    Construction & Working Drawings - Discussion
    layout
    453 Posts 114 Posters 392.1k Views 114 Watching
      tim
      @mitchel stangl said:
      These are example a of CD done with Layout:
      [attachment=0:m5hsn670]<!-- ia0 -->0811-GA-example-1.png<!-- ia0 -->[/attachment:m5hsn670]
      So if I understand your drawing, the mouse enters the trap......
      • W Offline
        watkins
        Dear Mitchel,
        Those drawings are very impressive, and so I might indeed be in touch. I tend to use Sketchup for preliminary design, and then switch to AutoDesk's Inventor for final modelling and 2D draughting. I haven't really investigated the potential of Layout even though I have the Pro version of Sketchup.
        Kind regards,
        Bob
          krupster51
          I've just started attempting the use of layout for CD's..........really just elevations of the building however. It's a bit clumsy for adding notes and the like. Anybody have a way to set and maintain a default for text, leaders, etc? I don't have an issue for use of SU models imported into LO for prelim drawings, but find it would certainly be way more of an issue for finished CD's. AutoCad was made for tech drawings, SU and LO are purely for presentation of ideas.
          Anyway....any methods for setting text, line, arrow leader, etc defaults. They seem to need to be re-set with every different task.
            bjanzen
            The tool defaults are set by the templates, so if you create a document to the style you like, and File->Save as Template, then all those things should be set properly for you.
            b
              bjanzen
              I should add one other clue for the experts in the crowd: LayOut files are zipped files, containing resources and XML. Look at styleManager.xml in the unzipped directory to see all the style defaults.
              b
                Mitchel Stangl
                It is really easy. Pick a tool, text, for example, set it up before using it. It will stay that way until you change it again. Easy!
                Mitchel
                • SektaS Offline
                  Sekta
                  Mitchel,
                  Love your CD drawings, always very inspirational to see someone using SU/LO to its full potential. Do you use the 3Skeng tool in alot of your work? I am starting to find this tool as well as profile builder essential in my workflow.
                  Although we are Architects, in the past year we have had opportunities to get more involved in heavy industrial work like galvanising plants, cement plants, a milk powder factory and even a rotary cowshed of all things. This work has come exclusively through our abilities to model these relatively complex industrial forms in SU quickly and efficiently.
                  Stan
                    aquafolium
                    its been taking some time, but I'm feeling good that once I get it set up, the second project will be much easier.
                      aquafolium
                      WB
                      am new to this
                      how do I post/share my example files?
                        @aquafolium said:
                        ...how do I post/share my example files?
                        Under the text area you are typing your post, there is an "Upload attachment" tab.
                          gedw99
                          Check out my PDF of the construction drawings from Layout.
                          Maybe it helps others.
                          I will post more tips on my web site and some Sketchup and Layout files to help others.
                          http://www.ubuntudesign.com
                          I am an architect and have used many CAD packages over the last 15 years.
                          Auto-cad, Micro-station, others
                          I actually think Sketch-up & Layout is better then all of them for my work anyway. BUT, you have to use it in the right way is what i say. It takes some "Best Practices" to get the best out of the software, like any software.
                          I agree that its a bit messy. Layout and Sketch-up is designed to be workable for many different vertical industries.
                          So, you have to modify your workflow and best practices to match what your trying to achieve.
                          i guess thats why so many plugin have come out to match vertical industries πŸ˜„
                          Some tips:
                          1. Have a layer for each Scene view, where you can put your dimensions on. You need this because then you can control on what scene (page) the dimensions are visible on.
                            For example, look at the following layer names: 0_Plan_dims, 2_Section_Dims
                            The "0" relates to the level in the building.
                            The "Plan" relates to what type of view it is.
                            The "Dims" relates to what is on that layer.
                          2. Also get the "Add hidden Layer" plugin; cant remember where i got it This allows you to add a layer WITHOUT it being turned on for ALL your scenes, which is what you actually want. Google should simply change the default Layer ADD functionality to do it this way in my opinion.
                          3. Draw everything on layer zero. Weird advice i know.
                            By this, i mean that you draw all lines and faces on layer zero, with no material or anything applied.
                            Then, you group it, and apply the material and the layer tag at the group level.
                            Doing this gives you maximum control over things and allows for speedy changes.
                          4. Use Components to model things that are the same.
                            Sure, you would do this for little things, but also for big things this is really useful.
                            For example, i have 6 apartments, and they are a mirror image of each other.
                            So, i just make then a component, copy it and flip it and i am done.
                          Sometimes, one apartment must have some special thing in it different from the other.
                          For example, say the staircase has to be different in each one because of site level conditions.
                          You break the staircase out of the Component then. Its still on the "Staircase" layer, just not part of the component now.
                          Simple.
                          Ged
                          Drawings ArchitecturalSample.pdf
                            Bert
                            I use that plugin a lot for the same reason as you.
                            Here is the link to "Add_hidden_layer"
                            Salutations (Best regards) Bert
                              jfanjoy
                              I probably represent a pretty unusual case, but I am currently using SU and LO to produce a set of construction drawings. I am an architect working for the Peace Corps in Guatemala, helping a rural Mayan community to design and build a 800 square meter high school. What I've discovered is that most of the local labor force is illiterate as well as unable to read conventional construction documents. SketchUp gives me a way to present the data in a way that makes more sense to the laborers doing the work. I've attached two example drawings from the set. They are obviously inadequate for your typical contractual arrangement in the US, but they are a lifesaver here and I don't know of any tool that would do a better job than SketchUp.
                              Go easy on the criticism... they are only about 85% done. πŸ˜„
                              BTW, Mitchel's drawings are pretty awesome.
