    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
    • G
      gavvy
      😮 just fit me !
      • mariochaM
        mariocha
        Just wanted to say that this plugin, amongs others, is really worth a donation, imho. 😄
        The parametric feature of the tools is so useful. !
        %(#008000)[Mario C.
        • fredo6F
          [Update to Chinese version - 26 Nov 09 - 21:50 CET
          The SuBAR_CLT team at SketchupBar have updated the translation the script into Chinese.
          See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=17948#p144180).
            jpurdy77
            unable to use plugin fredoscale on a mac, is there a help/ instructions on what to do.
            thanks
            • Chris FullmerC
              Hi James, re-read the first post of this thread. It describes a lot. And it has a .pdf file that includes installation help.
              Or if you were a bit more specific, more specific help might returned too. Its unclear if you just can't find the downlaod file, can't figure out how to install it, or can't use the tools once its installed. Plenty of places people tend to get lost in the process.
                jpurdy77
                ok, well i tried for a hour or so and im running a mac, the help is for windows or so it seems. downloaded it but cant seem to get it running in sketch up. must be something wrong, thus a mac step y step guid would help.
                James
                • Chris FullmerC
                  ok, so you're looking for installation help then, right? Where did you place the files? Perhaps you could take screenshot of the plugins folder if that is where youn put them?
                    mics_54
                    Edit postDelete postReport this postReply with quoteRe: [Plugin Library] LibFredo6 - v3.4b - 11 Nov 09
                    by mics_54 on Sun Dec 13, 2009 6:54 pm
                    I hope this is the right place to post a question about fredo scale.
                    I find the tool very useful and will start by thanking you for making it. I would like to thank you with a donation when things are more fiscally condusive.
                    Now, I build cabinetry etc and often a face frame on a cabinet will have multiple drawers. I have used fredoscale to stretch the cabinets to a taller dimension (or shorter as the case may be) with complete success with all members maintaining their original dimensions except the height or width. However on face fronts with multiple openings I can not find a way to stretch the front taller and have the openings for multiple drawers increase uniformly.
                    Can FS do this or am I asking too much at this time? I just wondered if I wasn't using the tool to it's capabilities.
                    tia!
                    • fredo6F
                      Maybe a picture would help to understand the exact issue you have.
                      Just in case, did you try with the Divider (key F4)? This allows positioning the pivot stretch plane where you need.
                        mics_54
                        No I didn't and I thought I saw something regarding that but I couldn't find it again. I am assuming there is only one stretch plane so I would need to use it 4 times on a face front with four openings. Here is an image the front and cabinet.
                          mics_54
                          Fredo, I found the video and it answered my questions thanks. I guess I would have to calculate the adjustmet in the size of each drawer opening and resize the front accordingly x4.
                          Thanks again.
                          • Y
                            ygcl
                            Well,but don`t download.
                            • zieiosZ
                              zieios
                              ok
                              koooooooooooooooooooooooooooooooooooooooooooooooooooooool
                                mike_in_ky
                                Hi...
                                I'm a newbie to SketchUp. I was looking at this topic and thought this plugin would benefit me in what I want to do with SU. I can't figure out how to download the plugin (FredoScale 2.0h).
                                Thanks,
                                mike_in_ky
                                • Chris FullmerC
                                  Hi Mike, it is in the very first post of this thread. Also read all the instructions. There is another file you will need to download and install along with this one to get it to all work,
                                    mike_in_ky
                                    Chris...
                                    Thanks. I finally found it and downloaded. I'll try installing later today.
                                    Mike
                                      mike_in_ky
                                      Chris...
                                      I was successful in installing Fredoscale 2.0 and worked with it a little. It's just what I wanted. Thanks for your help.
                                      Mike
                                        swzaw
                                        Thanks...It's wonderful Tool.
                                        • bagateloB
                                          bagatelo
                                          Is it possible to access and to use the tools of great FREEDO for other scripts, enlarging Google Sketchup's API or something like this?
                                          • fredo6F
                                            Do you have anything specific in mind?
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 58
                                            • 59
                                            • 20 / 59
