    Bonzai 2.0 released
    extensions
    215 Posts 28 Posters 34.7k Views 28 Watching
    • jeff hammondJ Offline
      @xrok1 said:
      ahh, yes, trim them then use the join tool to connect them, then the fillet will work.
      meh, there seems to be some quirks with it still.. might sign up at the bonzai forum and post there.
        @ken28875 said:
        This is really a Sketchup clone but with some tools that sketchup does not have.
        On the surface it might look similar. But it's fundamentally a different modelling tool.
        SketchUp is a surface modeller. While Bonzai is a NURBS modeller. Significant difference there.
        • utilerU Offline
          utiler
          Good point, Thom.
          Just Curious...
            The Photomatch is absolutely superior to SU.
            Question is, is there a format I can export from B3D from, that will preserve the view(s) set up in a b3s model when importing to SU?
              Aaaah! I've been fighting this PhotoMatch job in SU for my current project. I just can't get it correct. In B3D I got it fitting in 30secs! x_X Now how do I get this into SU? Need to render in VfSU.
                bonzai3d support
                Jeff,
                We have found that as you get close to the limits of what fillets can be generated, bonzai3d may not allow them to occur when you are doing these as 2d fillets. If you extrude the shape after it has been joined, you should then be able to apply a 2d Round to the desired segment, and derive the bottom edge to get what you want.
                Thanks for bringing this to our attention, we will get this corrected so that you can apply the same fillets in 2d as you can with rounding in 3d.
                Thomas,
                Bonzai3d will export views with a number of different formats, including 3ds and DAE. Unfortunately, it appears that SketchUp does not read the views from these formats.
                With bonzai3d, you can go to the Palettes Menu: View Parameters to see all the variables for the view, including the camera location, the center of interest, the view and spin angles, etc. (These values can be entered numerically into bonzai3d to change the view as well.) Perhaps there is a way to copy these values into SketchUp to set this view?
                Explore * Design * Deliver
                http://www.bonzai3d.com
                Version 2.5 Now Available!
                • X Offline
                  xrok1
                  well you can create a view, which inserts a camera that is selectable, but you can't seem to convert it to anything exportable, or snap to it to create matching geometry. 😒
                  • ken28875K Offline
                    ken28875
                    Hi Thomas,
                    Yes, you're right. I agree with you, but I wish that sketchup can do some similar things, maybe with the help of plugins.
                    The bulge is quite useful. The bending from Bonzai3D seems quite neat too, and the revolve/helices are great tools.
                    I don't know if anyone has tried to write a ruby script for similar tools than the ones I just mentioned above yet. The only thing that I can think of is the bending from Fredo.
                    Have a nice day! β˜€
                    _KN
                    Follow Your Dreams.
                    • X Offline
                      xrok1
                        ...what about DWG? I imagine I've had files where after importing I get a scene 3d
                        That's interesting. I could possibly write up a script. Depends if I can match up the values.
                        Will .skp export something B3D will support at some point?
                        • X Offline
                          xrok1
                          if bonzai would support exporting the camera as geometry as an option, problem would be solved wouldn't it? or even snapping to camera geometry (wireframe) so that it could be referenced to draw an object from before export.
                            Still would need work in SU. It'd be no different than using the values you see in B3D. Camera position, directions, FOV etc still need to match.
                              the funny thing is that is seen when I read the SUCF ! πŸ’š
                              • X Offline
                                xrok1
                                well we know jim knows how to code an importer (JF obj import) i wonder if he (someone) could figure out how to get the 3DS scene/camera info into SU.
                                  Does OBJ support views/cameras?
                                    Jim
                                    Maybe this can be made into something useful?
                                    http://forums.sketchucation.com/viewtopic.php?f=323&t=26185
                                    • X Offline
                                      xrok1
                                      i don't think so, i was suggesting perhaps a new or modified importer based on the obj importer that could properly handle 3DS. 😳
                                      does someone care to do Googles job for them yet again? 😑
                                        bonzai3d support
                                        Thomas,
                                        Bonzai3d also supports cameras via DWG format (although Autodesk automatically turns on clipping). If you uncheck this option (if you have such an option in SketchUp) then you should be able to get the view to match this way as well.
                                        However, I don't see anything in SketchUp's scenes after importing a DWG file that includes (views or scenes). Perhaps the question "How to import views to SketchUp" is a question for the main SketchUp forum?
                                        • F Offline
                                          fossa
                                          Exactly, way beyond tired of waiting for Google.
                                            Thomas,
                                            Will look into that. The DWGs I've seen this with has been exported from Revit.
                                            • 11
                                            • 11 / 11
