    [plugin] Ruby Code Editor - UPDATED to v3.0 3/4/2013
    56 Posts 11 Posters 44.3k Views 11 Watching
    • alexschreyerA Offline
      alexschreyer Extension Creator
      Thanks, Dan, for going through this so thoroughly. Everyone, please feel free to suggest code improvements. I would like to make this as useful as possible. Of course, I'll mention every help on the "About" tab.
      @Dan: I'll incorporate your revisions into the output code. That is really the part here that I had looked at the least.
      I like the idea of having tabbed multiple files. With the current tab support that should be relatively easy to implement.
      And thanks for the hint on the Windows UI look for IE. I didn't even know about the tag.
      Cheers,
      Alex
      Author of "Architectural Design with SketchUp":
      http://sketchupfordesign.com/
      • Dan RathbunD Offline
        Dan Rathbun
        I think I see another problem. If an error occurs don't you need to abort the operation instead of committing it?
        Try something like this:
          add_action_callback("exec") do |webconsole_dialog, p|
            v = webconsole_dialog.get_element_value('console').strip
            # puts v    # what's this for -- testing ??
            r = nil
            begin
              Sketchup.active_model.start_operation "RubyEditor"
              begin # evaluation
                r = eval v
              rescue => e
                r = e
                raise # pass to outer rescue clause
              end # eval
            rescue
              Sketchup.active_model.abort_operation
            else # only do if NO errors
              Sketchup.active_model.commit_operation
            ensure # always do this
              r!=nil ? r = r.to_s ; r='nil'
              p r
              r.gsub!(/ /, " ")
              r.gsub!(/\n/, "<br>")
              r.gsub!(/'/, "&rsquo;")
              r.gsub!(/`/, "&lsquo;")
              r.gsub!(/</, "&lt;")
              webconsole_dialog.execute_script("document.getElementById('results').innerHTML='#{r}'")
          end # callback
        I'm not here much anymore.
          Dan Rathbun
          Alex.. you did not change the Name of the DefaultSettings Key ('WebCon'), so your plugin is overwriting the values for Jim's standard WebConsole in the registry.
          There is always the possibilty that some people may still wish to use Jim's "plain Jane" version from time to time, even with yours installed.
          You should setup a unique Keyname for your defaults.
            I'll change the dialog name. Must have overlooked that one. I changed the class name.
            In the meantime, I figured out how to get linebreaks from a file into a dialog.
            filename = UI.openpanel
            f = File.new(filename,"r")
            text = f.readlines.join.gsub!(/\n/, '<KghBr31sD>')
            ndlg = UI;;WebDialog.new("Ruby Web Console", true, "WebCon123", 600, 400, 100, 100, true)
            ndlg.set_html ("<html><head></head><body><textarea style='width;100%;height;100%' name='mybox' id='mybox'></textarea></body></html>")
            ndlg.show {
              ndlg.execute_script("var text = '#{text}';var asddsa = text.replace(/<KghBr31sD>/g,String.fromCharCode(13));document.getElementById('mybox').value = asddsa")
            I think I saw the method (i.e. using a gibberish tag) discussed recently in the developers forum. I'll give that a try soon.
            Cheers,
            Alex
            • chrisglasierC Offline
              chrisglasier
              @alexschreyer said:
              @chrisglasier: ... It can very well work with my editor.
              It is not your editor it belongs to Jim; what you did, as I did, was to dress it up. But I don't want to focus on individual efforts but more on why the cognoscenti allow software companies to fob us off with metaphors for paperwork rather than providing digital machines.
              Take for example your original cheat sheets and my/Jim's Sketchup API digital device which provided an opportunity to link up many other devices like the console. The style is not an issue and you are more adept at implementing the links than an amateur and reluctant coder like me; the code is freely available here.
              I am very disappointed that you ignored this opportunity to exploit a way to link up data (that belongs to objects that have names) and digital devices (that can automate common tasks).
                @chrisglasier: I see now where you are coming from. My idea with my revision of Jim's Web Console was to make it more functional and spruce up the visuals but keep it easy enough for the beginning coder. I'll look again at your approach with the namesets but it seemed to me at the time to complicate things. I guess I just don't fully understand it yet.
                I am all for collaboration and combining efforts, though.
                Cheers,
                Alex
                  Dan Rathbun
                  Just a note on personal preference.
                  If you use the META tag I gave you previously, the buttons (New, Open, Save, Quit) take on the look of the nice XP style buttons (rounded corners & which hilite on hover, etc.) They look just as they do in native dialogs.
