    New API doc - typos and questions
    370 Posts 35 Posters 263.5k Views 35 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      Model.get_product_family
      http://code.google.com/apis/sketchup/docs/ourdoc/model.html#get_product_family
      Returns a constant number which indicates the product family of the installed SketchUp application.
      This is an Application related attribute, why is it part of the Model class?
      This should be a method of the Sketchup module as in: Sketchup.get_product_family
      _
      I'm not here much anymore.
        Dan Rathbun
        Model.export
        http://code.google.com/apis/sketchup/docs/ourdoc/model.html#export
        options_hash______ A hash containing the COLLADA (.dae) export options.
        The options listed in the hash example is missing the option for hidden geometry.
        The Registry Attribute Name is "ExportHiddenGeometry", but what is the options hash key?
        • hiddengeometry ?* hidden_geometry ?
          _
          Dan Rathbun
          Set class
          http://code.google.com/apis/sketchup/docs/ourdoc/set.html
          This class is defined in the Objectspace and should be listed under "Core Ruby Classes" (along with Array, Length, Numeric and String.)
          Instead it's buried under "App Level Classes" and listed with all those classes that are defined inside the Sketchup module.
          _
            Dan Rathbun
            OptionsProviderObserver.onOptionsProviderChanged
            http://code.google.com/apis/sketchup/docs/ourdoc/optionsproviderobserver.html#onOptionsProviderChanged
            The onOptionsProviderChanged method is invoked when an element is added to an Pages object.
            Should read, "The onOptionsProviderChanged method is invoked when an option is changed for an OptionsProvider object."
            _
              Entities.add_curve
              http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/entities.html#add_curve
              Returns an array of edges - not a Curve object.
                @thomthom said:
                Entities.add_curve
                Ita's the same as add_circle which returns an array od edges and to find the just made curves curve you use edges=entities.add_curve(array_of_points) curve=edges[0].curve
                But strangely not with add_arc which returns an ArcCurve ?
                It would be unadvisable to change what the API does with these add_ methods - rather it we should keep it as is and fix the API's Guide to reflect it properly - too many scripts already get the curve from the edges array and would fail if it were updated to return the curve not the curve's edges...
                  Nope, also returns an array.
                  Agree.
                    Agree.
                    Perhaps I meant to say, "... add_arc which says it returns an ArcCurve wrongly!" πŸ˜’
                      Sketchup.write_default
                      Sketchup.read_default
                      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/sketchup.html#write_default
                      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/sketchup.html#read_default
                      [..] the string associated with a value within the specified sub-section section of a .INI file or registry (within the Software > @Last Software > SketchUp section).
                      Is it really stored under @Last any more?
                        No, / Google / Sketchup 7 / etc... πŸ˜‰
                          Group.move!
                          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/group.html#move!
                          .move! moves to an absolute point. Worth noting in the manual.
                            Dan Rathbun
                            Geom::Point3d.+
                            http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#+
                            The '+' operator is a fast way to add to the current x, y and z values of a point, or to set the values of a point by adding to other points together.
                            The end of the sentence should read, "...by adding **two** other points together."
                            Returns:
                            vector a Vector object
                            There is no defined object named 'vector'. If we follow the example the class of the result is given as Geom::Point3d.
                            pt2 = Geom;;Point3d.new(100,200,300)
                            pt3 = pt2 + [1,1,1]
                            >> Point3d(101, 201, 301)
                            pt3.class
                            >> Geom;;Point3d
                            Arguments:
                            point2 A Point3d object.
                            An ArugemtError exception is raised if point2 is a Point3d object.
                            Valid argument classes are: Array or Vector3d. This means to use a Point3d as an argument, you must convert to Array. Example:
                            pt3 = pt1 + pt2.to_a
                            This method needs to be fixed to take a Point3d object and internally convert it to an Array...
                            # internal to + method
                            if arg[0].is_a? Point3d { arg[0]=arg[0].to_a }
                            ...or a Vector3d:
                            if arg[0].is_a? Point3d { arg[0]=[0,0,0].vector_to(arg[0]) }
                            either way. The current implementation is clumsy.
                              Dan Rathbun
                              **Geom::Point3d.-**
                              http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#-
                              Returns:
                              There is no defined object named 'vector', but there IS one named ' Vector3d'. If we follow the example the class of the result is given as Geom::Vector3d.
                              pt3 = pt2 - [1,1,1]
                              >> Vector3d(99, 199, 299)
                              pt3.class
                              >> Geom;;Vector3d
                              It seems a bit strange that + returns Point3d, but - returns Vector3d.
                                Dan Rathbun
                                Geom::Point3d.offset
                                Code example has errors:
                                [line1]replace"point ="with"point1 ="
                                [line1]use parameter delimiters both lines
                                [line3]replace".offset**!**"with".offset"
                                add comments
                                Corrected code:
                                point1 = Geom;;Point3d.new(10,10,10)
                                vector = Geom;;Vector3d.new(0,0,1)
                                point2 = point1.offset vector
                                # point1 is unchanged
                                # point2 is Point3d(10, 10, 11)
                                Geom::Point3d.offset!
                                add comments
                                point2 = point1.offset! vector
                                # point1 now equals point2
                                  Dan Rathbun
                                  Geom::Vector3d.x=
                                  http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#x=
                                  Geom::Vector3d.y=
                                  http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#y=
                                  Geom::Vector3d.z=
                                  http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#z=
                                  #Anchors: '=' char should be replaced with 'equals' in links.
