    [Plugin] Import STL files
    40 Posts 18 Posters 51.4k Views 18 Watching
    • Didier BurD Offline
      Didier Bur
      AAARGGHHHH 71 Mb !
      Downloading it now, but I guess the file is too big for SU...
      DB
        casey344
        Sorry, not my doing. 😕
        Manufacturer sent it that way.
          jwelin
          Thanks for the work on this plugin. I have a three questions:
          Is there a limit to the level of nested groups/components it exports?
          The exported STL seems to be incompatible with some applications. Rhino sees the geometry, for instance, while Magics does not. Also an SU2stl generated stl, opened in Rhino and resaved as an STL is much smaller in file size. Would you like to see examples?
          Is there a way to call this plugin from another? I have a need to batch export.
          John Welin
          architectural model maker
          Chicago, USA
            Didier Bur
            There are several STL formats which slightly differ in their syntax. The one I have choosen to export is the most standard one, as defined here for instance:
            http://www.gom.com/CONTAINER/files/sp_stl_en.pdf
            or here:
            http://mech.fsv.cvut.cz/~dr/papers/Lisbon04/node2.html
            Maybe some applications do not support every kind of STL ?
            I don't have Rhino, but I suppose that it saves an STL in the binary format, while my script saves it in ASCII (text), which is 8 times bigger (average). You can see the same differences between an ascii dxf and a binary dxf (dxb) for instance.
            No. Not tested here but as a recursive method is involved, there should be no limits.
            Components are NOT supported, groups are.
            Unfortunately no.
            Regards,
            DB
              I found that recursive methods might cause SU to bugsplat. http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=15585&p=120726 I had a method that looped over entities to find connected entities which used a recursive method. Had to change it to an iterative method.
                Didier Bur
                Bad news 😞
                DB
                  Mind you, it happens when you do many recursions. When crawling geometry you quickly end up with hundreds iterations. So if the script never goes that deep you're ok. But it's something to be aware of.
                  • N Offline
                    NewOne
                    When exporting STL from SolidWorks, here is an option to put all geometry in same file or to create separate file for each part. Mr. Didier Bur, could this script to be modified in a manner that allows multiple file selection and each geometry to be made group (or component if there are more identical parts) ? Or to specify a folder where stl part files are located?
                    Thank you.
                      Didier Bur
                      Dropped into the to-do list 😉
                      DB
                        bump
                        (sorry Dider - no practical reason just testing some moderation stuff)
                          stefkeB
                          Minor improvement:
                          On line 54 you call the "openpanel" method when exporting. This should be "savepanel", so the user gets the correct dialog displayed. Still works on Windows but not on OSX, where you need to point to an already existing file.
                          Also, the default "." file location could be replaced with ENV['USER'] or ENV['HOME'] or preferably the current file folder, as to make it more convenient. With 'USER' it works much better for me on OSX.
                          (I refer to the unscrambled file, obviously, not the compacted one -- maybe the reason why people think it is a binary file)
                            Didier Bur
                            @stefkeB: I'm using openpanel when importing, and savepanel when exporting. So I don't understand what you're talking about, propably you have an old version, because the latest one is v1.3. (Nov 2009) and is scrambled in a RBS file (so unreadable).
                            DB
                              I've been looking around at the various ruby based importers for SketchUp and I see that no one uses the Importer class. If this class is used the importer can be found in the native import list which would be very nice.
                              http://code.google.com/apis/sketchup/docs/ourdoc/importer.html
                              • charly2008C Offline
                                charly2008
                                Hi Didier,
                                I have tried the tool in Sketchup 8. The Unit support appears and I can choose my unit but then nothing happens. I've attached the stl files which I downloaded from Internet.
                                Charly
                                knot.zip
                                brain-gear.zip
                                  Didier Bur
                                  Hi Charly,
                                  Your files are binary STL files. The script cannot read such files, but only ASCII STL format.
                                  You can convert binary STL's to ASCII with Meshlab (free) for instance.
                                  Regards,
                                  DB
                                    charly2008
                                    Hi Didier,
                                    Thank you for the explanation. I learned something more to it.
                                    Charly
                                      davidheim1
                                      Didier,
                                      I just downloaded the STL Export/Import plug-in on my Mac, but I can't make it work. It asks me for the name of a file to export, but won't ever let me export anything. What am I missing? Can you provide a brief explanation of how to make the export function work?
                                      Many thanks,
                                      David Heim
                                      • mariochaM Offline
                                        mariocha
                                        @davidheim1 said:
                                        Didier,
                                        It asks me for the name of a file to export to, but won't ever let me export anything.
                                        David Heim
                                        Same here. It happens with the one loaded from SketchUcation store.
                                        But the one on CRAI Ruby depot, loaded the old way, manually, works.
                                        %(#008000)[Mario C.
                                          I recommend that anyone importing or exporting STL files in SketchUp use the open source plugin that SketchUp released: http://extensions.sketchup.com/en/content/sketchup-stl
                                          • F Offline
                                            frankleng
                                            very fast and good.thanks /
                                            • 2 / 2
