    Model This: helmet
    33 Posts 14 Posters 8.5k Views 14 Watching
      Ok here's mine...
      I used Tig's EEbyR Plugin to make the Helmet in 2 sections
      Not too happy with Visor but will do it again once the Pro's weigh in with some advice and tips
        KXI System
        @solo said:
        [give me a minute to model first]
        That was over 3 hours ago.... not that easy?
        I got distracted, man I knew I shouldn't had watch youtube while modeling!
        Then I forgot what I was doing and went to play a few games, now I'm back here wasting time explaining what took so long. AND I HAVEN'T EVEN STARTED! 😠
        Getting the perfect sig is hard...
        Google it!
          asirad
          Great job rclub24. I did my manually without any plugins but effect was very worst.
          I tried in your way but I have problem with one place
          Could you write or show how you did selected part of helm.
          Best Regards
          %(#0040BF)[My Polish Blog ------------
          http://3d.na.wroclaw.pl
            KXI System
            I finished mines, it was a bit harder than I thought. I had to use follow me and intersect with model a lot here, the visor I had to use the move tool and the finishing touches with the scale tool. No plugins (except weld for ease).
            This is not really beginner stuff, and the plan is not accurate either.
            I included the file.
            Helm.skp
            Google it!
              liam887
              compared to the other challenges it is pretty easy! Nobody has put the vents or chin straps in yet!
              VISIT MY ONLINE GALLERY
                d12dozr
                @kxi system said:
                ...and the plan is not accurate either.
                The whole point is to make the model look like the plan...of course the plan is accurate πŸ˜•
                http://goo.gl/f7ooYh
                  asirad
                  This is my second shot with helmet. I used only FFD plugin to correct arc. This one is better:
                  Here is a movie how to create this helm with EEbyR Plugin.
                  [flash=425,344:e6r6b632]http://www.youtube.com/v/em8YHNDFiyk&fs=1[/flash:e6r6b632]
                  Best Regards
                  • U Offline
                    Ultimatez 32
                    Alright I finally finished this helmet, I used vector push-pull, tube along path, projections, weld and the standard tools.
                    EDIT = here's the skp file..
                    helmet_green.skp
                    Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                    • ely862meE Offline
                      ely862me
                      sds,jpp,tos
                      Elisei (sketchupper)
                      Come and See EliseiDesign
                        @elisei
                        top class πŸ‘
                          Rockets
                          ely862me
                          πŸ‘ Show me please with a side
                          It feels that the visor is very long from this angle
                          • U Offline
                            Ultimatez 32
                            nice one ely πŸ‘ πŸ‘
                            anyways here's another try, only the skin without inner padding etc. made using sds and jpp. In the image there are 3 versions. The first is the proxy, the second is one iteration, and the third two iterations.
                            helmet_two.skp
                            • ely862meE Offline
                              ely862me
                              Thanks guys!
                              I ve made it after the blueprints.
                              Elisei
                                Rockets
                                ely862me
                                Excuse me, please. I hope you do not mind the comments. But not exactly. Corners have smooth
                                http://i301.photobucket.com/albums/nn63/PAKETA_album/Helmet8.jpg
                                • soloS Offline
                                  Two minutes, quick try using SU and sds.
                                  Not accurate, just an eyeballed try.
                                  http://img52.imageshack.us/img52/7711/helmet.gif
                                    Jim
                                    A clear case for using the right tool for the job, along with your obvious talent and dedication.
                                    Nice model, ely862me πŸ‘
                                      Rockets
                                      Great! Each step show. Please. For beginner
                                      SDS?
                                      • ely862meE Offline
                                        ely862me
                                        @rockets said:
                                        ely862me
                                        Ah yeah..u re right..i missed that detail πŸ˜„ ...they re a bit too sharp.
                                        I ran once sds and it was ok..then i moved a bit the corners and i forgot to check again πŸ˜‰ ..
                                        Happy sketching!
                                        Elisei
                                          KXI System
                                          I'll guess I'll remake mines a bit later then...
                                          Google it!
                                            SDS?
                                            I suppose Subdivide and Smooth by Dale Martens at Smustard πŸ˜‰
                                            A more rustic free Sudivide by Rick Wilson at Smustard
                                            JPP =Joint Push Pull by Fredo6