                                  All 3 methods suffer from the same return class anomoly as the Vector3d.[]= method, in that they return the class of the argument (which may not always be Float.) In contrast, the .x, .y and .z methods always return class Float.
                                  Propose that the .x=, .y= and .z= methods should be modified to return Float as the .x, .y and .z methods do.
                                  Propose to add note: "See the **.set!** method to set all three coordinates in one statement." ( .. to the description sections, of each of the three methods.)
                                    Dan Rathbun
                                    Geom::Vector3d.set!
                                    http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#set!
                                    This is a shortcut for writing:
                                    Clarify: "This is a shortcut for setting all coordinates of the vector, instead of setting them individually in three statements."
                                    You may also call this method with an array or another vector:
                                    Confusing. (I first took this mean that the SU extended Array class had an Array.set! method; which is NOT the case.)
                                    Clarify: "You may also call this method with an Array or a Vector3d object as the first argument,(and any other arguments will then be ignored.)"
                                    Add: "If only one Numeric argument is supplied, or if a one element Array is supplied, then only the x value will be changed. IF only 2 values are supplied, in the same way, then the z value will remain unchanged.
                                    All coordinate values must be implicitly convertable to Float class.
                                    (If you pass a nil value, a TypeError exception is raised.)"
                                    Arguments:
                                    x ____ The x value for the vector.
                                    y ____ The y value for the vector.
                                    z ____ The z value for the vector.
                                    vector2 ____ A Vector3d object.
                                    Remove 4th argument. (There is no valid fourth argument for this method. All args beyond 3 are ignored.)
                                    Clarify: (suggested Argument list)
                                    Arguments:
                                    x ____ The x value for the vector, a Vector3d object, or an Array.
                                    y ____ The y value for the vector. (optional)
                                    z ____ The z value for the vector. (optional)
                                    Better Code Example:
                                    vector = Geom;;Vector3d.new 0,0,1
                                    vector.set! 1,0,0  # three Numeric arguments
                                    vector2 = Geom;;Vector3d.new 1,2,3
                                    vector.set! vector2  # one Vector3d argument
                                    # vector now is (1,2,3)
                                    array1 = Array.new(4,5,6)
                                    vector.set! array1[2]  # one Numeric argument
                                    # vector now is (6,2,3)
                                    vector2.set! array1  # one Array argument
                                    # vector2 now is (4,5,6)
                                    vector.set! [5,4]  # one Array with 2 values
                                    # vector now is (5,4,3)
                                    # change x and z in one statement, this way;
                                    vector.set! 9, vector.y, 8
                                    # vector now is (9,4,8)
                                      Dan Rathbun
                                      Geom::Vector3d.[=]
                                      [="]http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#[]=[/url]
                                      Again the HTML anchor may cause problems in some browsers, suggest '#subscriptEquals'
                                      Obviously the #[]= anchor tag in the url cannot even be displayed properly in this forum.All of the #anchor links to methods using special chars need to be changed to comply with the HTML spec, as ThomThom noted:
                                      ID and NAME tokens must begin with a letter ([A-Za-z]) and may be followed by any number of letters, digits ([0-9]), hyphens ("-"), underscores ("_"), colons (":"), and periods ("."). [url:nfjuel6m]http://www.w3.org/TR/html4/types.html#type-name]("http)
                                      Returns:
                                      value _______ the newly set coordinate value
                                      the Geom::Vector3d.[] method returns class Float
                                      BUT, the Geom::Vector3d.[]= method returns the class of the argument.
                                      The code example may be misleading to the unwary,
                                      value = vector[i] = coordinate
                                      ..if the class of the coordinate variable is Integer then the class of the value variable will also be Integer.
                                      This causes a coder to do a two-step expression if they want a Float, ie:
                                      coordinate = 2
                                      vector[i] = coordinate # returns Integer 2
                                      value = vector[i]  # value.class >> Float
                                      %(#FF4000)[Two Issues:
                                      1. Is 'coordinate' the correct term, or would 'component' be a better term when refering to vectors?1. If all the rest of the methods that return subscript values from a Vector3d object are Float, then perhaps this method should as well, regardless of the class of the argument.]
                                        Dan Rathbun
                                        Geom::Point3d.<
                                        http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#%3C
                                        Returns:
                                        true if the point2 is closer to the origin.
                                        Following the example, I get the opposite result.
                                        TheReturns:should probably read,
                                        " *true* if the point2 is **farther** from the origin; *false* if the point2 is closer to the origin (than the receiver.)
                                          @thomthom said:
                                          Group.move!
                                          It doesn't seem to though - we've been testing it in another thread this afternoon and it seem that it moves relative to the transformation-origin NOT the model's ORIGIN - you first have to do a transformation by vector from where it is to the ORIGIN and then off again to the absolute point ?
                                            @dan rathbun said:
                                            Ruby code can no longer use the nil return value in a conditional boolean statement.
                                            There is also no way now to determine how many Dictionary objects, there are within an AttributeDictionaries collection (No Methods: .size, .length, .count, or .empty?)
                                            There are no methods but several easy combos to do it...
                                            You make an array of it and than get its length ?
                                            len = AttributeDictionaries.to_a.length
                                            or use 'each' ?
                                            len = 0;AttributeDictionaries.each{|d|len += 1}
                                            Where len is the AttributeDictionaries length ?
                                            • 18
                                            • 19
                                            • 8 / 19