                  The jQuery buttons you have used take up more space (especilally height-wise) and have the look of the old MS Frontpage styling, which I have always hated.
                  I prefer the native XP look.
                    @Dan: You are right, going with the OS styling also makes sense to keep elements looking "native" on Win and Mac.
                    I wanted to go with the jQuery UI framework, though, so that a) the dialog looks exactly the same on Win and Mac and b) later I could offer different styling to users, so that they can pick their preference from a dropdown. The UI system has various nice templates:
                    http://jqueryui.com/themeroller/
                    One question: I have to save some preferences (like the UI selection) locally. Can I reliably use cookies or should I go with an ini file?
                    Cheers,
                    Alex
                      Cookies can be purged by the user or utilities that clean the browser data. Safest is to store it separately.
                        Dan Rathbun
                        Agreed.
                        You can use Sketchup.write_default and Sketchup.read_default to save settings in the Registry (Win32) or plist files (Mac) but they have a few disadvantages.
                        Once you create a key, you cannot remove it, so they can become cluttered with old setting keys that are not used anymore.
                        And they can be only 1 level of heirarchy, even though the Windows Registry supports any numbers of levels. (It's a tree structered database.) Perhaps this is a limitation of the Mac plists and Google is enforcing it on both platforms for 'sameness'?
                        Also.. XP Home has a Registry limit size (I'm constantly on the edge of it and often get the Registry Limit reached Warnings. If I'd known about it I would have paid the extra and bought XP Pro.)
                        Anyhow.. an ini (or any settings file,) would give you complete freedom.
                        It doesn't need to be an ini format. It can be simply a ruby script that decalres a Settings Hash wrapped in your plugin namespace. Did you know that Module and Class definitions can be split up into multiple files? They can. The main file can be the functional part of the class definition, and the other can be just a Hash declaration inside the same class namespace, that gets loaded by the first (if it exists,) and gets RE-written by the first file, when changes to the settings are made.
                          Never knew that.
                          ...how much stuff you got installed? I've installed lots of random stuff on my old xp box through up the years - never had that warning.
                            Dan Rathbun
                            @thomthom said:
                            Never knew that.
                            TOO much stuff! OpenOffice Suite, AutoCAD, Epson Scanner Software, Windows SDK, MS VisualStudio (w/ VB, C#, C++, SQL Server), Debugging Tools for Windows, Windows Support Tools, PowerToys for Windows XP, MS HTML Help Workshop, PCB123, AdobeReader, Paint.NET, NotePad++, SciTE, FamilyOrigins (Genealogy dBase), Google Sketchup 7.x, Google Earth. ..etc...
                            (And at one time 2 full versions of MS Flight Simulator; which I uninstalled.)
                            I believe I didn't get the errors until after I installed AutoCAD. I can't find the exact error message at a MS search, but did find an article dated 2007 that says the RSL (Registry Size Limit) "no longer applies" to Windows XP or Windows Server 2003. But I know I have got the error popup after that.
                            @Alex: Thinking more about this. You don't need need to worry at all regarding this issue. The RSL applies only (if it even does anymore,) to the System Hive of the Registry. Sketchup settings are saved in the User Hive, which does not have (or never had) any size limit.
                              Dan Rathbun
                              It doesn't need to be an ini format. It can be simply a ruby script that decalres a Settings Hash wrapped in your plugin namespace. ... that gets loaded by the first (if it exists,) and gets RE-written by the first file, when changes to the settings are made.
                              If Js is more comfy for you, the same technique can be used but in Js. A ruby method can write out a Js script that is a JS object holding settings, or an Array of settings, or global varibales, whatever.
                              The file just gets loaded with the webpage.. no complex parsing required.
                              If the user makes settings changes.. you send them to a ruby callback that overwrites the settings .js file.
                              Also if you wish to change CSS dynamically you'll need to assign ID attributes to the stylesheets (whether inline or loaded via LINK tag.)
                                Thanks for the recommendations, guys. I actually went with the easiest version (cookies) for now since I was able to implement this without hassle. I'll look at file storage later.
                                Didn't know that the registry could actually become too large. I never ran into this problem. And I have several Autodesk products installed (those are huuuge - though mostly by filesize! When will ADSK finally cut down on bloating their own software).
