    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
    • Chris FullmerC Offline
      Hi James, re-read the first post of this thread. It describes a lot. And it has a .pdf file that includes installation help.
      Or if you were a bit more specific, more specific help might returned too. Its unclear if you just can't find the downlaod file, can't figure out how to install it, or can't use the tools once its installed. Plenty of places people tend to get lost in the process.
        jpurdy77
        ok, well i tried for a hour or so and im running a mac, the help is for windows or so it seems. downloaded it but cant seem to get it running in sketch up. must be something wrong, thus a mac step y step guid would help.
        James
          ok, so you're looking for installation help then, right? Where did you place the files? Perhaps you could take screenshot of the plugins folder if that is where youn put them?
            mics_54
            Edit postDelete postReport this postReply with quoteRe: [Plugin Library] LibFredo6 - v3.4b - 11 Nov 09
            by mics_54 on Sun Dec 13, 2009 6:54 pm
            I hope this is the right place to post a question about fredo scale.
            I find the tool very useful and will start by thanking you for making it. I would like to thank you with a donation when things are more fiscally condusive.
            Now, I build cabinetry etc and often a face frame on a cabinet will have multiple drawers. I have used fredoscale to stretch the cabinets to a taller dimension (or shorter as the case may be) with complete success with all members maintaining their original dimensions except the height or width. However on face fronts with multiple openings I can not find a way to stretch the front taller and have the openings for multiple drawers increase uniformly.
            Can FS do this or am I asking too much at this time? I just wondered if I wasn't using the tool to it's capabilities.
            tia!
            • fredo6F Offline
              Maybe a picture would help to understand the exact issue you have.
              Just in case, did you try with the Divider (key F4)? This allows positioning the pivot stretch plane where you need.
                mics_54
                No I didn't and I thought I saw something regarding that but I couldn't find it again. I am assuming there is only one stretch plane so I would need to use it 4 times on a face front with four openings. Here is an image the front and cabinet.
                  mics_54
                  Fredo, I found the video and it answered my questions thanks. I guess I would have to calculate the adjustmet in the size of each drawer opening and resize the front accordingly x4.
                  Thanks again.
                  • Y Offline
                    ygcl
                    Well,but don`t download.
                    • zieiosZ Offline
                      zieios
                      ok
                      koooooooooooooooooooooooooooooooooooooooooooooooooooooool
                        mike_in_ky
                        Hi...
                        I'm a newbie to SketchUp. I was looking at this topic and thought this plugin would benefit me in what I want to do with SU. I can't figure out how to download the plugin (FredoScale 2.0h).
                        Thanks,
                        mike_in_ky
                          Hi Mike, it is in the very first post of this thread. Also read all the instructions. There is another file you will need to download and install along with this one to get it to all work,
                            mike_in_ky
                            Chris...
                            Thanks. I finally found it and downloaded. I'll try installing later today.
                            Mike
                              mike_in_ky
                              Chris...
                              I was successful in installing Fredoscale 2.0 and worked with it a little. It's just what I wanted. Thanks for your help.
                              Mike
                                swzaw
                                Thanks...It's wonderful Tool.
                                • bagateloB Offline
                                  bagatelo
                                  Is it possible to access and to use the tools of great FREEDO for other scripts, enlarging Google Sketchup's API or something like this?
                                  • fredo6F Offline
                                    Do you have anything specific in mind?
                                      alz
                                      Hi Fredo6 --
                                      Fantastic script, love being able to scale non-axis aligned!
                                      When scaling, I saw the global unit position is displayed in the status bar as it scales. For example, taking a big box and scaling it down displays [~500] when it passes 500 in the Z-axis.
                                      Is it possible to have the distance moved display as well? So, if the box's top face was at 700z and was scaled down to 500z, the status bar would also display [-200].
                                      Or, better yet -- Have an option to swap the scale percentage in the VCB for unit distance. So, instead of the VCB saying 0.71, it would say -200. Having this option lets objects be scaled by the model unit for exact face location (rather than eyeballing a percentage).
                                      ๐Ÿ˜„
                                        arjunmax09
                                        i'm having a problem using the bender tool in freedo scale... for instance.. in case of bending a cuboid...when the protractor comes.... instead of bending my cuboid .... it changes into a wedge....like a ramp...what shd. i do??
                                        when you fail at something....you haven't really failed...you've found one way the thing will not work out
                                          Jim
                                          Tap the F4 key - that will turn on segments.
                                          • H Offline
                                            harshal kshatriya
                                            thanks man.......
                                            i love it.........
                                            it working. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 56
                                            • 57
                                            • 37 / 57
