[Plugin] [CityGen] - Core [WIP] (0.1.3a) — 19 September 2009
as of the 19-sep update, are you still using the google code repo? I noticed there were no updates when I tried to pull after the announcement.
This is from the repo. I just made an easy public download that was more up to date.
Bookmark...
Had a tough time trying to put the program in it.
So, I'd look forward to updates.
Hi- This is an interesting project. Unfortunately I wasn't able to get all the files from both Core and Streetgen in the correct heirarchy in the plugins folder so I keep getting error messages. Is this a Mac problem?
Depends on how you extracted it. Macs tend to create an extra folder when extreating - the files you need would be inside the first one.
(note - this depend on how you extracted it.) -
if you have instaled several plugins more at the same time: MODULOR,
Where can we find this plug "Modulor" ?
THX
It's not exactly the same name
no ... but it's hard to juggle them eoueoue's...
Does it possible with your plug to generate "streets" with no round Corners?
Set Angle Threshold to 180 degrees (or more).
PS Are you interested by a little French translation of your Plug's UI?
In the future, yes. But as it is now - this plugin is experimental and many things will change. (When I get around to work on it again.)
here 0.01 as corner radius (Why not 0 possible)
90° as Angle thresholdPS Are you interested by a little French translation of your Plug's UI?
Not possible to average for have an angle more straight?
Because after there are some glitch when you make some functions with it
As it is now - it does no error checking at all. But you're right - it's something that'd be nice if it did.
In your last versions measures are not keeping from previous calculate in the dialog box
I'm still stumped as to where to put the plug-ins on CityGen and StreetGen. To keep my SU7 from crashing, I had to make a City_Gen folder and nothing comes up. I don't know what I'm doing wrong.
Footnote: When I put the city_gen.rb file in Plug-ins, after clicking in to SU7, I get a crash leading to a bug repot. If only I can find out what the problem is.
The plug-in is not really ready for use, but I made a Windows installer for the current version. See the Downloads tab:
Note: both the plugin and the installer should be considered experimental. Let me know if it works.
The Core:
citygen folder
city_gen_loader.rb
These goes into the plugins folder.Street Gen
street_gen folder
street_gen.rb
These goes intoplugins/citygen/modules/I don't know why any of these would be causing crashes. I've not experienced it myself.
That's interesting. What did you use to create that?
Inno
Site not found · DreamHost
The owner of this domain has not yet uploaded their website.
(www.jrsoftware.org)
Thanks, thomthom et. al. I managed to get it running smoothly.
What I did was searching through Google and there was an Alpha installer of CityGen, but it froze my SU -- but (d'uh on my part
), I "forgot" to put the city_gen loader.rb in the plugin, the CityGen in the Citygen folder and the streetGen in the modules your stated... To make a long story short - it was a real bumpy ride, no pun intended.Thanks guys for all your help. I'll keep playing with this feature.
