    Model This: helmet
    33 Posts 14 Posters 8.1k Views 14 Watching
      KXI System
      I finished mines, it was a bit harder than I thought. I had to use follow me and intersect with model a lot here, the visor I had to use the move tool and the finishing touches with the scale tool. No plugins (except weld for ease).
      This is not really beginner stuff, and the plan is not accurate either.
      I included the file.
      Helm.skp
      Getting the perfect sig is hard...
      Google it!
        liam887
        compared to the other challenges it is pretty easy! Nobody has put the vents or chin straps in yet!
        VISIT MY ONLINE GALLERY
          d12dozr
          @kxi system said:
          ...and the plan is not accurate either.
          The whole point is to make the model look like the plan...of course the plan is accurate πŸ˜•
          http://goo.gl/f7ooYh
            asirad
            This is my second shot with helmet. I used only FFD plugin to correct arc. This one is better:
            Here is a movie how to create this helm with EEbyR Plugin.
            [flash=425,344:e6r6b632]http://www.youtube.com/v/em8YHNDFiyk&fs=1[/flash:e6r6b632]
            Best Regards
            %(#0040BF)[My Polish Blog ------------
            http://3d.na.wroclaw.pl
            • U Offline
              Ultimatez 32
              Alright I finally finished this helmet, I used vector push-pull, tube along path, projections, weld and the standard tools.
              EDIT = here's the skp file..
              helmet_green.skp
              Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
              • ely862meE Offline
                ely862me
                sds,jpp,tos
                Elisei (sketchupper)
                Come and See EliseiDesign
                  @elisei
                  top class πŸ‘
                    Rockets
                    ely862me
                    πŸ‘ Show me please with a side
                    It feels that the visor is very long from this angle
                    • U Offline
                      Ultimatez 32
                      nice one ely πŸ‘ πŸ‘
                      anyways here's another try, only the skin without inner padding etc. made using sds and jpp. In the image there are 3 versions. The first is the proxy, the second is one iteration, and the third two iterations.
                      helmet_two.skp
                      • ely862meE Offline
                        ely862me
                        Thanks guys!
                        I ve made it after the blueprints.
                        Elisei
                          Rockets
                          ely862me
                          Excuse me, please. I hope you do not mind the comments. But not exactly. Corners have smooth
                          http://i301.photobucket.com/albums/nn63/PAKETA_album/Helmet8.jpg
                          • soloS Offline
                            Two minutes, quick try using SU and sds.
                            Not accurate, just an eyeballed try.
                            http://img52.imageshack.us/img52/7711/helmet.gif
                              Jim
                              A clear case for using the right tool for the job, along with your obvious talent and dedication.
                              Nice model, ely862me πŸ‘
                                Rockets
                                Great! Each step show. Please. For beginner
                                SDS?
                                • ely862meE Offline
                                  ely862me
                                  @rockets said:
                                  ely862me
                                  Ah yeah..u re right..i missed that detail πŸ˜„ ...they re a bit too sharp.
                                  I ran once sds and it was ok..then i moved a bit the corners and i forgot to check again πŸ˜‰ ..
                                  Happy sketching!
                                  Elisei
                                    KXI System
                                    I'll guess I'll remake mines a bit later then...
                                    Google it!
                                      SDS?
                                      I suppose Subdivide and Smooth by Dale Martens at Smustard πŸ˜‰
                                      A more rustic free Sudivide by Rick Wilson at Smustard
                                      JPP =Joint Push Pull by Fredo6
                                        Nowhere near as impressive as Elisei's 😒
                                        Just added some thickness to the Helmet and sorted out my issue with the Visor
                                        Now trying the Padded Insert...
                                        Here's my version if anyone's interested, at 1.5mb?, must need purging πŸ˜•
                                        Helmet.skp
                                        • ely862meE Offline
                                          ely862me
                                          That looks pretty good!!(all i have is practice) if u practice more u get better results πŸ˜‰
                                          Elisei
                                          • EddyNLE Offline
                                            EddyNL
                                            @ely862me
                                            Your model makes me want to cry...
                                            I've been working with SU for 2 years now. My helmet doesn't even come close to yours!
                                            viewtopic.php?f=271&t=11903 Modelling my city for Google Earth!
                                            • 2 / 2
