    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.3m Views 345 Watching
      mics_54
      Just in case, did you try with the Divider (key F4)? This allows positioning the pivot stretch plane where you need.
      No I didn't and I thought I saw something regarding that but I couldn't find it again. I am assuming there is only one stretch plane so I would need to use it 4 times on a face front with four openings. Here is an image the front and cabinet.
        mics_54
        Fredo, I found the video and it answered my questions thanks. I guess I would have to calculate the adjustmet in the size of each drawer opening and resize the front accordingly x4.
        Thanks again.
        • Y
          ygcl
          Well,but don`t download.
          • zieiosZ
            zieios
            ok
            koooooooooooooooooooooooooooooooooooooooooooooooooooooool
              mike_in_ky
              Hi...
              I'm a newbie to SketchUp. I was looking at this topic and thought this plugin would benefit me in what I want to do with SU. I can't figure out how to download the plugin (FredoScale 2.0h).
              Thanks,
              mike_in_ky
              • Chris FullmerC
                Hi Mike, it is in the very first post of this thread. Also read all the instructions. There is another file you will need to download and install along with this one to get it to all work,
                  mike_in_ky
                  Chris...
                  Thanks. I finally found it and downloaded. I'll try installing later today.
                  Mike
                    mike_in_ky
                    Chris...
                    I was successful in installing Fredoscale 2.0 and worked with it a little. It's just what I wanted. Thanks for your help.
                    Mike
                      swzaw
                      Thanks...It's wonderful Tool.
                      • bagateloB
                        bagatelo
                        Is it possible to access and to use the tools of great FREEDO for other scripts, enlarging Google Sketchup's API or something like this?
                        • fredo6F
                          Do you have anything specific in mind?
                            alz
                            Hi Fredo6 --
                            Fantastic script, love being able to scale non-axis aligned!
                            When scaling, I saw the global unit position is displayed in the status bar as it scales. For example, taking a big box and scaling it down displays [~500] when it passes 500 in the Z-axis.
                            Is it possible to have the distance moved display as well? So, if the box's top face was at 700z and was scaled down to 500z, the status bar would also display [-200].
                            Or, better yet -- Have an option to swap the scale percentage in the VCB for unit distance. So, instead of the VCB saying 0.71, it would say -200. Having this option lets objects be scaled by the model unit for exact face location (rather than eyeballing a percentage).
                              arjunmax09
                              i'm having a problem using the bender tool in freedo scale... for instance.. in case of bending a cuboid...when the protractor comes.... instead of bending my cuboid .... it changes into a wedge....like a ramp...what shd. i do??
                              when you fail at something....you haven't really failed...you've found one way the thing will not work out
                                Jim
                                Tap the F4 key - that will turn on segments.
                                • H
                                  harshal kshatriya
                                  thanks man.......
                                  i love it.........
                                  it working. 👍 👍 👍
                                    arjunmax09
                                    nothing happens, it opens the layer palette... I've attached a video of what happens when i try to bend an object..it will show what exactly goes wrong.....
                                    Problems using fredoscale bender.zip
                                    • C
                                      chrisjk
                                      Another way to turn slicing on is to use the right click context menu once the shape is selected with the bender tool.
                                        AR-51
                                        Hi, I install Libfredo6,RoundCorner and Fredoscal, but I'm unable to use them in SketchUp.
                                        When I click on Tools>FredoScale noting happens. I also get no response when I click on Window>Libfredo6>Default Parameter.
                                        Can anyone with Window Vista help me? I don't get the option to unzip when I download the folders.
                                        Thanks for the help.
                                        Cannot access Fredoscal or RoundCorner from Tools>Fredo6 Collections.
                                        http://i601.photobucket.com/albums/tt93/Bestworldphoto/Sketch.jpg
                                        Plug in foulder
                                        http://i601.photobucket.com/albums/tt93/Bestworldphoto/Plugin.jpg
                                        • fredo6F
                                          Do you have the icons in the Toolbar?
                                          Otherwise, can you turn the Ruby console on, and then select the menu LibFredo6 Default Parameters.
                                          Finally, can you check the content of the folders FREDOSCALE_Dir_20, etc... to verify they correspond to the footprint of the doc.
                                            d12dozr
                                            Fredo,
                                            Thank you for one of the most brilliant tools in Sketchup, I use FredoScale regularly.
                                            I am wondering if you could add the option to Box Stretching of multiple stretch dividers spaced equally by default, but also with the ability to manually adjust their position as well? Each portion would be stretched equally. This would be especially useful on say a window with multiple panes where now I stretch in two or more steps. Maybe the user could add dividers with F5 or subtract dividers with F6.
                                            Just an idea, and thanks again for all of your tools 😄
                                            http://goo.gl/f7ooYh
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 58
                                            • 59
                                            • 20 / 59
