    Bonzai 2.0 released
    extensions
    215 Posts 28 Posters 60.7k Views 28 Watching
    • X Offline
      xrok1
      HEY! dwg worked! it created a new scene tab that seems to match except that B3D and SU seem to not agree where the origin is. try it out!
      • X Offline
        xrok1
        yes i have toolbar hell.. i'm just to tired of it to rearrange them again. 😢
        • X Offline
          xrok1
          hmm...
            Speaking of toolbars - I was having some trouble arranging the B3D toolbars today. Accidentally moved one of them and it suddenly appeared underneath another one. Tried to move it back - and I got a strange feeling of SU-toolbar-déjà-vu. They didn't seem to stay where I dropped them.
            • X Offline
              xrok1
              love the fact that you can detach the flyout toolbars.
              i really think that this:Capture2.JPG
              should be the default though, for a while i could'nt figure why i had to rearange my tools to my liking everytime i started. 👊
                i really think that this:[attachment=0:1dckt4eq]<!-- ia0 -->Capture2.JPG<!-- ia0 -->[/attachment:1dckt4eq]
                Ah hah! 👍
                • ken28875K Offline
                  ken28875
                  This is the setting for bonzai3d. Does anyone knows if there is a similar option for sketchup? Each time I add a new plugin, everything gets messed up and I have to rearrange all my icons when I start sketchup.
                  Thanks.
                  _KN
                  Follow Your Dreams.
                  • X Offline
                    xrok1
                    Thanks.
                    _KN
                    sorry, this is the age old question. i'm afaid you, and everyone else is SOL when it comes to this issue! 👿
                    maybe there will be a couple users left by version 8 who can enjoy fixed toolbars! 😒 MAYBE...
                      bonzai3d support
                      Rocky,
                      I was not able to get the view into SketchUp -- but you may know something about SketchUp that I don't...
                      Regarding bonzai3d preferences, the palette locations AND the tool options are stored in the System General: Preference file (or Previous Session settings). Personally, I don't like the Previous Session option, as it can cause tools to behave differently every time you launch bonzai3d (if you are changing tool options and then quitting). Personally, I like to launch with Default Prefs, change anything and everything I can think of, Save a Preference File, quit, and relaunch once more -- and then exactly the preferences (and only the preferences) that I want will be saved.
                      Does this help?
                      Explore * Design * Deliver
                      http://www.bonzai3d.com
                      Version 2.5 Now Available!
                      • jeff hammondJ Offline
                        not quite everyone 
                        • X Offline
                          xrok1
                          do tell!
                            @bonzai3d support said:
                            Jeff,
                            We have found that as you get close to the limits of what fillets can be generated, bonzai3d may not allow them to occur when you are doing these as 2d fillets. If you extrude the shape after it has been joined, you should then be able to apply a 2d Round to the desired segment, and derive the bottom edge to get what you want.
                            Thanks for bringing this to our attention, we will get this corrected so that you can apply the same fillets in 2d as you can with rounding in 3d.
                            i'm a dunce 😞
                            i cannot figure this out...
                            are you saying to first extrude like this:
                            or like this?
                            if it's either of those two, it's not working for me..
                            • X Offline
                              xrok1
                              Rocky,
                              Your second example (extruding horizontally) is the right way -- and you should then use the Round tool on (only) the horizontal segment that is visually close to the (green) Y axis.
                              If you are having any further trouble with this, please email your BNZ file to support@bonzai3d.com so we can get you a more specific answer.
                              😆 that was jeff.
                                For the origin, make sure you set the options to preserve the drawing origin.
                                I tried to export. I do get a new scene. But the view don't match.
                                xrok1: That thing you thought was related the the camera, when you select it, the Entity Info window says direct. Think it refers to a lightsource.
                                  Regarding the matching views: my bad! I had saved the view before changing it for export.
                                  This looks promising.
                                    bonzai3d support
                                    Rocky,
                                    Yes, that is a graphic representation of the light source, and may be deleted if you don't want it. (It imports as an actual light source to programs that support it.)
                                    Jeff,
                                      Onto another topic: can you have Hidden lines ontop of a background image? would be useful for photomatching.
                                      • X Offline
                                        xrok1
                                        mine seem to match?? maybe you could give me your file?
                                          See the follow up post. I forgot to save the view in B3D after updating it. 😳
                                            bonzai3d support
                                            @xrok1 said:
                                            😆 that was jeff.
                                            Oops! Sorry.
                                            Thomas,
                                            There is not a background option for the hidden Line view, but perhaps you can get what you want in Shaded Work by setting the objects to Render as Wireframe and NOT Render as Shaded Surface?
                                            You could do this on an object basis if you want, but it would be easiest to change this back and forth, perhaps, if you used the Layer (or Layer Group) overrides:
                                            • 11
                                            • 6 / 11
