    What's your beginners tip?
    305 Posts 169 Posters 453.9k Views 169 Watching
    • pmolsonP
      pmolson
      First open beer, then open sketchup!
      pmo
      • ToboboT
        Tobobo
        I have one,
        If you are working in a big detailed model that is slow to open or change scenes. Set up a scene with only the basic geometry on so you can use it to move around. This is helpful when creating an animation.
        Toby
        Philippians 4:13
        • pmolsonP
          pmolson
          Beginners of an appropriate age of course.
          • F
            flyashy
            Remember that once you've changed the arc/circle segment resolution ( by typing the number of segments in the mesurements window while drawing them i.e. 100s instead of 24s etc) it remains that way until you change it again.
            For example let's say you're drawing a 50' Dia. Circle it'll be all right to type in a large number of segments, but then it'll stay at that number for any new circles you draw. so you might end up drawing 200 segment circles for a 3" dia Pipe component and your model will just collapse under all the weight of edges!
            The easier way to have finer segmented curves is to change the resolution afterwards from the entity info window.
            • majidM
              majid
              set your units first
              pay careful attention to "OPTIONS" while importing/exporting.
              be skillful on selection methods.(usinf context meno, shift , Ctrl,...)
              make group/components (depending on your aim) to avoid "gluing" all objects to each other.
              while you have even 2 repetitive object, start using components instead of doing repetitive jobs.
              • H
                halane34
                Como todavía soy un principiante, toma esto por lo que vale la pena. La mejor ayuda para mí fue la serie de Aidan Chopra de videos en YouTube. Ahora también tienen la guía complementaria .. "de SketchUp para Dummies". Está muy claro que habla y fácil de entender y tiene un montón de buenas sugerencias. Es perfecto para un novato de gráficos 3D como yo!
                Espero que esto ayude!
                • K
                  KXI System
                  Translation:
                  As I'm still a beginner, take this for what it's worth. The best help for me was the number of Aidan Chopra videos on YouTube. Now also have the companion guide .. SketchUp for Dummies ". It's very clear and easy to understand speech and has lots of good suggestions. It's perfect for beginners to 3D graphics as I do hope this helps!
                  SO true!
                  Getting the perfect sig is hard...
                  Google it!
                    Mensa
                    These tips helped greatly, thanks!
                      mm5949
                      It took me a while, but I finally learned the "Intersect with Model" tool. This is a good (only?) way to make accurate mortise and tenons for woodworking. It's explained on page 222 of the (downloadable...887 pages!) SU User's Guide which I downloaded from the official SU website (at http://sketchup.google.com/support/bin/answer.py?hl=en&answer=116174). It is a powerful tool. ☀
                      • V
                        vindemiatrix
                        hello everyone and all the french community in the world ^^ my tips for beginners it's to learn with the video on youtube cut your screen in two , one youtube one sketchup and practice on one things everyday first the basics with sketchup4school but they are american so it's hard to undrestand because of there texas accent eating bublle gum ^^
                        and go far , found "good" technical tuto is quite difficult like how using the light in vray or how smooth or connect the edge but there is !!!
                        like "andeciuala" he speak a undertandle englih speak slowly i think he was indian cool people and explain very well and so technic amazing i use a plugin for firefox to save this tuto it's download helper a free plugin that's all .
                        i design for jewellery in france .
                        win 7 64bit , 8go ,nvidia 320gt,intel i3 5300 with two screen perfect for sketchup 22" & 21"
                        • C
                          chrisjk
                          To save the palaver of deleting a lot of unwanted geometry after using an intersect operation, I find Bool Tools from Smustard indispensable.
                          • B
                            bob-designer
                            Never draw anything twice. Never draw anything twice. In my cad days it was Blocks.
                            In SU, make it a component. My tip, Bob
                              ScrubBurnRepeat
                              use the shift key, early and often.
                              08-Feb-2010 edit: avoid using mouse to select "hide" from context-click menu. every once in a while the mouse will mistakenly click "erase", and the result will appear the same as if mouse had clicked "hide". Unfortunately, much later (even later after a few unhide-all's) you will wonder to where some parts have disappeared.
                                jessemorton24
                                CONVERT INTERSECTION CONTOUR LINES TO UNIFORM B SPLINES FROM FREDO's PLUGIN!!! THEN EXTRUDE BY RAILS!!!! FROM TIG's PLUGGINS!!! ANYTIME YOU INTERSECT TO FACES TO CREATE A CONTOUR LINE FOR COMMAND EXTRUDE PROFILE AND RAILS!!.. AND DO IT AT 100!!!! SO IT IS SOFT AS A BABY'S BOBO!!
                                Parkways, Driveways, Gateways, Pathways...
                                • mitcorbM
                                  mitcorb
                                  It may have been said several times in this topic:
                                  Go through all of the 9 or so pages in this thread.
                                  Then look up the Duh/Doh thread. There "may" be some gems there, too.
                                  • G
                                    GoldenFrog
                                    Awww...really? 🤣
                                    Remember, great minds think alike, and fools never differ.
                                    • leedeeteeL
                                      leedeetee
                                      I've no idea if this has been covered before but one think I have just discovered (embarassing!) is the fact that when moving/rotating groups or components, rather than having to use the rotate tool (which can be tricky if the object hasn't a flat face, e.g a person or a tree) you can just use the move function and rotate with the little red crosses that appear on the faces.
                                      I know this is probably old news but it saved me a load of time/heartache. 😳
                                      • I
                                        iiian2009
                                        As a beginner myself, I don’t feel that I am really qualified to give tips, but … I have found that learning to use layers properly has helped me enormously. By turning on and off layers, you can access and see parts of your model that would otherwise be very difficult to work on. Imagine if you could do this in real life - you would be able to scratch your feet without taking your shoes and socks off! Bliss!
                                        • GaieusG
                                          @iiian2009 said:
                                          As a beginner myself, I don’t feel that I am really qualified to give tips...
                                          This is not true. There is nothing more important in the learning process than these "enlightenment" moments and sharing them with other beginners can bring seemingly basic but not necessarily obvious things (more experienced users may not even think about) to their attention.
                                          Now as for your "discoveries"; if you turn some layers off and make a scene (View > animation > add scene - or when you already have one, just rightclickon the tab and "add..." or add one from the scene manager - see below) then turn them on again and make another scene, next time you do not even have to go and turn them on - just click on the scene tab and the parts "vanish".
                                          Best is to open your scene manager (Window menu) and uncheck the "camera location" and "Include animation" when you only use the scenes for working. Don't forget to refresh the scenes if you make any changes in existing ones.
                                          • G
                                            gabwil
                                            maybe the wrong place for this question...
                                            Is there one place to see all available plugins?
                                            I find posts about the ones I want but have a hard time finding the actual file for download. I am looking for: line_normals
                                            gabwil
                                            • 15
                                            • 16
                                            • 6 / 16
