    Re: [Plugin] Another Mirror Ruby
    31 Posts 15 Posters 37.5k Views 15 Watching
      Matt666
      Here is icon I use for this plugin.
      Frenglish at its best !
      My scripts
      • boofredlayB Offline
        boofredlay
        Matt, do you use it for the Mirror3[1].0.rb or for Mirror.rb?
        And how do you get the icon/button to work with the script?
        Thanks.
        The current issue I have with Mirror.rb is that I get a bugsplat about 15-20% of the time, which inversely correlates to the frequency of times I save before using it. 😒
          Matt666
          Hi Boofredlay !
          I don't know !! I've renamed it...
          At the beginning of the script, it's written :
          Description : Mirrors Selection at Point, Line or Plane
          Author : Originally by Frank Wiesner
          BUT NOTE from v2.6 it's been TIG tweaked and rewritten...###
          Usage : 1. Make Selection (Any Entites allowed)###
          2. Select 'Mirror Selection' from Plugins Menu
          or from Context Menu or your ShortCut Key
          3. If here's no Selection then dialog informs
          4. Pick a Point and RETURN to Mirror at the Point
          5. Pick a Second Point and RETURN to Mirror at the Line
          6. Pick a Third Point to Mirror at the Plane
          7. Final Option is Erase Original ?
          If Yes then Highlighting of Selection passes to Copies
          (Note: Erase is undo-able separately from the Mirroring)
          Replace that
          if( not file_loaded?("mirror3.0.rb") )
          	UI.menu("Plugins").add_item("Mirror Selection") { Sketchup.active_model.select_tool MirrorTool.new }
          	UI.add_context_menu_handler do | menu |
          		if Sketchup.active_model.selection
          			menu.add_separator
          			menu.add_item("Mirror Selection") { Sketchup.active_model.select_tool MirrorTool.new }
          file_loaded("mirror3.0.rb")
          By that :
          	tb = UI;;Toolbar.new("Mirror")
          	cmd = UI;;Command.new("MI") { Sketchup.active_model.select_tool MirrorTool.new }
          	cmd.large_icon = cmd.small_icon = File.join("plugins", "MI.png")
          	cmd.tooltip = cmd.status_bar_text = "Mirror"
          	tb.add_item(cmd)
          			menu.add_separator
          	state = tb.get_last_state
          	if(state == TB_NEVER_SHOWN)
          		tb.show
          	elsif (state == TB_VISIBLE)
          		tb.restore
          In the code.
          My scripts
            boofredlay
            Thanks Matt, that did the trick however I cannot see the image, just the toolbar. I have the image placed in my Plugins folder, does it need to go elsewhere?
            Thanks again.
            • Didier BurD Offline
              Didier Bur
              This line sounds wrong to me. Replace it with:
              cmd.large_icon = cmd.small_icon = "Plugins"/MI.png"
              DB
                Matt666
                Oops πŸ‘Ž 😳
                Excuse me I have not tested the code...
                I don't use slashes in my scripts, because I think (not sure) they could cause a bug on mac machines...
                cmd.large_icon = cmd.small_icon = File.join(File.dirname(__FILE__),"MI.png")
                Thank you for your correction Didier !
                My scripts
                  I now TIG did one but here's another..
                  Mirror Creates reversed images of existing objects. You have the option of erasing or retaining your original image – to create a symmetrical mirror effect or to simply reverse the image. Author: Originally created by Frank Wiesner.
                  [attachment=0:24s5sp9i]<!-- ia0 -->Mirror3[1].0.rb<!-- ia0 -->[/attachment:24s5sp9i]
                  To set the record straight... Frank invented the Mirror script ages ago: however, after version 2.6 I rewrote it - using some of his algorithms for picking the mirroring lines/planes etc, but with a completely different mirroring method. Everything after v3 [so far] is my tweaking of the code... My version is at v3.1...
                  If you want to make a toolbar / icon feel free. Remember to increment the revision / version and publish it. Then if I [or anyone else taking up the mantel] need to make any future adjustments it'll be based on that current updated version...
                  Mirror is in the public domain - so simply adjust it with your 'improvements' - remembering to credit previous originators - like Frank, or me - in the introductory notes - and let it rip...
                    boofredlay
                    • EdsonE Offline
                      Edson
                      perhaps some of our ruby experts could tweak this script so that when installed the icon would be too.
                      http://www.mahfuz.arq.br
                        arjunmax09
                        I installed the icon made by matt666 in my plugins directory and made the requisite changes to the plugin as specified on this forum. The icon is showing in my SketchUp Interface. Unfortunately when I select a group, click on the mirror icon, select two axis for mirroring. ....nothing happens 😞
                        i've modified the plugin like this...
