    Way to Exit Photomatch?
    15 Posts 6 Posters 1.0k Views 6 Watching
    • X
      xrok1
      how about if you do a photo match, add a page before you move the camera then delete the photo match?
      • Chris FullmerC
        Nope, the new page turns into an exact duplicate of the photomtach. I even made a new page hat does not keep the camera info, then went to my photomatch scene, then updated my other scene to keep camera location, updated the scene and then it also become a copy of the photomatch. 😞
          hmm... I imagine I did this once... ... ... hmm .... it's all to early in the morning...
          • mitcorbM
            mitcorb
            What about chrisglasier's [CODE]Camera Settings thread. Anything in there?
            • GaieusG
              What if you simply delete the PhotoMatch scene (without making a new scene prior to that)?
              (Just thinking loud - I have actually never made a PM model)
                MartinRinehart
                This sounds too simple. I must be missing something. In case I'm not, in your console:
                ` # when you like the settings
                view = Sketchup.active_model.active_view
                cam = view.camera
                newcam = cam.set( cam.eye, cam.target, cam.up )
                newcam.fov = cam.fov # others as needed
                later on
                view.camera = newcam`
                (Basic idea. Code not run.)
                Did I see somewhere that cam.set() actually takes more args than the docs report?
                  Well, I tried to find a way to do this from the SU UI - but found none.
                  • mitcorbM
                    mitcorb
                    @Martin:
                    My apologies for misspelling your name.
                    mitcorb
                    • X
                      xrok1
                      how about using film/stage to create a camera?
                      • Chris FullmerC
                        Very interesting. This must be a Feature request then. Or maybe just make a ruby to do it. I was realy hoping it was built in.
                        Oh well, I'll do it through Ruby then. Thanks everyone. I'll try the film and stage method, then I'll try with your code Martin.
                        • Chris FullmerC
                          Well, as a follow up. I discovered how to do what I wanted more or less. I really just wanted to get the photomatch photo out of the way. I thought deleteing the photmatch would be the easiest way....not the case. But I did find that I could open the SketchOver dialo window and from there I could choose to tun of the photo. So that did the trick.
                          • Chris FullmerC
                            I also discovered that if I then choose to edit the photomatch from the SketchOver dialog window, I can right click and choose "Cancel Photomatch", and that will erase the photomatch, but leave the camera in the correct position. So then I just created a new scene right there, and it worked just how I wanted. After much work.
