    [Plugin] Manifold v2.2
    126 Posts 19 Posters 82.5k Views 19 Watching
      @driven said:
      TIG,
      I've got a couple of test on the go, I'll report on them when they're cooked.
      some additional ?'s
      which should be faster for manifold, simply continuing after fail or a manual repair than re-test continue
      would it be possible to choose bothquad's and tri's as two separate groups, if you have two different post destinations for the object?
      or would EraseCoplanar on a copy of a Tri'd group give identical mesh results?
      Manual fix versus Auto-fix depends on what needs fixing - making it right in the first place is the best bet ๐Ÿ˜‰
      If you choose NOT to triangulate but then want a triangulated version then copy it and simply select all faces and run my [+tt's] tool triangulate_faces and you'll have the same result - uses the same code... ๐Ÿค“
        driven
        Even Likes Curves, but they will slow it down.
        seems a lot quicker than before on this sort of thing
          Here's v2.0 http://forums.sketchucation.com/viewtopic.php?p=218691#p218691
          Glitch in health-check if very small edges in faces fixed...
            v2 ? is this a major or minor update?
              The tweaks were relatively minor - BUT as I am unlikely to make many more changes in the short-term I thought I'd mark it with '2.0'... ๐Ÿ˜‰
                I have missed this new true gem! ๐Ÿ˜ณ
                  When I use Manifold I obtain that ok
                  But When I kill or move the group red repair
                  I have the original copy with killed internal faces Yes ok โ˜€ , but always segments on the faces! ๐Ÿ˜ฎ
                  Does it normal? A simple box with 6 faces must be result ? No clean selection?
                    [attachment=0:2jmg80n7]<!-- ia0 -->bug.png<!-- ia0 -->[/attachment:2jmg80n7]
                    This is correct.
                    The internal faces are removed by any edges they has forming part of the external envelope are kept.
                    If you want rid of then use one of the tools that removes coplanar edges...
                    It could seek to remove coplanar edges too ?
                      Here's v2.1
                      It now has the option to remove coplanar edges before triangulation, this will minimize the number of faces -useful if for example internal faces have been removed and their old edges are not needed to keep the external 'manifold' skin intact...
                        Cool now we have possibility or not to "clean" the model in the same time ๐Ÿ˜‰
                          2 volumes
                          copy move
                          for each selected (2 volumes) Intersect Selected
                          Group
                          for each "group" apply Manifold
                          with same answers : Yes for the first question (of course)
                          and No for the others questions
                          Curious result is not the same! ๐Ÿ˜ฎ
                          Is that normal?
                          test.skp
                            driven
                            @Pilou,
                            tested your .skp on mac and got two different results? first time I opened SU from your download file, 2nd time I opened it from inside SU, but that was the only thing I changed, something odd??
                              Manifold has to start somewhere in its checking - the first entity it encounters might not always be the same so you get differing results if there's a big mess...
                              Manifold was written to do specific job - check that a group is 'manifold' and if not try to fix it - it is so that when you export your model - e.g. to 3D-printer software - it will work. As it says at the start 'give us break' and try and at least offer it a set of geometry you hope might be manifold - it is NOT a boolean tool to merge volumes - it tries to decide which is the face to keep but sometimes removing or healing something changes the form - hence the colored 'report' group.
                              Before using 'manifold' try manually to get rid of at least a few known internal faces etc [x-ray mode + hide is good for this] - then the processing is quicker and more consistent...
                              ๐Ÿ˜’
                                I well understand ๐Ÿ˜„
                                The only curious thing is that it not the same result for 2 similar groups inspected ๐Ÿ˜‰
                                  make.GQ.china
                                  Thank you for your plug-ins! ๐Ÿ˜Ž ๐Ÿ˜
                                    Here's v2.2 - updated FR lingvo file [thanks to Didier Bur] and glitches with Tooltips and other strings deBabelizing now sorted...
                                    • P
                                      pdwyer
                                      Does/should this work with SU 8?
                                      I'm not seeing any colours or new models created, even with the downloaded example but the example skp file is v7.
                                      I suspect v8 needs a plugin like this too. If there is some other way to find doubles/duplicates/manifolds etc I'd love to know
                                      Cheers
                                        Cheers
                                        In v8 there are 'manifold' functions built in...
                                        • P
                                          pdwyer
                                          Really? ๐Ÿ˜ฒ
                                          What are they called?
                                          • GaieusG
                                            The new solid tools. Outer shell (available in the free version, too), should do (more or less) what manifold plugin would (unless I am completely mistaken as I have never used this plugin yet)
                                            • 6 / 7
