    Circular/Spiral Building Help
    17 Posts 8 Posters 2.2k Views 8 Watching
    • G
      GreenSaints
      Hey,
      I'm not trying to model that building - I'm designing my own which has taken "inspiration" from that building.
      What you have done is great - I think I can work something out for the semi circle at the bottom.
      How could I make that more curved?
      • GaieusG
        Tas, somehow try to visualize that semi circle. I for instance do not know where and how you want to add it - at least post a rough 2d sketch in top view or something, please.
        • G
          GreenSaints
          I've taken what KXI posted for me and drawn the semi circle.
          Where the spiral attaches to the semi circle I want that to join continuously - not sit on top like I have at the minute. Do that make sense?
          Again, thank you for your help
          Spiral.skp
          • K
            KXI System
            I've updated my model to make it more "round"
            Spiral.skp
            Getting the perfect sig is hard...
            Google it!
            • G
              GreenSaints
              KXI - thank you for that, it's great
              • GaieusG
                That's exactly and basically the way it should go. If it is a little smoother, the better of course but the theory is what counts.
                Spiral.skp
                • G
                  GreenSaints
                  Brilliant - that's exactly what I wanted.
                  Now - how did you do it?! ๐Ÿ˜ฒ
                    Maybe this can be take some idea ๐Ÿ˜‰
                    Shape Bender by Chris Fullmer ๐Ÿ˜Ž
                    [flash=425,344:2nwpubt9]http://www.youtube.com/v/tGHTIOMm_34&hl[/flash:2nwpubt9]
                    If you don't want the increase/decrease of the thickness, just take a simple box ๐Ÿ˜‰
                    http://forums.sketchucation.com/download/file.php?id=42120
                    • GaieusG
                      Pilou-Pilou...
                      You know one has to learn to walk first!
                      ๐Ÿ˜‰
                      So as I didn't even have access to any helix plugins (the Ruby Libary depot is down again), the whole thing was dome just manually. ๐Ÿ˜ณ
                      Some easy steps (in fact, after creating that face that we'll spin around in the first step, you could also delete the side of the cylinder to make sure you do not create unnecessary geometry...
                      I don't know what's happening - D0me's picture is uploaded all the time although I definitely choose another one!
                        Jim
                        Here's one way without plug-ins.
                        [flash=640,480:2nrat7h1]http://www.youtube.com/v/lI-2MxTi0YY[/flash:2nrat7h1]
                        • charly2008C
                          charly2008
                          Maybe the simplest methode with DrawHelix1.3 and FollowMeAndKeep tool.
                          -Draw helix with specified measures
                          -Explode helix and draw the Profile
                          -FollowMeAndKeep the profile
                          -Manual correction
                          • T
                            tfdesign
                            Can the pitch and diameter be adjusted after a helix is sketched, or modelled? I haven't got this plugin, but I was drawing a helix yesterday in ViaCAD (which is pretty simple to do).
                              A 'helix' is simply a 3D curve - so like anything else it can be Scaled in plan to change its diameter or make it ellipsoidal and in its height to change its 'pitch'...
                              You can taper it in its height when making it too.
                              It's so quick to do remaking another helix is easy enough...
                              Here's an example of a tapered helix of two different sizes and a link flat-arc quickly processed in EEbyRails to give a helical weirdness...Untitled.png
