    Model This: helmet
    33 Posts 14 Posters 8.5k Views 14 Watching
    • X Offline
      xrok1
      @liam887 said:
      @eduardonl said:
      @kxi system said:
      I see your challenge, I will do this easily.
      [give me a minute to model first]
      WHAT? I'm not even trying, I suck at making rounded shapes.
      Looking forward seeing your model.
      they are a pain at first but after a bit of practice you learn rounded shaped are not all that bad. It helps to be able to subdivide there is a plugin here, or you can export to another 3D app, makes things a lot smoother!
      it says using SU only πŸ˜‰
        liam887
        Oh yeah I know I was just talking generally to create rounded shapes, can still use the plugins tho.
        VISIT MY ONLINE GALLERY
        • soloS Offline
          That was over 3 hours ago.... not that easy?
            Ok here's mine...
            I used Tig's EEbyR Plugin to make the Helmet in 2 sections
            Not too happy with Visor but will do it again once the Pro's weigh in with some advice and tips
              KXI System
              I got distracted, man I knew I shouldn't had watch youtube while modeling!
              Then I forgot what I was doing and went to play a few games, now I'm back here wasting time explaining what took so long. AND I HAVEN'T EVEN STARTED! 😠
              Getting the perfect sig is hard...
              Google it!
                asirad
                Great job rclub24. I did my manually without any plugins but effect was very worst.
                I tried in your way but I have problem with one place
                Could you write or show how you did selected part of helm.
                Best Regards
                %(#0040BF)[My Polish Blog ------------
                http://3d.na.wroclaw.pl
                  KXI System
                  I finished mines, it was a bit harder than I thought. I had to use follow me and intersect with model a lot here, the visor I had to use the move tool and the finishing touches with the scale tool. No plugins (except weld for ease).
                  This is not really beginner stuff, and the plan is not accurate either.
                  I included the file.
                  Helm.skp
                  Google it!
                    liam887
                    compared to the other challenges it is pretty easy! Nobody has put the vents or chin straps in yet!
                      d12dozr
                      @kxi system said:
                      ...and the plan is not accurate either.
                      The whole point is to make the model look like the plan...of course the plan is accurate πŸ˜•
                      http://goo.gl/f7ooYh
                        asirad
                        This is my second shot with helmet. I used only FFD plugin to correct arc. This one is better:
                        Here is a movie how to create this helm with EEbyR Plugin.
                        [flash=425,344:e6r6b632]http://www.youtube.com/v/em8YHNDFiyk&fs=1[/flash:e6r6b632]
                        Best Regards
                        • U Offline
                          Ultimatez 32
                          Alright I finally finished this helmet, I used vector push-pull, tube along path, projections, weld and the standard tools.
                          EDIT = here's the skp file..
                          helmet_green.skp
                          Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                          • ely862meE Offline
                            ely862me
                            sds,jpp,tos
                            Elisei (sketchupper)
                            Come and See EliseiDesign
                              @elisei
                              top class πŸ‘
                                Rockets
                                ely862me
                                πŸ‘ Show me please with a side
                                It feels that the visor is very long from this angle
                                • U Offline
                                  Ultimatez 32
                                  nice one ely πŸ‘ πŸ‘
                                  anyways here's another try, only the skin without inner padding etc. made using sds and jpp. In the image there are 3 versions. The first is the proxy, the second is one iteration, and the third two iterations.
                                  helmet_two.skp
                                  • ely862meE Offline
                                    ely862me
                                    Thanks guys!
                                    I ve made it after the blueprints.
                                    Elisei
                                      Rockets
                                      ely862me
                                      Excuse me, please. I hope you do not mind the comments. But not exactly. Corners have smooth
                                      http://i301.photobucket.com/albums/nn63/PAKETA_album/Helmet8.jpg
                                      • soloS Offline
                                        Two minutes, quick try using SU and sds.
                                        Not accurate, just an eyeballed try.
                                        http://img52.imageshack.us/img52/7711/helmet.gif
                                          Jim
                                          A clear case for using the right tool for the job, along with your obvious talent and dedication.
                                          Nice model, ely862me πŸ‘
                                            Rockets
                                            Great! Each step show. Please. For beginner
                                            SDS?