                              IDJK-1.pdf
                                jfanjoy
                                Oops, here is the second document, showing the rainwater/potable water/wastewater systems.
                                IDJK-2.pdf
                                  These are great, Jim, and if "officially" no "more" is needed and the workers can easily "read" these drawings, they perfectly fulfil their role (even I could understand them - and I am not an architect/builder at all).
                                    smalld
                                    Everyone is clear that LO has no problems with printing A1 or 36"x24" type drawings, right? I've seen so many threads and posts asking about that sort if thing that I thought it might be worth reminding people. My local printshop will run off 36x24 sheets from a USB stick for C$2.50 each and it takes very little time (I'm quite amazed at how fast modern large format printers can be) to get a full set for my current house project printed up.
                                    I too have used SU just recently to complete the approval of a $300,000 Physiotherapy Clinic which is underway and had all pertinent drawings produced with SU and LO in PDF format and am now working on a 43 acre Green Development which will include strata, single family dwellings, affordable housing units all within the Sustainable Building Criteria. The clinic was and the development will all be printed in PDF format by our local college at extremely economical costs. At their rates it would take me years to recover the costs in upgrading my present plotters. SU and LO definitely meet the need as far as presentation and basic floor plans. I use several different CAD programs one of which is a unique CAD system that allows me to ensure a 1%-2% wastage factor guaranteed, providing me with complete materials lists, including cut lists, cutting diagrams and allows me to determine the total amounts of screws, nails, (per pound according to local bldg codes) insulating foam, vapor barrier, tile base and grout, concrete, roofing mtls, window & door schedules, electrical, HVAC, automatic; elevations, sections, floor plans and many of all the other factors/materials that are required in the construction of the building(s), with only a few limitations, however it required a significant amount of time in defining input, but well worth the minutes in the face of being able to recall and apply to these same definitions to future designs from the database. It also allows me to import/export drawings from SU which I use for conceptual drawings, presentations, and for client consultation.
                                    For presentation and simple flr plans as well as on the spot revisions in concept,SUand LOcan't be beat.
                                    If they one day make it more of a true CAD System I might quickly and quietly dumped my present programs, but with all it's potential in the face of their stated mandate, I think I would be holding my breath for a long time. Till then I will happily keep trying to use and learn more about SU [/b & [b]LO and continue to explore their full potential while taking the fantastic opportunity to learn from the the most learned and wise out there - including viewsion, and the many exceptional, creative and innovative SU users and innovators out there.
                                    Thanx and thanx again to each and every one of you.http://forums.sketchucation.com/posting.php?mode=quote&f=12&t=15911&p=184024#http://forums.sketchucation.com/posting.php?mode=smilies&f=12#
                                    smalld
                                    Your house is your larger body- Kahlil Gibran**[dir=ltr:cxq51k3g][/dir:cxq51k3g]**
                                    • V Offline
                                      varmint
                                      I'm new to the forum but was interested in the topic as I have used SketchUp and Layout with some limited success to create scaled construction drawings. Recently I came across some 2D plan and elevation components (and materials) that had a beautiful hand drawn quality to them, ranging from kitchen and bathroom appliances, to outdoor furniture and plants and trees, which were specifically for SketchUp as well as CAD packages. They are from a company called iSymbol at http://www.isymbol.eu and I wondered if anyone has used them as I'm thinking of buying some of the sets to give that 'designer' look to the drawings.
                                      • bmikeB Offline
                                        bmike
                                        Presentation drawings for upcoming zoning meeting. I'm a timber frame designer - but do plenty of schematic work with my clients, as well as presenting how my work coordinates with others. This particular project I worked the schematic design from scratch, and will see this turned over to a local firm for CD's permits, etc.
                                        http://lh5.ggpht.com/_0jkA5M3PGcY/S47R9usMzlI/AAAAAAAAOvI/pZzgrI8fwks/s800/millrd-presentation_01.jpg
                                        http://lh4.ggpht.com/_0jkA5M3PGcY/S47VeCJZR7I/AAAAAAAAOvw/MATZLkwV90I/s800/millrd-presentation_03.jpg
                                        http://lh3.ggpht.com/_0jkA5M3PGcY/S47R8D246vI/AAAAAAAAOvE/Mj_JdjMsSC0/s800/millrd-presentation_03.jpg
                                        http://lh4.ggpht.com/_0jkA5M3PGcY/S47R3jErNUI/AAAAAAAAOvA/WTXAVGf9YTQ/s800/millrd-presentation_06.jpg
                                        http://lh6.ggpht.com/_0jkA5M3PGcY/S47RfUBqjNI/AAAAAAAAOug/yNobOMTAFok/s800/millrd-presentation_12.jpg
                                        http://lh3.ggpht.com/_0jkA5M3PGcY/S47Ry5ItDNI/AAAAAAAAOuk/slcbzaoND3s/s800/millrd-presentation_14.jpg
                                        Final set submitted is about 16 sheets. Will also add a few construction detail shots of how the frame interacts with other components. I have the color set, as well as a separate set with a B/W sketch line drawing style - slightly softer than an ACAD drawing, but still crisp for a non color print.
                                        It took a few test plots to see what font sizes I'd like and how my styles would translate to paper. I'm partial to the color versions - but if I were to take this further I'd probably do a mix of color w/without shading and line work drawings.
                                        • W Offline
                                          watkins
                                          You don't say, so I assume you used Layout to make the presentation drawings. Is that the case?
                                          • bmikeB Offline
                                            bmike
                                            are you talking to me?
                                            yes, i did use layout with embedded model(s) to create the tf and building model...
                                            • 22
                                            • 23
                                            • 3 / 23