                        # Name ;          Mirror 3.0 ###
                        # Description ;   Mirrors Selection at Point, Line or Plane
                        # Author ;        Originally by Frank Wiesner
                        #				  BUT NOTE from v2.6 it's been TIG tweaked and rewritten...###
                        # Usage ;         1. Make Selection (Any Entites allowed)###
                        #                 2. Select 'Mirror Selection' from Plugins Menu
                        #					 or from Context Menu or your ShortCut Key ###
                        #                 3. If here's no Selection then dialog informs ###
                        #                 4. Pick a Point and RETURN to Mirror at the Point
                        #                 5. Pick a Second Point and RETURN to Mirror at the Line
                        #                 6. Pick a Third Point to Mirror at the Plane
                        #                 7. Final Option is Erase Original ? ###
                        #					 If Yes then Highlighting of Selection passes to Copies
                        #					 (Note; Erase is undo-able separately from the Mirroring) ###
                        # Type ;      	Script
                        # History;
                        #				3.0  05 Aug  2006 ### TIG Ending rewritten to avoid rare bugsplats.
                        #				2.9  03 Aug  2006 ### TIG Start;commit loops to avoid rare bugsplats.
                        #				2.8  26 July 2006 ### TIG re-tweaked - Rewritten to be MUCH simpler.
                        #										Mirroring of ANY Entity Selection works properly.
                        #				2.7  23 July 2006 ### TIG tweaked - Rewritten generally.
                        #										Now processes Multiple selections of Groups and/or
                        #										Components, but warns if any 'loose' (UnGrouped)
                        #										Faces in Selection as they might lose any RePostioned
                        #										Texture data, interfere etc.
                        #				2.6  22 July 2006 ### TIG tweaked - Context menu added IF ONE group/compo.
                        #                                       Warns about selection IF NOT ONE group/compo.
                        #                                       Materials now preserved in mirrored copy BUT you will
                        #									    need to group selection to preserve material positioning
                        #										- although this is define-able it is not find-able from
                        #										the orignal face info !
                        #                                       Final option to Erase of Original Group/Compo.
                        #                 2.5  (8.Jul.2oo5)  - bugfix; faces with holes reduce now to a single face
                        #                                    - major code rewrite (dropped @clondedObject hash, heavy
                        #                                      use of groups during construction,...
                        #                                    - more redundant constructions, but seems to be more robust
                        #                                    - WARNING; POLYGONS DO NOT WORK VERY WELL
                        #                 2.4  (5.Jul.2oo5)  - all unnecessary edges created by the add_faces_from_mesh()
                        #                                      method are erased! faces with holes mirror now perfectly.
                        #                 2.3  (4.Jul.2oo5)  - fixed "mirror at plane" error
                        #                 2.2  (2.Jul.2oo5)  - works in group editting mode
                        #                                    - prevents picking of identical points
                        #                 2.1  (1.Jul.2oo5)  - fixed "undo group" bug
                        #                                    - code cleanup
                        #                 2.0  (30.Jun.2oo5) - new tool-like interface
                        #                 1.4  (29.Jun.2oo5) - arc bug fixed
                        #                                    - code simplified (clone_selection() removed)
                        #                 1.3  (24.Jun.2oo5) - can handle faces with holes in it (although more edges
                        #                                      are drawn than nessesary)
                        #                                    - correct orientation of mirrored faces
                        #                                    - supports arcs (at least works for circles), curves and groups
                        #                 1.2  (20.Jun.2oo5) - axis and origin selection algorithm does not rely on tool tips any more.
                        #                 1.1  (19.Jun.2oo5) - fix coplanar point bug
                        #                                    - better tooltips
                        #                                    - supports mirror at lines (edges, axis, construction lines)
                        #                                    - mirror-at-plane code simplified
                        #                 1.o  (10.Jun.2oo5) - first version
                        require 'sketchup.rb'
                        class MirrorTool
                            def initialize
                                @MIRROR_AT_POINT = 1
                                @MIRROR_AT_LINE = 2
                                @MIRROR_AT_PLANE = 3
                                @numPrecision = 0.00001
                            def reset
                                @pts = []
                                @state = 0
                                @transformationType = nil
                                @trans = nil
                                @point = nil
                                @line = nil
                                @linev = nil
                                @plane = nil
                                @planeNormal = nil
                                @pointOnPlane = nil
                                @curvesDone = Hash.new()
                                @cloneGroup = nil
                                @ip = Sketchup;;InputPoint.new
                                @ip1 = Sketchup;;InputPoint.new
                                @ip2 = Sketchup;;InputPoint.new
