    [plugin] Ruby Code Editor - UPDATED to v3.0 3/4/2013
    56 Posts 11 Posters 44.3k Views 11 Watching
      driven
      a possibly naive question from one your target end users,
      I'm teaching myself ruby on a mac
      I have a very Ruby for SU text book that is in PDF format on my hard-drive, I want to access it through the reference menu on your console, (which does throw up some code errors, but still mostly works)
      Is it possible, or could I put it on my website and read it from there (less preferable as the books not published yet)?
        driven
        @Dan,
        thanks a lot for that, I went round in circles trying to get the pdf file to load using #{ENV['HOME']} but eventually just dragged the file in with out that there and it opens the doc on top of SU, but can I get it to stay on top while I use SU? I want to copy paste bits and bobs straight into ruby console.
        #  helpmenu.rb
        #  Created by Dan Rathbun on 14/02/2010.
        #  Copyright (c) 2010 @SCF. No? rights reserved.
        # helpmenu.rb for PLAT=Mac & OS=OSX
        module SU_User
          module Menus
            helpmenu=UI.menu('Help')
            helpmenu.add_separator
            # Edit the 'Your TextBook Title' Menu Item Title below
            # Edit the pathname to your textbook pdf file below
            helpmenu.add_item('TextBook') {
              UI.openURL("file;//localhost/Users/johns_iMac/Documents/Learning_rubies/TextBook.pdf")
            #   #{ENV['HOME']} inside a double-quoted string    ##### couldn't get  #{ENV['HOME']} to work, but just draging the pdf file into the double quotes works
            #   should return something like; '/Users/John' on the Mac
            #   For PC, the HOME variable must be changed to USERPROFILE
          end # module Menus
        end # module SU_User
        %(#004000)[So, that just open pdf in preview, but this does what I'm after a modal wd pdf, on a Mac you can work under show_modal
        get_dialog = UI;;WebDialog.new
        get_dialog.show_modal
        (get_dialog.set_url "file;//localhost/Users/johns_iMac/Documents/Learning_rubies/TextBook.pdf")
        what I can't figure is how to get the help item (such a good place to put it) to trigger this??]
          driven
          GOT IT....
          #  helpmenu.rb
          module SU_User
            module Menus
              helpmenu.add_item('TextBook') { get_dialog = UI;;WebDialog.new
          (get_dialog.set_url "file;//localhost/Users/johns_iMac/Documents/Learning_rubies/TextBook.pdf")}
            end # module Menus
          Not only does pdf's I can follow Kirill tutorials inside of SU
          • Dan RathbunD Offline
            Dan Rathbun
            @driven said:
            @Dan, thanks a lot for that, I went round in circles trying to get the pdf file to load using #{ENV['HOME']} but eventually just dragged the file in with out that there and it opens the doc on top of SU, but can I get it to stay on top while I use SU? I want to copy paste bits and bobs straight into ruby console.
            No problem!
            Don't worry about copyright. It's so simple and really just slightly modified version of the code snippet from the API. Assigning a copyright would be like tying to patent the chemical formula H2O.
            Apparently the UI.openURL argument requires (on the Mac,) the protocol 'file://localhost' before the HOME variable. For a trully generic loadstring (if you were to change your username,) this should work as well (all one line):
            UI.openURL("file://localhost#{ENV['HOME']}/Documents/Learning_rubies/TextBook.pdf")
            URLs work slightly different on PC and Mac.
            Anyway... it was a good learning exercise for you.
            I'm not here much anymore.
              driven
              Thanks again Dan,
              I'll globalise it, and do you have any objections to me posting this ruby for others, less interested in doing it themselves... I think really handy.
              the next thing I've been attempting is to make this RubyCodeEditor to .show_modal.
              then I can, read the text, copy paste edit in RCE and see the result in web console, without constantly changing screens.
              any ideas where to implement that in nsnSketchupApi.rb
              or am I in completely the wrong place EDIT: Yes , it's completely the wrong ruby, I guess that's why that doesn't work, I'm learning a at least now to dig through the right rubies...
                Dan Rathbun
                This is something Alex can do when he gets the User Preferences options part done. He can add an option for Mac users to check a box and then put a conditional statement in the code.
                Some thing like:
                if RUBY_PLATFORM.include?('darwin') %(#F0F0F0)[__]OPTIONS['MacShowModal'] ? show_modal() : show() else # it's a PC %(#F0F0F0)[__]show() end #if
                or you can just change the show to show_modal near he end of the code (for your copy, til Alex gets to releasing his next version.)
                  Except that you can't create modal webdialogs on Mac. A modal form on the Mac only makes it stay on top of SU's window - but not modal.
                    Dan Rathbun
                    Well handy yes, but not all that 'special'. There are numerous plugins around that put help links on the menus. (One by Didier and TBD that will search all folders under Plugins and create links to any help file type, like .pdf, .txt, .chm, .hlp, .htm, etc... automatically.)
                    There is a problem with your version. You have the new constructor inside the command block without a conditional check to only create a new instance if it has not yet been done. Repeated clicking on the menu would create extra WebDialog objects, wasting space on the stack.
                    Either move the constructor statement before the 'helpmenu.add_item' line, or add
                    ' get_dialog=false' before it and change the constructor inside the {} block to:
                    ' get_dialog = UI::WebDialog.new if not get_dialog'
                    Probably the 2nd is best, so the WebDialog object doesn't get created unless the menuitem is actually clicked.
                      Dan Rathbun
                      He knows, we know. That's really what he wants... it to stay on top.
