    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 403.0k Views 71 Watching
    • mitcorbM Offline
      mitcorb
      Could this condition be related to another author's plugin that somehow preconditions the session? Or is this just farfetched?
        Thanks for the idea, but I don't think it's a clash - EEbyRails has no 'global variables' etc...
          Could it be some plugin modifying one of the base classes..?
            cmoreink
            I'll be waiting for a new updated version, till then I'll work on trying to figure out what is the problem.
            my portfolio
              layyhkl
              thank
                Jim
                Hi TIG, FYI.
                extrudeEdgesByRails.rb;161; warning; parenthesize argument(s) for future version
                extrudeEdgesByRails.rb;164; warning; parenthesize argument(s) for future version
                extrudeEdgesByRails.rb;172; warning; parenthesize argument(s) for future version
                extrudeEdgesByRails.rb;210; warning; parenthesize argument(s) for future version
                extrudeEdgesByRails.rb;220; warning; parenthesize argument(s) for future version
                extrudeEdgesByRails.rb;230; warning; parenthesize argument(s) for future version
                extrudeEdgesByRails.rb;243; warning; parenthesize argument(s) for future version
                extrudeEdgesByRails.rb;245; warning; parenthesize argument(s) for future version
                extrudeEdgesByRails.rb;626; warning; parenthesize argument(s) for future version
                extrudeEdgesByRails.rb;628; warning; parenthesize argument(s) for future version
                extrudeEdgesByRails.rb;663; warning; parenthesize argument(s) for future version
                extrudeEdgesByRails.rb;669; warning; parenthesize argument(s) for future version
                extrudeEdgesByRails.rb;689; warning; parenthesize argument(s) for future version
                extrudeEdgesByRails.rb;708; warning; parenthesize argument(s) for future version
                extrudeEdgesByRails.rb;710; warning; parenthesize argument(s) for future version
                extrudeEdgesByRails.rb;736; warning; parenthesize argument(s) for future version
                  @jim said:
                  Hi TIG, FYI.
                  > etc
                  It's already fixed in new versions... out soon
                  x=db"text"
                  becomes
                  x=(db("text"))
                  etc...
                    Here's v2.2 with various minor glitch fixes and a new combined Toolbar with other Extrusion Tools...
                    http://forums.sketchucation.com/viewtopic.php?p=201286#p201286
                      driven
                      hi TIG,
                      thanks again,
                      EEbyR and EEbyV don't work out of the plugins menu, but do from toolbar buttons
                      EEbyR's toobar image is blank once EEbyV is loaded, but both work
                      EEbyV looks really useful, but what is 'extrude by sweep' mentioned in the ruby text?
                      EDIT just combined the the 3 Tig folder's and I have all three working icon/buttons, but still no functionality from plugin folder, so can I just comment them out of there.
                        Same for me 😄
                        All works but only with icone 😉
                        When existing image 😉
                        EEV here is blank 😄
                          If you extract [NOT drag/drop] the contents of this zip you should get three .rb files, which are the script itself, the deBabelizer script and the toolbar maker script. Also there should be a folder [TIGtools] containing the lingvo files and pngs for the buttons and an htm donation link, with a folder of its images too.
                          The three rb files go into Plugins folder and the TIGtools folder goes into Plugins folder too. The script looks for the pngs to form the toolbar icons in there - so apparently you have messed up the folders as it's not finding them...
                          If you extract a zip file any decent zip-application will keep the file/folder structure - you can either extract the contents directly into the Plugins folder where everything will be in the right place OR into a tempoarry folder on your desktop - and then move its contents to the Plugins folder later...
                          Since some of the TIGtools folder's contents and also the other add-on .rb files might already exist answer Yes to overwrite them with these new versions...
