Optimization Tips
$VERBOSE controls messages and warnings that get set to STDERR.
Set to nil so SU Ruby doesn't waste time spitting out useless warnings about sloppy code (like "warning: meaningless use of == in nil context") which noone wants to read anyway (when they're doing modelling.) Or my other favorite "warning: parenthesize arguments for future version."
Settings:
$VERBOSE = nil : sets 'Silent' mode
$VERBOSE = false : sets 'Medium' mode (default)
$VERBOSE = true : sets 'Verbose' modeThese settings correspond to ruby start parameter -W with values of 0,1,2 (which would also set $VERBOSE in a standard Ruby Environment.)
thanks Dan. That will come in handy!
I see a lot of SU scripts using some of the more compact iterators Ruby iterators. So they might read nice, but they're often slower than just simple for-loops.
http://blog.shingara.fr/each-vs-for.html
The other biggie to look out for is operations that involve copying when modifying in place would work just as well. Its slow and it generates lots of garbage.
Interesting.
foris faster thaneach. Butdo ... endis faster than{ ... }? I really didn't expect that. And I don't see why. Thought it was just alternative syntax. But they behave differently?@adamb said:
Interesting. I'll have to look through some of my code. I've not thought of that at all.
@thomthom said:
But do ... end is faster than { ... } ? I really didn't expect that. And I don't see why. Thought it was just alternative syntax. But they behave differently?
hm.. maybe not. seemed to very very little difference. suppose that's other things affecting the minute differences.
And why is for faster then each?
Looking at the source code for
Array.each:VALUE rb_ary_each(ary) VALUE ary; { long i; for (i=0; i<RARRAY(ary)->len; i++) { rb_yield(RARRAY(ary)->ptr[i]); } return ary; }It's using for as well, and the whole loop is done in C - so why isn't this C
forloop faster than a rubyforloop? -
OT: Any chance the forum administrator of SCF can fix the [ruby] tag to not remove formatting. Formatting is a big part of understanding code, and while for regular text collapsing whitespace down to a single space might work, for code it does not.
@adamb said:
OT: Any chance the forum administrator of SCF can fix the [ruby:38zsi59i]tag to not remove formatting. Formatting is a big part of understanding code, and while for regular text collapsing whitespace down to a single space might work, for code it does not.
I think the
rubyis meant for inline code. While you got thecodetag for block codes. (Though I wish there was a way to expand it - I loathe internal scrollbars.) -
Interesting test Adam:
doit 6.474 3.292 nilNote: I increased the number of iterations (
10000000.times { ... }) -
Didn't realise Ruby would recreate the variables for each iteration. I'd thought it'd keep them for the duration of the loop...
Seems an arbitrary (and wrong) assumption that inline code requires removing whitespace. Why not just leave in what the author wrote rather than trying to second guess? Whatever.
Agree - whitespace eating of
rubyhas bothered me as well. Will ask if it can be changed. -
The closure you create with curly braces is handled as a first class object and passed as an argument to the iterator. This means the scope of any variables you mention inside that block is limited to that block - it must create them each time.
Is that why
eachis slow? -
Guys, Thom asked if we can do something with these white spaces but I have to say it is most probable that we cannot. I is hard coded somewhere in the php script of the forum software and even if we could tweak that, it would be impossible to keep it through upgrades (which is very due soon anyway).
Is the code tag not good (apart from that scrolling annoyance)?
It's ok. I just hoped there was a config UI for BBCode tags on the forum. Thought it was normal. The
codetag is ok, just figured if it could be changed...I don't suppose there are forum plugins that can be installed? having the code block apply syntax highlighting would be a delight for us coders. Such as this:
Edit: what version of phpBB does SCF run? I'm looking at this: http://www.phpbb.com/kb/article/adding-custom-bbcodes-in-phpbb3/ from this it appear to be that it'd be a matter of setting the HTML replacement for the ruby tag to not collapse white space using CSS.
Replacement sample something like this:
<span style="white-space:pre;">{TEXT}</span> -
I can imagine you would like that syntax highlight! I use Notepad++ and know what a difference it is!
Coen and Tavi should be spoken to about these things.
In regard to this should one init the variables used by
for into speed up things? or is that not needed?Would this
` x = 0
for x in collection...
be faster thanfor x in collection...
end`
no
I've always thought
forusedeachunder the hood.http://blog.grayproductions.net/articles/the_evils_of_the_for_loop
for loops do not have their own scope - the loop variable and any variables created in the loop become available (or are over-written) in the current scope.
With
.each, variables are local to the block {..}