                                Cheers,
                                Alex
                                  driven
                                  a possibly naive question from one your target end users,
                                  I'm teaching myself ruby on a mac
                                  I have a very Ruby for SU text book that is in PDF format on my hard-drive, I want to access it through the reference menu on your console, (which does throw up some code errors, but still mostly works)
                                  Is it possible, or could I put it on my website and read it from there (less preferable as the books not published yet)?
                                    driven
                                    @Dan,
                                    thanks a lot for that, I went round in circles trying to get the pdf file to load using #{ENV['HOME']} but eventually just dragged the file in with out that there and it opens the doc on top of SU, but can I get it to stay on top while I use SU? I want to copy paste bits and bobs straight into ruby console.
                                    #  helpmenu.rb
                                    #  Created by Dan Rathbun on 14/02/2010.
                                    #  Copyright (c) 2010 @SCF. No? rights reserved.
                                    # helpmenu.rb for PLAT=Mac & OS=OSX
                                    module SU_User
                                      module Menus
                                        helpmenu=UI.menu('Help')
                                        helpmenu.add_separator
                                        # Edit the 'Your TextBook Title' Menu Item Title below
                                        # Edit the pathname to your textbook pdf file below
                                        helpmenu.add_item('TextBook') {
                                          UI.openURL("file;//localhost/Users/johns_iMac/Documents/Learning_rubies/TextBook.pdf")
                                        #   #{ENV['HOME']} inside a double-quoted string    ##### couldn't get  #{ENV['HOME']} to work, but just draging the pdf file into the double quotes works
                                        #   should return something like; '/Users/John' on the Mac
                                        #   For PC, the HOME variable must be changed to USERPROFILE
                                      end # module Menus
                                    end # module SU_User
                                    %(#004000)[So, that just open pdf in preview, but this does what I'm after a modal wd pdf, on a Mac you can work under show_modal
                                    get_dialog = UI;;WebDialog.new
                                    get_dialog.show_modal
                                    (get_dialog.set_url "file;//localhost/Users/johns_iMac/Documents/Learning_rubies/TextBook.pdf")
                                    what I can't figure is how to get the help item (such a good place to put it) to trigger this??]
                                      driven
                                      GOT IT....
                                      #  helpmenu.rb
                                      module SU_User
                                        module Menus
                                          helpmenu.add_item('TextBook') { get_dialog = UI;;WebDialog.new
                                      (get_dialog.set_url "file;//localhost/Users/johns_iMac/Documents/Learning_rubies/TextBook.pdf")}
                                        end # module Menus
                                      Not only does pdf's I can follow Kirill tutorials inside of SU
                                        Dan Rathbun
                                        @driven said:
                                        @Dan, thanks a lot for that, I went round in circles trying to get the pdf file to load using #{ENV['HOME']} but eventually just dragged the file in with out that there and it opens the doc on top of SU, but can I get it to stay on top while I use SU? I want to copy paste bits and bobs straight into ruby console.
                                        No problem!
                                        Don't worry about copyright. It's so simple and really just slightly modified version of the code snippet from the API. Assigning a copyright would be like tying to patent the chemical formula H2O.
                                        Apparently the UI.openURL argument requires (on the Mac,) the protocol 'file://localhost' before the HOME variable. For a trully generic loadstring (if you were to change your username,) this should work as well (all one line):
                                        UI.openURL("file://localhost#{ENV['HOME']}/Documents/Learning_rubies/TextBook.pdf")
                                        URLs work slightly different on PC and Mac.
                                        Anyway... it was a good learning exercise for you.
                                          driven
                                          Thanks again Dan,
                                          I'll globalise it, and do you have any objections to me posting this ruby for others, less interested in doing it themselves... I think really handy.
                                          the next thing I've been attempting is to make this RubyCodeEditor to .show_modal.
                                          then I can, read the text, copy paste edit in RCE and see the result in web console, without constantly changing screens.
                                          any ideas where to implement that in nsnSketchupApi.rb
                                          or am I in completely the wrong place EDIT: Yes , it's completely the wrong ruby, I guess that's why that doesn't work, I'm learning a at least now to dig through the right rubies...
                                            Dan Rathbun
                                            This is something Alex can do when he gets the User Preferences options part done. He can add an option for Mac users to check a box and then put a conditional statement in the code.
                                            Some thing like:
                                            if RUBY_PLATFORM.include?('darwin') %(#F0F0F0)[__]OPTIONS['MacShowModal'] ? show_modal() : show() else # it's a PC %(#F0F0F0)[__]show() end #if
                                            or you can just change the show to show_modal near he end of the code (for your copy, til Alex gets to releasing his next version.)
                                            • 2 / 3
