    Optimization Tips
    110 Posts 22 Posters 215.7k Views 22 Watching
      @thomthom said:
      @tig said:
      How about model.selection.add(model.entities.to_a) ?
      I over simplified the example - updated to reflect a purpose.
      Sidenote: . to_a isn't required as selection.add accepts any kind of collection object. It even let you feed it nested array of entities without the need to flatten the array.
      I usually .to_a my entities, because it stops me falling into trap like modifying the entities whilst referring to them in a loop; or an array is also needed for some other things like entities.transform(tr,entities.to_a)
      • Dan RathbunD
        Dan Rathbun
        $VERBOSE controls messages and warnings that get set to STDERR.
        Set to nil so SU Ruby doesn't waste time spitting out useless warnings about sloppy code (like "warning: meaningless use of == in nil context") which noone wants to read anyway (when they're doing modelling.) Or my other favorite "warning: parenthesize arguments for future version."
        Settings:
        $VERBOSE = nil : sets 'Silent' mode
        $VERBOSE = false : sets 'Medium' mode (default)
        $VERBOSE = true : sets 'Verbose' mode
        These settings correspond to ruby start parameter -W with values of 0,1,2 (which would also set $VERBOSE in a standard Ruby Environment.)
        I'm not here much anymore.
        • W
          Whaat
          thanks Dan. That will come in handy!
          • AdamBA
            AdamB
            I see a lot of SU scripts using some of the more compact iterators Ruby iterators. So they might read nice, but they're often slower than just simple for-loops.
            http://blog.shingara.fr/each-vs-for.html
            The other biggie to look out for is operations that involve copying when modifying in place would work just as well. Its slow and it generates lots of garbage.
              Interesting. for is faster than each. But do ... end is faster than { ... } ? I really didn't expect that. And I don't see why. Thought it was just alternative syntax. But they behave differently?
              Interesting. I'll have to look through some of my code. I've not thought of that at all.
                hm.. maybe not. seemed to very very little difference. suppose that's other things affecting the minute differences.
                  And why is for faster then each?
                  Looking at the source code for Array.each:
                  VALUE
                  rb_ary_each(ary)
                      VALUE ary;
                      long i;
                      for (i=0; i<RARRAY(ary)->len; i++) {
                          rb_yield(RARRAY(ary)->ptr[i]);
                      return ary;
                  It's using for as well, and the whole loop is done in C - so why isn't this C for loop faster than a ruby for loop?
                  • AdamBA
                    AdamB
                    OT: Any chance the forum administrator of SCF can fix the [ruby] tag to not remove formatting. Formatting is a big part of understanding code, and while for regular text collapsing whitespace down to a single space might work, for code it does not.
                      @adamb said:
                      OT: Any chance the forum administrator of SCF can fix the [ruby:38zsi59i]tag to not remove formatting. Formatting is a big part of understanding code, and while for regular text collapsing whitespace down to a single space might work, for code it does not.
                      I think the ruby is meant for inline code. While you got the code tag for block codes. (Though I wish there was a way to expand it - I loathe internal scrollbars.)
                        Interesting test Adam:
                        doit 6.474 3.292 nil
                        Note: I increased the number of iterations ( 10000000.times { ... })
                          Didn't realise Ruby would recreate the variables for each iteration. I'd thought it'd keep them for the duration of the loop...
                          • AdamBA
                            AdamB
                            Seems an arbitrary (and wrong) assumption that inline code requires removing whitespace. Why not just leave in what the author wrote rather than trying to second guess? Whatever.
                              Agree - whitespace eating of ruby has bothered me as well. Will ask if it can be changed.
                              • AdamBA
                                AdamB
                                The closure you create with curly braces is handled as a first class object and passed as an argument to the iterator. This means the scope of any variables you mention inside that block is limited to that block - it must create them each time. 😞
                                  Is that why each is slow?
                                  • GaieusG
                                    Guys, Thom asked if we can do something with these white spaces but I have to say it is most probable that we cannot. I is hard coded somewhere in the php script of the forum software and even if we could tweak that, it would be impossible to keep it through upgrades (which is very due soon anyway).
                                    Is the code tag not good (apart from that scrolling annoyance)?
                                      It's ok. I just hoped there was a config UI for BBCode tags on the forum. Thought it was normal. The code tag is ok, just figured if it could be changed...
                                      I don't suppose there are forum plugins that can be installed? having the code block apply syntax highlighting would be a delight for us coders. Such as this:
                                      Error 404 (Not Found)!!1
                                      (code.google.com)
                                      http://syntaxhighlighter.googlecode.com/files/Overview01.png
                                      Edit: what version of phpBB does SCF run? I'm looking at this: http://www.phpbb.com/kb/article/adding-custom-bbcodes-in-phpbb3/ from this it appear to be that it'd be a matter of setting the HTML replacement for the ruby tag to not collapse white space using CSS.
                                      Replacement sample something like this:
                                      <span style="white-space:pre;">{TEXT}</span>
                                      • GaieusG
                                        I can imagine you would like that syntax highlight! I use Notepad++ and know what a difference it is!
                                        Coen and Tavi should be spoken to about these things.
                                          In regard to this should one init the variables used by for in to speed up things? or is that not needed?
                                          Would this
                                          ` x = 0
                                          for x in collection
                                          endbe faster than for x in collection
                                          end`
                                          • AdamBA
                                            AdamB
                                            no
                                            • 1 / 6
