    What's your beginners tip?
    305 Posts 169 Posters 453.9k Views 169 Watching
    • majidM
      majid
      set your units first
      pay careful attention to "OPTIONS" while importing/exporting.
      be skillful on selection methods.(usinf context meno, shift , Ctrl,...)
      make group/components (depending on your aim) to avoid "gluing" all objects to each other.
      while you have even 2 repetitive object, start using components instead of doing repetitive jobs.
      • H
        halane34
        Como todavía soy un principiante, toma esto por lo que vale la pena. La mejor ayuda para mí fue la serie de Aidan Chopra de videos en YouTube. Ahora también tienen la guía complementaria .. "de SketchUp para Dummies". Está muy claro que habla y fácil de entender y tiene un montón de buenas sugerencias. Es perfecto para un novato de gráficos 3D como yo!
        Espero que esto ayude!
        • K
          KXI System
          Translation:
          As I'm still a beginner, take this for what it's worth. The best help for me was the number of Aidan Chopra videos on YouTube. Now also have the companion guide .. SketchUp for Dummies ". It's very clear and easy to understand speech and has lots of good suggestions. It's perfect for beginners to 3D graphics as I do hope this helps!
          SO true!
          Getting the perfect sig is hard...
          Google it!
            Mensa
            These tips helped greatly, thanks!
              mm5949
              It took me a while, but I finally learned the "Intersect with Model" tool. This is a good (only?) way to make accurate mortise and tenons for woodworking. It's explained on page 222 of the (downloadable...887 pages!) SU User's Guide which I downloaded from the official SU website (at http://sketchup.google.com/support/bin/answer.py?hl=en&answer=116174). It is a powerful tool. ☀
              • V
                vindemiatrix
                hello everyone and all the french community in the world ^^ my tips for beginners it's to learn with the video on youtube cut your screen in two , one youtube one sketchup and practice on one things everyday first the basics with sketchup4school but they are american so it's hard to undrestand because of there texas accent eating bublle gum ^^
                and go far , found "good" technical tuto is quite difficult like how using the light in vray or how smooth or connect the edge but there is !!!
                like "andeciuala" he speak a undertandle englih speak slowly i think he was indian cool people and explain very well and so technic amazing i use a plugin for firefox to save this tuto it's download helper a free plugin that's all .
                i design for jewellery in france .
                win 7 64bit , 8go ,nvidia 320gt,intel i3 5300 with two screen perfect for sketchup 22" & 21"
                • C
                  chrisjk
                  To save the palaver of deleting a lot of unwanted geometry after using an intersect operation, I find Bool Tools from Smustard indispensable.
                  • B
                    bob-designer
                    Never draw anything twice. Never draw anything twice. In my cad days it was Blocks.
                    In SU, make it a component. My tip, Bob
                      ScrubBurnRepeat
                      use the shift key, early and often.
                      08-Feb-2010 edit: avoid using mouse to select "hide" from context-click menu. every once in a while the mouse will mistakenly click "erase", and the result will appear the same as if mouse had clicked "hide". Unfortunately, much later (even later after a few unhide-all's) you will wonder to where some parts have disappeared.
                        jessemorton24
                        CONVERT INTERSECTION CONTOUR LINES TO UNIFORM B SPLINES FROM FREDO's PLUGIN!!! THEN EXTRUDE BY RAILS!!!! FROM TIG's PLUGGINS!!! ANYTIME YOU INTERSECT TO FACES TO CREATE A CONTOUR LINE FOR COMMAND EXTRUDE PROFILE AND RAILS!!.. AND DO IT AT 100!!!! SO IT IS SOFT AS A BABY'S BOBO!!
                        Parkways, Driveways, Gateways, Pathways...
                        • mitcorbM
                          mitcorb
                          It may have been said several times in this topic:
                          Go through all of the 9 or so pages in this thread.
                          Then look up the Duh/Doh thread. There "may" be some gems there, too.
                          • G
                            GoldenFrog
                            @pmolson said:
                            Beginners of an appropriate age of course.
                            Awww...really? 🤣
                            Remember, great minds think alike, and fools never differ.
                            • leedeeteeL
                              leedeetee
                              I've no idea if this has been covered before but one think I have just discovered (embarassing!) is the fact that when moving/rotating groups or components, rather than having to use the rotate tool (which can be tricky if the object hasn't a flat face, e.g a person or a tree) you can just use the move function and rotate with the little red crosses that appear on the faces.
                              I know this is probably old news but it saved me a load of time/heartache. 😳
                              • I
                                iiian2009
                                As a beginner myself, I don’t feel that I am really qualified to give tips, but … I have found that learning to use layers properly has helped me enormously. By turning on and off layers, you can access and see parts of your model that would otherwise be very difficult to work on. Imagine if you could do this in real life - you would be able to scratch your feet without taking your shoes and socks off! Bliss!
                                • GaieusG
                                  @iiian2009 said:
                                  As a beginner myself, I don’t feel that I am really qualified to give tips...
                                  This is not true. There is nothing more important in the learning process than these "enlightenment" moments and sharing them with other beginners can bring seemingly basic but not necessarily obvious things (more experienced users may not even think about) to their attention.
                                  Now as for your "discoveries"; if you turn some layers off and make a scene (View > animation > add scene - or when you already have one, just rightclickon the tab and "add..." or add one from the scene manager - see below) then turn them on again and make another scene, next time you do not even have to go and turn them on - just click on the scene tab and the parts "vanish".
                                  Best is to open your scene manager (Window menu) and uncheck the "camera location" and "Include animation" when you only use the scenes for working. Don't forget to refresh the scenes if you make any changes in existing ones.
                                  • G
                                    gabwil
                                    maybe the wrong place for this question...
                                    Is there one place to see all available plugins?
                                    I find posts about the ones I want but have a hard time finding the actual file for download. I am looking for: line_normals
                                    gabwil
                                    • GaieusG
                                      Hi Gabwil,
                                      Here is an extension index where you can find most of the plugins ever published and here is a list of plugins published on these forums (some are not listed in the index above). The actual plugins are generally attached to the bottom of the very first post (by the author) in each topic.
                                      • X
                                        xrok1
                                        and the #1 beginner tip is.... post a picture (even 2d or hand drawn!) of what your trying to acheive with your question****!!!!!**** 👿
                                        • G
                                          gonegoing
                                          Learn keyboard shortcuts. It really speeds things up
                                          Another one: When you export an image do so at about 3000 pixels. Then reduce image size in Photoshop to smooth the lines.
                                            Dadoing
                                            1. If you use Microsoft Office, check out MS OneNote for collecting and organizing notes about SU.
                                            2. First time you open Sketchup to see what it's all about, consider setting it up to look like the attached image. Check out View/Toolbars.
                                            Problem with Sketchup is it's more fun than cleaning up sawdust and sharpening tools.
                                            • 15
                                            • 16
                                            • 7 / 16