                                @ip3 = Sketchup;;InputPoint.new
                                Sketchup;;set_status_text "Mirror;  Pick First Point"###
                                @drawn = false
                            def activate
                                ###Sketchup.send_action("showRubyPanel;")
                                self.reset
                                ss=Sketchup.active_model.selection
                                if ss.empty?
                                    Sketchup;;set_status_text "Mirror; NO Selection !"###
                            		UI.messagebox("Select Something BEFORE Using the Mirror Tool.")###v2.8
                                    Sketchup.active_model.select_tool nil
                            def deactivate(view)
                                view.invalidate if @drawn
                                @ip1 = nil
                                @ip2 = nil
                                @ip3 = nil
                            def onMouseMove(flags, x, y, view)
                                case @state
                                when 0 # getting the first end point
                                    @ip.pick view, x, y
                                    if( @ip.valid? && @ip != @ip1 )
                                        @ip1.copy! @ip
                                    view.invalidate
                                    view.tooltip = @ip.tooltip if @ip.valid?
                                when 1 # getting the second end point
                                    @ip.pick view, x, y, @ip1
                                    if( @ip.valid? && @ip != @ip2 )
                                        @ip2.copy! @ip
                                        @pts[1] = @ip2.position
                                    view.invalidate
                                when 2 # getting the third end point
                                    @ip.pick view, x, y, @ip2
                                    if( @ip.valid? && @ip != @ip3 )
                                        @ip3.copy! @ip
                                        @pts[1] = @ip3.position
                                    view.invalidate
                            def onLButtonDown(flags, x, y, view)
                                @ip.pick view, x, y
                                if( @ip.valid? )
                                    case @state
                                    when 0
                                        if( @ip.valid? )
                                            @pts[0] = @ip.position
                                            Sketchup;;set_status_text "Mirror;  Hit RETURN to Mirror at Point or Pick Point 2"
                                            @state = 1
                                    when 1
                                            @pts[1] = @ip.position
                                            @state = 2
                                            Sketchup;;set_status_text "Mirror;  Hit RETURN to Mirror at Line or Pick Point 3"
                                    when 2
                                        if( @ip.valid? && @ip != @ip1 && @ip != @ip2 )
                                            @pts[2] = @ip.position
                                            @state = 3
                                            mirror()
                            def onCancel(flag, view)
                                reset
                            def draw(view)
                                if( @ip.valid? && @ip.display? )
                                    @ip.draw(view)
                                    @drawn = true
                                if( @state == 1 )
                                    view.set_color_from_line(@ip1, @ip)
                                    view.draw(GL_LINE_STRIP, @ip1.position, @ip.position)
                                    @drawn = true
                                elsif( @state == 2 )
                                    view.drawing_color = "gray"
                                    view.draw(GL_LINE_STRIP, @ip1.position, @ip2.position)
                                    view.set_color_from_line(@ip2, @ip)
                                    view.draw(GL_LINE_STRIP, @ip2.position, @ip.position)
                                    @drawn = true
                            def onKeyDown(key, repeat, flags, view)
                                if( key == CONSTRAIN_MODIFIER_KEY && repeat == 1 )
                                    @shift_down_time = Time.now
                                    if( view.inference_locked? )
                                        view.lock_inference
                                    elsif( @ip.valid? )
                                        view.lock_inference @ip
                            def onKeyUp(key, repeat, flags, view)
                                if( key == CONSTRAIN_MODIFIER_KEY && view.inference_locked? && (Time.now - @shift_down_time) > 0.5 )
                                    view.lock_inference
                                if( key == 13)
                                    mirror()
                                    self.reset
                            def mirror()
                                case @state
                                when 1
                                    @transformationType = @MIRROR_AT_POINT
                                    @point = @ip1.position.clone
                                    @trans = Geom;;Transformation.scaling(@point, -1.0)
                                    Sketchup.active_model.start_operation "Mirror at Point"
                                when 2
                                    @transformationType = @MIRROR_AT_LINE
                                    @line = [@ip1.position, @ip2.position]
                                    @linev = Geom;;Vector3d.new(@ip2.position.x-@ip1.position.x, @ip2.position.y-@ip1.position.y, @ip2.position.z-@ip1.position.z)
                                    Sketchup.active_model.start_operation "Mirror at Line"
                                when 3
                                    @transformationType = @MIRROR_AT_PLANE
                                    @plane = Geom.fit_plane_to_points(@ip1.position, @ip2.position, @ip3.position)
                                    @planeNormal = Geom;;Vector3d.new(@plane[0], @plane[1], @plane[2])
                                    @planeNormal.normalize!