                        Dan Rathbun
                        FYI: On the PC, Windows ignores 'file://localhost/' and strips it off when it passes the path to whatever application is registered to open the filetype. If it's a .txt it will likely open in Notepad, if a .pdf it will open in Adobe Acrobat Reader, etc.
                          driven
                          Exactly, the Mac 'flaw' is the best feature
                          Dan, I got this far last night and I'll have another look, with your new input in mind, but what do think??
                          > #  _PDF_Viewer.rb
                          > #  seems to only work with adobe pdf format, but that's what safari saves pdfs to, so if it won't open, re-save from safari
                          > #  seems to open most image files at full size so you may want smaller copies, export to mail and post to self is cheap and easy,
                          > #  batch conversion, or graphics convertor.
                          > #  helpmenue.rb Created by Dan Rathbun on 14/02/2010.
                          > #  2010 @SCF. No? rights reserved.
                          > #  modified for modal Mac usage by john@drivenupthewall.co.uk
                          > #  show_modal works differently on PC's
                          > #  user selected pdf + image veiwer
                          > #  for PLAT=Mac & OS=OSX
                          > module SU_User
                          >    module Menus
                          > require "sketchup.rb"
                          > # Check to see if the plugin is already loaded
                          > if not file_loaded? "_PDF_Viewer.rb"
                          > # where to look for it
                          > # it's name in the Help menu
                          >    helpmenu.add_item('PDF_Viewer') {
                          >       file = UI.openpanel;
                          >       get_dialog = UI;;WebDialog.new;
                          >       get_dialog.show_modal;
                          >       get_dialog.set_url(file)
                          >   end
                          >     end
                          >  file_loaded "_PDF_Viewer"
                          > end
                          If I move get_dialog.set_url(file) to the top will that allow multi-windows? I do get new file, iff I shut the first window
                          chee
                          #  _PDF_Viewer.rb
                          module SU_User
                             module Menus
                          cheers
                            ? It's terrible. Makes it impossible to make replacements for UI.inputbox.
                              driven
                              I'll more than likely agree if/when I get to that stage in coding, but being able to simply float the 'TextBook' over SU has already increased my workflow, so for now I see it as a blessing which I may curse later on...
                              BTW: I found the your 'missing manual' page helpful, but only found it through google after I almost last-night.
                                Yea - it'd odd that show on PC keeps the window ontop of SU, while on OSX it doesn't. So much for consistency. πŸ˜’
                                ??? == osx.show() pc.show() == osx.show_modal() pc.show_modal() == ???
                                Oh the sanity of being a SketchUp scripter!
                                  driven
                                  on the PC, if you are watching a tutorial in a wd viewer, can you pause to draw and still see the video, or does it jump to the back,under SU, where you have to go find it to carry on?
                                    Webdialogs on PC created using .show() is always parent to the SU window and will stay on top. Like SU's toolwindows.
                                      Dan Rathbun
                                      Check out these links (bookmark them!):
                                      Sketchup Ruby resources
                                      http://forums.sketchucation.com/viewtopic.php?f=180&t=10142
                                      Developer's Forum Sticky Links
                                      http://forums.sketchucation.com/viewtopic.php?f=180&t=20427
                                      State of Observers
                                      http://forums.sketchucation.com/viewtopic.php?f=180&t=20676
                                        driven
                                        cheers for those Dan, it is a bit hard to navigate this forum, when your not quite sure what your looking for...
                                        don't suppose you know a way of turning off
                                        UI.play_sound(Sketchup.get_resource_path("video/fera.mp3"))
                                        #in sync with
                                        when "stop"
                                        		UI.stop_timer @timer1;"video/fera.mp3"
                                        I know this dosen't work but I can't find any method of having the sound pause or stop when I turn off the video texture, which I can turn on and of at will.
                                        I could change a new page and switch to another .mp3 (blank), but as an exercise I'm trying to avoid that as instead off pause, continue, need to start over to keep in sync...
                                          chyn2000
                                          I wanted to say that this is an AWESOME plugin!
                                          Some functionality suggestions that (IMHO) would make your interface even more invaluable:
                                          Add break point capability:
                                          At break points, the pluging could add a popup before execution (behind the scenes, not in the viewable text field). The user would just press 'OK' to continue on.
                                          Add Escape or Kill button:
                                          The Escape would be an emergency breakout to stop execution if the user created an inf loop. Maybe force inserted into any loop conditions (again, behind the sceens).
                                          Add Variable Watcher window:
                                          This might be pretty hard, but then maybe not, but also a variable watcher window sharing the space with the results/error window. I could see this working by having pairs of fields. Type the variable name in one field and the program updates that fields pair with the in scope value.
                                          Reduce Web Console's realestate during execution:
                                          Have the option to hide, minimize or make the Web Console transparent during code execution.
                                          Just some suggestions, though I'm sure you are busy doing things that actually make you money so you can pay for internet access (oh, and I guess eat and have a place to sleep too... πŸ˜‰ )
                                          Cheers!
                                          Reg
                                            Dan Rathbun
                                            @driven said:
                                            don't suppose you know a way of turning off ...
                                            This needs to be broken off into a new thread. It's far removed from the WebConsole/RubyEditor discussion.
                                            (and sorry.. John, I don't mess with sound in Sketchup or WebDialogs. My only suggestion would be to embed a media player of some kind in the webpage. Check up on the html OBJECT tag. [EMBED and APPLET are deprecated.])
                                            http://msdn.microsoft.com/en-us/library/ms535859(VS.85).aspx
                                            • 2 / 3