                          NOTE: Depending on your 'administrator' rights with Vista etc you might be getting incremented copied of files/folders - please look in Plugins and check - you should have one .rb for each of the EEby... scripts you've insatlled, one #extrusionToolbar.rb script to make the toolbar, one deBabelizer.rb to translate languages and one TIGtools folder which itself will contain several .lingvo [translation] files and .png images for the toolbar buttons, and also the htm donation link file and a folder of that file's images...
                          If you have any duplicate folders combine their contents all into the original one and then erase the empty ones, and also any '..Copy..' .rb files you might find too.
                          If this IS happening then it's probably best to extract zips to a temporary folder on your desktop and then move everything [keeping the same folder structure] into Plugins, overwriting any existing stuff...
                          Hope this helps...
                            @driven said:
                            hi TIG,
                            'ExtrudeEdgesBySweep' was a proto-tool that's now abandoned [I had hoped for results different from EEbyR but the new algorithms produced inconsistent results that were almost identical anyway, so I gave up on it] - all references to it should have been removed - they is now, and will be omitted in any updates... Sorry for the confusion...
                              driven
                              no apology needed, most people don't read the rubies, and I just thought it was maybe yet another super-duper 'secret' tool that I'd missed and that it was maybe why I get a blank tool button.like this
                              However, now knowing that it's not and still not having the ability to use any of the EE tools from the plugin menu, I've been trying a few things to get that functionality back and I can't.
                              Basically
                              1: I have a 'spare' Button that does nothing if there is any single EE tool installed (so, I'll get 2,3 or 4 buttons, never one)
                              2: Plugin Menu function does not work with one or all EE tools installed (they are there) with or without #extrusionToolbar.rb.
                              I don't think it's a 'Mac' thing, your scripts never give me those sort of issues, and it's not an install issue either, although Mac's do Copy/Paste + Drag/Drop differently to PC's, I know that and have a fairly bullet proof procedure I use all the time.
                                @driven said:
                                no apology needed, most people don't read the rubies, and I just thought it was maybe yet another super-duper 'secret' tool that I'd missed and that it was maybe why I get a blank tool button.[attachment=0:3504o1ud]<!-- ia0 -->BlankButton.jpg<!-- ia0 -->[/attachment:3504o1ud]
                                Basically
                                When you hover over the blank button what tooltip or VCB message do you get ?
                                In the Plugins Menu do you have duplicate EEby.. entries ?
                                I suspect you have two copies of something around somewhere... Are all your plugins in the a same folder ??
                                  How many tools must have now the Extrude Bar tools?
                                  • Bob JamesB Offline
                                    Bob James
                                    I get the two icons on the right (EEbR and EEbV), but what are the next two?
                                      You can have 1, 2, 3 or 4 buttons, depending on which Plugins you have downloaded - which can be any of these - EEbyEdges, EEbyLathe, EEbyRails and EEbyVector... [EE=ExtrudeEdges - saves typing... damn I did it anyway 😒 ]
                                      You also need #extrusionToolbar.rb which makes the toolbar when it loads [if any one of these other rb files is in the Plugins folder] - the other rubies then load and make a Plugins>Menu item and a 'Extrusion Tools' Toolbar button for themselves [if it finds the toolbar has been made beforehand] - if a button .png is missing [e.g. perhaps you have put it in the wrong place] you get a blank button but the tooltip and VCB texts should still work etc...
                                        driven
                                        No tooltip message, but it does toggle grey [on/off], effects nothing
                                        No duplicates, even took out lath.rb, just in case
                                        All my plugins are in same folder
                                        #extrusionToolbar.rb is at top of list
                                          I know Fredo has had problems with files being copied into duplicate Plugins folders in different places ? Any cahce of this ?
                                          Any other Mac users getting similar problems with these tools ?
                                          Any Mac users getting NO problems with these tools ?
                                          Help appreciated... 😕
                                            driven
                                            and this one
                                            TIGtools combined
                                            • 11
                                            • 12
                                            • 13
                                            • 19
                                            • 20
                                            • 11 / 20