                                    @pointOnPlane = @ip1.position
                                    Sketchup.active_model.start_operation "Mirror at Plane"
                                ss=Sketchup.active_model.selection###
                            	sents=[]
                            	ss.each{|e|sents.push(e)}
                            	copy_group=Sketchup.active_model.active_entities.add_group(sents)
                                new_group=copy_group.copy
                                nents=[]
                                new_group.entities.each{|e|nents.push(e)}
                                new_center = new_group.bounds.center.clone
                                mirror_point(new_center)
                                t=nil
                                t = Geom;;Transformation.scaling(new_center,-1,-1,-1)if @state==1
                                t = Geom;;Transformation.rotation(new_center,@linev,Math;;PI)if @state==2
                                tt=nil
                                if @state==3
                                   xxx=@planeNormal.normalize.to_a[0].abs*-1
                                   yyy=@planeNormal.normalize.to_a[1].abs*-1
                                   zzz=@planeNormal.normalize.to_a[2].abs*-1
                                   xxx=1 if xxx>0
                                   yyy=1 if yyy>0
                                   zzz=1 if zzz>0
                                   xxx=-1 if xxx<=0
                                   yyy=-1 if yyy<=0
                                   zzz=-1 if zzz<=0
                                   t = Geom;;Transformation.scaling(new_center,xxx,yyy,zzz)
                                   tt= Geom;;Transformation.rotation(new_center,@planeNormal,Math;;PI)
                                end#if
                                new_group.transform!(t)if t###mirror
                                new_group.transform!(tt)if tt###
                                transVec = Geom;;Vector3d.new(new_center.x-new_group.bounds.center.x, new_center.y-new_group.bounds.center.y, new_center.z-new_group.bounds.center.z)
                                t = Geom;;Transformation.translation(transVec)
                                new_group.transform!(t)###then move
                                ### ending dialog...
                            	Sketchup;;set_status_text "Mirror; Erase Original Selection ?"###
                            	if UI.messagebox("Erase Original Selection ? ",MB_YESNO,"")==6
                            	   ### 6=YES 7=NO
                            	   Sketchup.active_model.commit_operation###v2.9
                              	   Sketchup.active_model.start_operation "Mirror; Erase Original Selection"
                            	    Sketchup.active_model.selection.clear
                              	    copy_group.erase!
                            	    new_group.explode
                              	    nents.each{|e|Sketchup.active_model.selection.add(e)if e.valid?}###v3.0
                              	else
                                   new_group.explode
                                   copy_group.explode
                                   sents.each{|e|Sketchup.active_model.selection.add(e)if e.valid?}###v3.0
                            	end#if
                                self.reset
                                Sketchup.send_action "selectSelectionTool;"
                            end#def
                            def mirror_point(new_p)
                                if (@transformationType == @MIRROR_AT_PLANE)
                                    if (!new_p.on_plane?(@plane))
                                        mirrorp = new_p.project_to_plane(@plane)
                                        @trans = Geom;;Transformation.scaling(mirrorp, -1.0)
                                        new_p.transform!(@trans)
                                elsif (@transformationType == @MIRROR_AT_LINE)
                                    if (!new_p.on_line?(@line))
                                        mirrorp = new_p.project_to_line(@line)
                                elsif (@transformationType == @MIRROR_AT_POINT)
                                    if (!(new_p == @point))
                            end#def
                        end # class MirrorTool
                        ### menus ##############################################################
                               tb.add_item(cmd)
                                     menu.add_separator
                                  tb.show
                                  tb.restore
                        when you fail at something....you haven't really failed...you've found one way the thing will not work out
                          arjunmax09: All formatting is lost like that. Use the [code] tag to mark up code. Or preferably, when you got a longer piece of code like that, just upload the .rb file.
