    Who wants to get paid for thier work
    21 Posts 6 Posters 1.6k Views 6 Watching
    • F Offline
      fireplug1111
      @tig said:
      @fireplug1111 said:
      I'm sorry I thought I had posted a link to what I wanted. Here is a link look at the HUEY
      http://forums.sketchucation.com/viewtopic.php?f=15&t=25313
      The only things there are the images of plans/elevations with a few scant dimensions - but what makes these so different from the SKP that I used ? Are you saying there are some dimensional discrepancies ? or somethings missing or added ?? or what ???
      Please give a few more clues - my telepathy isn't working today πŸ˜„
      Yes the HUEY you used is excatly the way I want it sliced up. However the huey from the warehouse ( the one you used ) is no where near scale. If you look at a front view of the one I supplied and the one you used you will see a huge differance.
        Yes the HUEY you used is exactly the way I want it sliced up. However the huey from the warehouse ( the one you used ) is no where near scale. If you look at a front view of the one I supplied and the one you used you will see a huge difference.
        BUT please explain what these differences are !!!
        They might be OBVIOUS to you... but to everyone else [or even just me] they seem insignificant................
        Please expand on exactly what's up...
        • F Offline
          fireplug1111
          I'm using this to build a remote control UH-1D Huey helicopter, this will be a scale heilcopter. I need this to cut out formers to build a fiberglass mold so I can install my mechanics. Look at this thread and you will see why I need it to be exact. http://www.helifreak.com/showthread.php?t=127202
          • O Offline
            outland86
            i would have thought that if a guy had the skill to fly one of these Models and also the skill to make it from scratch. he /she might have the skill to make accurate drawings of what they need and post them to whomever was trying to help them with a particular modeling problem
            but hey what do i know
              @fireplug1111 said:
              I'm using this to build a remote control UH-1D Huey helicopter, this will be a scale helicopter. I need this to cut out formers to build a fiberglass mold so I can install my mechanics. Look at this thread and you will see why I need it to be exact. http://www.helifreak.com/showthread.php?t=127202
              I understand what you are hoping to do with the 'slices'. "What's up" = what is wrong with the existing models that isn't fixable ? IF you highlight what is needed to be fixed more clearly then perhaps we can fix it. To say 'it's no good' is not much help. but saying the fuselage should be 1'6" longer would be ! I realize you want to be 'exact' BUT what is 'exact' - give us some clues here man... Do you see what I mean ?
              • F Offline
                fireplug1111
                Outlander- ther are posted with measurments.
                TIG can you slice thisup the same way you sliced up the other one you did?Helicopter body shell by EliseiDesign.rar
                • F Offline
                  fireplug1111
                  I've tried everything I can think of. If you guys say its so easy to slice this up then you come to Florida and work for NASA they need rocket scientist. Every time I use slicer it either says NO VOLUME and when it finally gives me the measurements to slice it up it just freezes my computer. So I must be doing something wrong. I just don't get how something that seems so easy can be so difficult... As far as the tutorials Nothing on slicing.....
                  Still looking for help.
                    Yes.
                    However the model is only about 4' long so what centers do you want the slices - you previously said 6" but that was assumed to be along the full size which was about 41' ?
                    It's metric too [though it's easy to swap to footric] so do you want 6" c/c or 0.6" c/c ??
                    I can do either...
                    EDIT: I apologize - I rechecked and it is full sized so I'll send it through shortly at 6" c/c...
                    • O Offline
                      outland86
                      i have it !!!!
                      just get a big 3d printer print out the model whip out to the shed get a chainsaw
                      and bobs your uncle πŸ˜„
                      do you think NASA will hire me ? πŸ˜„
                        Here's the model back sliced at 6" c/c [full sized].
                        The slices are laid out and numbered so it should be straightforward to reassemble.
                        84 slices ~8 minutes to slice...
                        The last slice is spaced slightly differently to fit the length - see the assembled set...
                        Now you have to print to scale - 1/10 or 1/12 ?
                        Good luck. πŸ˜‰Helicopter body shell by EliseiDesign.zipHelicopter body shell by EliseiDesign.png
                        • F Offline
                          fireplug1111
                          I sure wish I know how you did that.. I spent about 5 hours today playing with that and could not do anything. THANKS A MILLION.......
                          Its excatly what I need. Can you see the differance between the warehouse one and this one? Thats why I wanted this one.
                          Once again thanks
                            Here's a Z and a Y sliced version - might also be useful...
                            The slices ~6" - I did that so it's symmetrical...
                            Sorry for the gap in communication - even I have to go to bed...Helicopter body shell by EliseiDesignZY.skpHelicopter body shell by EliseiDesignZY.png
