    [Plugin] extrudeEdgesByVector
    20 Posts 9 Posters 37.8k Views 9 Watching
    • C
      chrisjk
      Tig,
      You have been a busy bee - I felt compelled to donate! 😄
      • mitcorbM
        mitcorb
        I want to test this for sure. Thank you TIG
        • mitcorbM
          mitcorb
          I have loaded it in SU6. And I updated lathe and rails. I have a 3button toolbar for 3 functions.
          It just so happens that the other toolbars got scrambled at the top of the window.
          However, extrude by vector and extrude by lathe toolbar buttons work fine.
          I will test extrude by rails later and comment if anything unusual occurs.
          Extrude by vector is sweeeeeeeeet.
          Thank you, sir.
            works but only by icone! 😉
            http://forums.sketchucation.com/download/file.php?id=41124
              Cool add to the tool extrusion set ☀
              Curious, that works with the icone but not by menu Plugins/ Extrude Edges by Vector 😲
              you write
              Run the Tool from Plugins > 'Extrude Edges'.
              or click on 'Extrude Edges' in the 'Extrusion Tools' Toolbar.
              I's not Extrude Edges by Vector ?
              Can you put an image of what must be
              Extract the zipped files into Plugins and their sub-folders...
              because folder Tigtool or file debabeliser.rb will not erase old one? (extrude edges by rails?
              Can we have an option for drawing only with edges at the screen?
              And seems there is not this very useful function 😉
              (here from the Didier Bur tool bar projection plug who has not this function too) 😉
              http://news.sketchucation.com/wp-content/uploads/2009/06/projections.jpg
                Pilou
                If you extract [NOT drag/drop] the contents of this zip you should get three .rb files, which are the script itself, the deBabelizer script and the toolbar maker script. Also there should be a folder [TIGtools] containing the lingvo files and pngs for the buttons and an htm donation link, with a folder of its images too.
                The three rb files go into Plugins folder and the TIGtools folder goes into Plugins folder too. The script looks for the pngs to form the toolbar icons in there - so apparently you have messed up the folders as it's not finding them...
                If you extract a zip file any decent zip-application will keep the file/folder structure - you can either extract the contents directly into the Plugins folder where everything will be in the right place OR into a tempoarry folder on your desktop - and then move its contents to the Plugins folder later...
                Since some of the TIGtools folder's contents and also the other add-on .rb files might already exist answer Yes to overwrite them with these new versions...
                Hope this helps...
                PS: It is quite similar to Didier's tool which I completely rewrote for this and added to my toolset...
                  v1.1 is here with a new improved ES lingvo file thanks to Defisto...
                  http://forums.sketchucation.com/viewtopic.php?p=216977#p216977
                  • EdsonE
                    Edson
                    tig,
                    one of your fantastic plugins also includes a folder named TIGtools (extrude..byLathe). won't there be some confusion between the two? if i just replace the previous one all the pngs and other plugin-specific files will go away, will they not?
                    please advise us on what to do.
                    http://www.mahfuz.arq.br
                      driven
                      @edson said:
                      tig,
                      theres an explanation from TIG over at EEbyRailv2.2, you need to combine all 4 TIGtool folder if you want all 4, there a screenshot from my Mac
                      see if you have the same problem and report back to TIG
                        for next version a radial move and /or scale will be very cool 😄
                        • EdsonE
                          Edson
                          @tig said:
                          Edson
                          There should only be one TIGtools folder ALL of the files - i.e. the lingvo and pngs, htm etc go in there en mass.
                          As you install more of my updated plugins that have button pngs etc I'll put them in there just add to it...
                          Any advice on this 'blank button' issue ?
                          thanks, tig. i had already done so after john's suggestion. i must have done it well as i get a nice toolbar with 3 icons (no blank icon spot) and the 3 tools appear on my plugins menu.
                          i am afraid i have no clue about the 'blank button' issue. i am the quintessential mac user: i do not know much of what goes on underneath the screen.
                            Edson
                            There should only be one TIGtools folder - ALL of the files - i.e. the lingvo and pngs, htm etc go in there en mass. [BUT the .rb files all go directly into Plugins !]
                            • simon le bonS
                              simon le bon
                              Thank you so much TIG,
                              But you produce so quick than it is difficult to follow you. I was still working around and making some tries with "Extrude Edges by RailsV2" while you are outing extrudeEdgesByLathe v2.1, then v2.2, then v2.3!!Oups I succeed to jump on this one but "Platch!" extrudeEdgesByVector v1.1 come in!! I am desesperate , I'm crying mercy.. 🤣
                              total respect,, simon.
                                Rather than update the whole set for one file here's an updated FR lingvo file that Pilou has sent me - it'll be included in the next major update too, but in case any French users would like it now please unzip it and put it into the ../Plugins/TIGtools/ folder and replace the earlier one.
                                extrudeEdgesByVectorFR.zip
                                A tip for general lingvo use:
                                If you have downloaded [or even made] a lingvo file for your language, then to find your current locale id simply type or copy/paste this line into the Ruby Console Sketchup.get_locale.upcase
                                It will return EN-US=English, FR=French, ES=Spanish etc...
                                The lingvo file needs to have that id as a suffix if it is to be found and used instead of the default EN-US English version - e.g. extrudeEdgesByVector**FR**.lingvo would be the French version.
                                Some users - like Pilou - have their locale set to be EN-US even though they are French... they trick the deBabelizer into using the FR lingvo file by making a copy of the extrudeEdgesByVectorEN-US.lingvo file as say extrudeEdgesByVectorEN-US Copy.lingvo, and a copy of the extrudeEdgesByVectFR.lingvo file renamed as extrudeEdgesByVectorEN-US.lingvo to overwrite the original - that way the locale tester finds it to be EN-US and so it uses that file which has been cunningly remade as a French translation ! 💭
                                If there are no lingvo files [e.g. you have deleted them] then the default language that's built into the script (EN-US) is used anyway...
                                This way you can have your tool's prompts and dialogs in any language you like - just make the file as XxxxEN-US.lingvo and it'll get used - so Esperanto [EO] is even possible... 🤓
                                  Here's v1.3 - Menu typo corrected and FR lingvo file updated.
                                    driven
                                    just the fn file???
                                      @driven said:
                                      just the fn file???
                                      Yes - I now have the individual tools and the combo pack to keep synchronized so minor changes affect both.
                                      There were more important changes to the EEbyRails tool...
                                      I'm thinking of stopping the updates of each tool individually and doing the combo only ?
                                      • brodieB
                                        brodie
                                        TIG,
                                        Would it be possible to get a slight tweak on this? The extrusion works great but I use it pretty often and the dialogs sort of break up the flow a bit for me. I wonder if it would be a big deal to have a version that doesn't ask you about reversing the faces and automatically explodes the resulting geometry.
                                        -Brodie
                                        Edit: Nevermind. I just found your post on Didier's ExtrudeLineTool thread. With your modification to get it to work in 2014, that's exactly what I needed. Thanks!
                                        404 Not Found
                                        (sketchucation.com)