                            Please remove one of your duplicated posts - one is more than long enough ! [done, thanks]
                            Also, please put long bits of code inside a code/code-block - it keeps its formating and is easier to read/copy.
                            Your toolbar/menu part works fine for me - so you must have edited something else within the main text ???
                            Just copy your new part [below '###menus###...'] and then paste it over the equivalent section in a copy of the original script - it should then work...
                            Note that the last version is 3.1...
                            Are you picking suitable axes, points to actually give a 'mirror' ?
                              arjunmax09
                              yeah i'm picking the right axes, points to give a mirror.... only to find nothing...
                              πŸ˜• uh.... TIG I know zilch about ruby... I just followed the instructions given on the forum to modify my mirror plugin... but nothin' happened... I'm unable to understand the instructions that ur givin' on this post. Is it necessary that I keep the old mirror ruby in my folder as well as the new one... i.e. 2 ruby files for mirror in my plugins folder??
                                You only need one 'version' of the script.
                                It is a self-contained file with everything it needs inside it [unless of course it's the toolbar version which then needs the button's image file too]
                                Temporarily remove one of the scripts and see if the other one works...
                                Also try opening the Ruby Console [Windows Menu] and type in [or easier copy/paste it]
                                Sketchup.active_model.select_tool(MirrorTool.new)
                                then <enter> key.
                                Does the mirror tool then work or print an error etc ? πŸ˜•
                                Do you get prompted for the axes etc ?
                                What does the Ruby Console say when you run the tool in the four available ways - from Plugins Menu, Toolbar, Right-click Context-Menu and Typing in the command as above ?
                                Do you pick three discrete points that form something to mirror about - say one point on the group and then a point on the green axis and one on then blue axis ? You should then get a copy made and a request to keep/erase the original...
                                  arjunmax09
                                  • <enter> key.
                                  No ... it doesn't ....My older version of mirror plugin works just fine [i haven't tweaked it for the icon]... ..Can you upload your tweaked mirror script [ the one that uses the icon]so that i can use it????
                                  and... one more question..... I don't know ruby... is there a standard string that can be added to a ruby script so that i can make its custom toolbar or buttons work...??? I really hate scrolling through the plugins menu to get the one i want to use...
                                    See my edited post...
                                    Have you removed the 'working version' and retried in case they are clashing ?
                                    I actually don't have a toolbar version as I always use a shortcut key to run it. 😒
                                      arjunmax09
                                      Yeah... i've removed my 'workin version' and retried ....... the problem persists....
                                      Actually this is what happening...
                                      The objects that i want to mirror get recreated as a group on the spot itself. suppose i have a cube and next to it a sphere is there....
                                      i select the sphere and cube using the shift key...
                                      next i click on mirror button
                                      next... i draw a line along green axis
                                      now... i draw my path across blue axis...
                                      ..... the two objects get grouped together on the spot...
                                      i can't seem to figure out the problem 😞
                                        It groups them to do the mirroring then explodes the group back as it was - if it's working...
                                        I have decided I will add the tool button to the script for you and ensure it's working, then post it.
                                        Can you post the .png button image for me please... ❓
                                        EDIT: no need I found it...
                                          Here's v3.2 with the toolbar option added.
                                          Otherwise the script's workings are unchanged.
                                          It's been fully tested and works when activated from the Menu, the Context-Menu, a Shortcut or the new Toolbar.
                                          If the MI.png file is not found with the .rb file then the toolbar is NOT made.
                                          You can activate this new 'Mirror' toolbar from View>Toolbars.
                                          Put these 2 files into 'Plugins' - you can omit MI.png [or rename] it if you don't want a toolbar.Mirror.rbMI.png
                                          πŸ€“
                                          EDIT: NOTE THAT THE LATEST VERSION IS NOW AVAILABLE HERE http://forums.sketchucation.com/viewtopic.php?p=276512#p276512
                                          • broomstickB Offline
                                            broomstick
                                            I think a variant of the Mirror Plugin, should consider creating a toolbar with 3 buttons: each one would perform the mirror simmetrically to one of the axis, asking before the operation to click on the plane to define the start of the mirror line.
                                            It would work similarly to rot90 plugin, but for the mirror.
                                            I hate myself for not being able to code, otherwise I'd do it myself!
                                            • 2 / 2
