    Way to Exit Photomatch?
    15 Posts 6 Posters 950 Views 6 Watching
    • Chris FullmerC Offline
      Well thats the point, It seems like this should be built into SU. So I didn't want to write a tool to do this if it is already a native feature. Especially since its something I only need for this little project.
      • X Offline
        xrok1
        how about if you do a photo match, add a page before you move the camera then delete the photo match?
          Nope, the new page turns into an exact duplicate of the photomtach. I even made a new page hat does not keep the camera info, then went to my photomatch scene, then updated my other scene to keep camera location, updated the scene and then it also become a copy of the photomatch. 😞
            hmm... I imagine I did this once... ... ... hmm .... it's all to early in the morning...
            • mitcorbM Offline
              mitcorb
              What about chrisglasier's [CODE]Camera Settings thread. Anything in there?
                What if you simply delete the PhotoMatch scene (without making a new scene prior to that)?
                (Just thinking loud - I have actually never made a PM model)
                  MartinRinehart
                  This sounds too simple. I must be missing something. In case I'm not, in your console:
                  ` # when you like the settings
                  view = Sketchup.active_model.active_view
                  cam = view.camera
                  newcam = cam.set( cam.eye, cam.target, cam.up )
                  newcam.fov = cam.fov # others as needed
                  later on
                  view.camera = newcam`
                  (Basic idea. Code not run.)
                  Did I see somewhere that cam.set() actually takes more args than the docs report?
                    Well, I tried to find a way to do this from the SU UI - but found none.
                    • mitcorbM Offline
                      mitcorb
                      @Martin:
                      My apologies for misspelling your name.
                      mitcorb
                      • X Offline
                        xrok1
                        how about using film/stage to create a camera?
                          Very interesting. This must be a Feature request then. Or maybe just make a ruby to do it. I was realy hoping it was built in.
                          Oh well, I'll do it through Ruby then. Thanks everyone. I'll try the film and stage method, then I'll try with your code Martin.
                            Well, as a follow up. I discovered how to do what I wanted more or less. I really just wanted to get the photomatch photo out of the way. I thought deleteing the photmatch would be the easiest way....not the case. But I did find that I could open the SketchOver dialo window and from there I could choose to tun of the photo. So that did the trick.
                              I also discovered that if I then choose to edit the photomatch from the SketchOver dialog window, I can right click and choose "Cancel Photomatch", and that will erase the photomatch, but leave the camera in the correct position. So then I just created a new scene right there, and it worked just how I wanted. After much work.
