                  @bonzai3d support said:
                  Jeff,
                  We have found that as you get close to the limits of what fillets can be generated, bonzai3d may not allow them to occur when you are doing these as 2d fillets. If you extrude the shape after it has been joined, you should then be able to apply a 2d Round to the desired segment, and derive the bottom edge to get what you want.
                  Thanks for bringing this to our attention, we will get this corrected so that you can apply the same fillets in 2d as you can with rounding in 3d.
                  i'm a dunce 😞
                  i cannot figure this out...
                  are you saying to first extrude like this:
                  or like this?
                  if it's either of those two, it's not working for me..
                  • X Offline
                    xrok1
                    Rocky,
                    Your second example (extruding horizontally) is the right way -- and you should then use the Round tool on (only) the horizontal segment that is visually close to the (green) Y axis.
                    If you are having any further trouble with this, please email your BNZ file to support@bonzai3d.com so we can get you a more specific answer.
                    πŸ˜† that was jeff.
                      @xrok1 said:
                      HEY! dwg worked! it created a new scene tab that seems to match except that B3D and SU seem to not agree where the origin is. try it out!
                      For the origin, make sure you set the options to preserve the drawing origin.
                      I tried to export. I do get a new scene. But the view don't match.
                      xrok1: That thing you thought was related the the camera, when you select it, the Entity Info window says direct. Think it refers to a lightsource.
                        Regarding the matching views: my bad! I had saved the view before changing it for export.
                        This looks promising.
                          bonzai3d support
                          Rocky,
                          Yes, that is a graphic representation of the light source, and may be deleted if you don't want it. (It imports as an actual light source to programs that support it.)
                          Jeff,
                            Onto another topic: can you have Hidden lines ontop of a background image? would be useful for photomatching.
                            • X Offline
                              xrok1
                              mine seem to match?? maybe you could give me your file?
                                See the follow up post. I forgot to save the view in B3D after updating it. 😳
                                  bonzai3d support
                                  @xrok1 said:
                                  πŸ˜† that was jeff.
                                  Oops! Sorry.
                                  Thomas,
                                  There is not a background option for the hidden Line view, but perhaps you can get what you want in Shaded Work by setting the objects to Render as Wireframe and NOT Render as Shaded Surface?
                                  You could do this on an object basis if you want, but it would be easiest to change this back and forth, perhaps, if you used the Layer (or Layer Group) overrides:
                                  • X Offline
                                    xrok1
                                    ?? what do you mean by hidden lines?
                                    EDIT ok, you mean wireframe. rightclick any object and click attributes, then clear the check box for render as a shaded surface
                                    BTW, support the background images seam to load upside down??
                                    • X Offline
                                      xrok1
                                      awsome let us know how it turns out. πŸ˜„
                                        Problem then is that I get all lines, and it's hard to tell them apart for a model where lots of stuff is going on.
                                        Hidden Lines with background would be great for photomatching as you'd only see the contour edges and you can then ensure they line up with your background image.
                                        Feature request?
                                        Layer Groups! πŸ˜„ This I like. πŸ‘
                                          http://www.formz.com/forum/discus41/messages/35952/41031.html?1266419040 πŸ˜‰
                                          • X Offline
                                            xrok1
                                            i guess i'll have to join their forum. the thing is i have an nvidia 8600 though, very common card/drivers, shouldn't be problematic.
                                            • 11
                                            • 7 / 11
