    New API doc - typos and questions
    370 Posts 35 Posters 269.8k Views 35 Watching
      Camera.set
      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/camera.html#set
      The initialize method is deprecated. It essentially does the same thing as Camera.set.
      Seems that's the description for Camera.new http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/camera.html#new
      ...and that Camera.new has the description for Camera.set
        View.pickray
        http://code.google.com/apis/sketchup/docs/ourdoc/view.html#pickray
        Returns:
        ray
        a ray
        "a ray"? Without testing this I#m guessing either a vector or line.
        • Dan RathbunD Offline
          Dan Rathbun
          @thomthom said:
          View.pickray
          Returns:
          ray a ray
          see this...
          Model.raytest
          A ray is a two element array containing a point and a vector [Geom::Point3d(), Geom::Vector3d()]. http://code.google.com/apis/sketchup/docs/ourdoc/model.html#raytest
          _
          I'm not here much anymore.
            Yea - I tested it later that day. It's what the Geom module describes as a line.
              Dan Rathbun
              Shouldn't the API have a definition for Line and/or Ray as a class (under the Geom module) ?
              something like:
              class Geom;;Ray < Array
                def new(*args)
                  Array[Geom;;Point3d().new, Geom;;Vector3d().new]
                  super()
                Line and Plane? hm... maybe... thought of that myself. but never really felt the need for it to make a request. works fine as it is.
                Dealing with them as Arrays works ok. They are simple structures.
                  Dan Rathbun
                  Model.add_note
                  The note is not displayed unless there are entities in the model. If you add a note first thing in a new model, it is invisible but .visible? on the note object still returns true.
                  As soon as you draw something, the note appears.
                    Jim
                    Thanks Dan - yet more never-seen-before docs coming to light.
                      I have the mental image of Scott drowning in printouts from this thread... πŸ˜’ πŸ˜†
                        Jim
                        Oh, I think there is a completely undocumented UTM class in there somewhere under Geom.
                          hm.. all I can find out about that one is:
                          Geom::UTM.instance_methods.sort.join("\n") (eval):894: warning: instance_methods: parameter will default to 'true' as of 1.8.1 to_a to_latlong to_s x y zone_letter zone_number
                            Jim
                            View.show_frame
                            Documentation for this method contains some poorly-parsed html tags.
                              Dan Rathbun
                              Geom::UTM.instance_methods.sort.join("\n")... snip ...
                              from Wikipedia search on "UTM":
                              Universal Transverse Mercator coordinate system, a grid-based method of mapping locations on the surface of the Earth.
                              http://en.wikipedia.org/wiki/Universal_Transverse_Mercator_coordinate_system
                              _
                                Dan Rathbun
                                Model.get_product_family
                                http://code.google.com/apis/sketchup/docs/ourdoc/model.html#get_product_family
                                Returns a constant number which indicates the product family of the installed SketchUp application.
                                This is an Application related attribute, why is it part of the Model class?
                                This should be a method of the Sketchup module as in: Sketchup.get_product_family
                                _
                                  Dan Rathbun
                                  Model.export
                                  http://code.google.com/apis/sketchup/docs/ourdoc/model.html#export
                                  options_hash______ A hash containing the COLLADA (.dae) export options.
                                  The options listed in the hash example is missing the option for hidden geometry.
                                  The Registry Attribute Name is "ExportHiddenGeometry", but what is the options hash key?
                                  • hiddengeometry ?* hidden_geometry ?
                                    _
                                    Dan Rathbun
                                    Set class
                                    http://code.google.com/apis/sketchup/docs/ourdoc/set.html
                                    This class is defined in the Objectspace and should be listed under "Core Ruby Classes" (along with Array, Length, Numeric and String.)
                                    Instead it's buried under "App Level Classes" and listed with all those classes that are defined inside the Sketchup module.
                                    _
                                      Dan Rathbun
                                      OptionsProviderObserver.onOptionsProviderChanged
                                      http://code.google.com/apis/sketchup/docs/ourdoc/optionsproviderobserver.html#onOptionsProviderChanged
                                      The onOptionsProviderChanged method is invoked when an element is added to an Pages object.
                                      Should read, "The onOptionsProviderChanged method is invoked when an option is changed for an OptionsProvider object."
                                      _
                                        Entities.add_curve
                                        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/entities.html#add_curve
                                        Returns an array of edges - not a Curve object.
                                          @thomthom said:
                                          Entities.add_curve
                                          Ita's the same as add_circle which returns an array od edges and to find the just made curves curve you use edges=entities.add_curve(array_of_points) curve=edges[0].curve
                                          But strangely not with add_arc which returns an ArcCurve ?
                                          It would be unadvisable to change what the API does with these add_ methods - rather it we should keep it as is and fix the API's Guide to reflect it properly - too many scripts already get the curve from the edges array and would fail if it were updated to return the curve not the curve's edges...
                                            Nope, also returns an array.
                                            Agree.
                                            • 18
                                            • 19
                                            • 6 / 19
